#21 |
nalini
Rep Power: 17 ![]() |
krystian,
how did you solve this error: #0 Foam::error::printStack(Foam:stream&) #1 Foam::sigFpe::sigFpeHandler(int) #2 __restore_rt #3 Foam::momentCoefficient(Foam::GeometricField<foam: :vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&) #4 main #5 __libc_start_main #6 __gxx_personality_v0 Floating point exception i am getting the same message using v1.4 on fedora for the cavity example .... am looking now in the forum for any clues but would really appreciate it if you could explain how you solved it cheers |
#22 |
Rep Power: 18 ![]() |
Nalini,
It would be good if you could also include what appears before these lines which you posted. Generally, the answer for that is, that liftDrag is not suited for every solver. Current stage only allows its use for one-phase flows or at least it doesn't work for two-phase flows which I tested. Try to run it for simpleFoam, that should work. However for icoFoam it doesn't. As you see it is kind of limited. If anyone managed to run it for rasInterFoam, any info will be appreciated. Thanks, K |
#23 |
nalini
thanks
i was using icoFoam will have a play and see what i can come up with |
#24 |
let us know what you've got.
#25 |
Rajneesh
HI All,
I am getting following error at the last step ![]() of Any clues on what is going on here. thanks in advance g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/postProcessing/incompressible/lnInclude -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/transportModels -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/turbulenceModels -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/LESmodels/LESdeltas/lnInclude -IlnInclude -I. -I/home/raj/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/liftDrag.o -L/home/raj/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \ -lincompressiblePostProcessing -lfoamUtil -lOpenFOAM -ldl -lm -o /home/raj/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag /usr/bin/ld: cannot find -lfoamUtil collect2: ld returned 1 exit status make: *** [/home/raj/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag] Error 1 |
#26 |
N S Prasad
Hi
I have a dreadfully slow connection and downloading OF1.2 will take 4 hrs or more. Can anyone just give me the liftdrag sources in a tarball?? Thanks. |
#27 |
Hrvoje Jasak
Rep Power: 33 ![]() |
You can find all the files accessible individually in the
dev SVN repository. Try: src/postProcessing/incompressible/liftDrag/ Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
#28 |
Alessandro Spadoni
Hello Forum,
I just installed the utility liftDrag as suggested in: http://www.cfd-online.com/OpenFOAM_D...es/1/2299.html I am running a very simple case in simpleFoam. I have a naca0012 at 0 angle of attack, and k-epsilon for modeling turbulence. I get the analysis to converge nicely, pressure looks good, velocity, k, epsolin, etc. look very good. When I run liftDrag . naca0012 -time 700 for example, I get this output: [gtg627eOpenFOAM@ruzzene03 simpleFoam]$ liftDrag . naca0012 -time 700 /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : liftDrag . naca0012 -time 700 Date : Oct 29 2007 Time : 03:42:42 Host : ruzzene03 PID : 9647 Root : /home/gtg627eOpenFOAM/OpenFOAM/gtg627eOpenFOAM-1.4.1/run/tutorials/simpleFoam Case : naca0012 Nprocs : 1 Create time Create mesh for time = 700 Time = 700 Reading U Reading p Inlet velocity: (50 0 0) Wall patch 1 named airfoiln : Reference area: 0.297421 Reference length: 1 Drag coefficient: 0.00116109 Lift coefficient: (0 8.21932e-05 -1.32776e-21) Moment coefficient: (-2.05483e-06 2.90273e-05 -1.95907e-05) This result seems to not include viscous forces. The drag for a naca0012 at 0 deg and Re ~ 3 million should be approximately 0.0058, from "theory of wing sections." Thank you in advance for any comments, Alessandro |
#29 |
Alessandro Spadoni
Hello Forum,
In directory "applications/utilities/postProcessing/miscellaneous/liftDrag/liftDrag.C I see the follwing call: ------------------------------------------------------------- Info<< "Wall patch " << patchI << " named " << patches[patchI].name() << " : " << nl << "Reference area: " << Aref << " Reference length: " << Lref << " Drag coefficient: " << dragCoefficient ( U, p, nu, patches[patchI].name(), Uav, Aref ) ------------------------------------------------------------------ but in file ../src/postProcessing/incompressible/liftDrag/liftDrag.C I see that I can also compute turbDragCoefficient. Following the above example for the drag coefficient I can call: scalar turbDragCoefficient ( const autoPtr<foam::turbulencemodel>& turbulence, const volVectorField& U, const volScalarField& p, const dimensionedScalar& mu, const word& patchName, const vector& Uinf, const scalar& Aref ); My questions are: 1. How do I specify the input const autoPtr<foam::turbulencemodel>& turbulence? 2. is mu the same as nu? It seems so in the first file I mentioned above. Thank you again, Alessandro |
#30 |
Alessandro Spadoni
Hello Forum,
Sorry for the impulsive message writing. The solution to the problem I pointed out in the previous two messages can be found in: http://www.cfd-online.com/OpenFOAM_D...es/1/5067.html Thank you, Alessandro |
#31 |
Fabian Korn
Hi Forum,
i am a new OpenFOAM user and have a problem with compieling the lift and drag force tool. At step 6 II the following error showed up, and an error occurs if i try to run step 7. Would be perfect if somebody would help me. The following lines is only the end of the error. /tmp/cchPMiak.s:11202: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11203: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11204: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11205: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11206: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11207: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11208: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11209: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11210: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11211: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11212: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11213: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11214: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11215: Error: unknown pseudo-op: `.weakref' /tmp/cchPMiak.s:11917: Warning: setting incorrect section attributes for .data.DW.ref.__gxx_personality_v0 /tmp/cchPMiak.s:11924: Warning: setting incorrect section attributes for .text.__i686.get_pc_thunk.bx make: *** [Make/linuxGccDPOpt/liftDrag.o] Error 1 Thanks a lot. |
#32 |
Hrvoje Jasak
This is a compiler problem - you need to rebuild gcc on your machine and it will go away.
Hrv
#33 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 ![]() ![]() |
It may not be that bad. This weakref thing is usually a problem with the assembler. Usually this means that the binutils (where the assembler belongs) are waaaay older than the compiler. So recompiling the binutils might help as well (it is as difficult as recompiling gcc, but takes less time)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
#34 |
Fabian Korn
Hi again,
thank you for the help, now step 6 compiled well, but i still get an error during step 7. Sorry for asking proberbly stupid questions buti am quiet new with linux and OpenFOAM Here is the error massage. ccDPOpt/liftDrag.o -L/home/fabian/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \ -lincompressiblePostProcessing -lfoamUtil -lOpenFOAM -ldl -lm -o /home/fabian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag /usr/bin/ld: cannot find -lfoamUtil collect2: ld returned 1 exit status make: *** [/home/fabian/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag] Error 1 Is it still a compiler problem? I compiled gcc-4.2.1 on my computer: Thanks for helping me again. |
#35 |
Fabian Korn
Everything what i tried before was executed with OpenFOAM 1.4.1,
When i try it with OpenFOAM 1.4, then i get the same massage exept that it cannot find -lincompressiblePostProcessing |
#36 |
Juho Peltola
Could anyone help me with my liftDrag to 1.4.1 conversion?
I followed the directions posted in this thread until I ran in to the same problem as Fabian and Rajneesh ie. "foamUtil not found". I then copied the foamUtil directory from 1.2 and ran "wmake libso foamUtil". After that liftDrag compiled without errors but when I test it on the icoFoam/cavity: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : liftDrag . cavity -latestTime Date : Feb 26 2008 Time : 16:37:31 Host : LinuxLoota PID : 27737 Root : /home/juho/OpenFOAM/peltol20-1.4.1/run/tutorials/icoFoam Case : cavity Nprocs : 1 Create time Create mesh for time = 0.5 Time = 0.5 Reading U Reading p Inlet velocity: (1 0 0) #0 Foam::error::printStack(Foam: ![]() #1 Foam::sigFpe::sigFpeHandler(int) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: [0xffffe420] #3 Foam::momentCoefficient(Foam::GeometricField<foam: :vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::dimensioned<double> const&, Foam::word const&, Foam::Vector<double> const&, double const&, double const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libincompressiblePostProce ssing.so" #4 main in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag" #5 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #6 Foam::regIOobject::readIfModified() in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/liftDrag" Floating point exception (core dumped) ================================================== It gives a similar error message when I try it on my automotive test case but in this case it also lists the inlet velocity as 60 instead of 30 it really is. I'm using a 32-bit Ubuntu Gutsy on a Intel machine. Any guidance is greatly appreciated! Juho |
#37 |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 ![]() |
There is a division by zero somewhere. Please run the liftDrag utility on a different case to confirm this. Alternately, you can find several threads in this forum that help you to modify your solver to print lift and drag info directly in the log file for every time step.
#38 |
Juho Peltola
Thank you.
I ran it on my simpleFoam automotive test case with a similar result. I found your (?) turbFoam_1 solver with built in lift and drag calculation on the forum. I'll look into it next. |
#39 |
Juho Peltola
I included the lift and drag calculations to the simpleFoam but in a very crude way. I compiled in the reference velocity and kinematic viscosity.
Seems to be working... |
#40 |
Gabriela Bracho
Hello!!
I'm running some cases of the tutorial... I've found some differences between my results and the results that appear in the User Guide (v.OF-1.4). Specially in the cavityHighRe case. (in spite of we're using the same set-up) The Guide says that U should converge at Time=1.63, but when I run it, it converged at Time=1.805. Then we run it in other machine and other version of OpenFoam (1.4.1) and the results where the same of v.1.4 (Time=1.805), but different to the Manual: Our results at Time=1.63 are: >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Time = 1.63 Courant Number mean: 0.11671 max: 0.839843 DILUPBiCG: Solving for Ux, Initial residual = 2.18463e-05, Final residual = 2.98021e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 2.52903e-05, Final residual = 2.92166e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 2.94105e-05, Final residual = 8.12416e-07, No Iterations 8 time step continuity errors : sum local = 6.12008e-09, global = 4.01513e-19, cumulative = 1.31549e-18 DICPCG: Solving for p, Initial residual = 1.08552e-05, Final residual = 8.55134e-07, No Iterations 5 time step continuity errors : sum local = 6.10618e-09, global = -6.73987e-19, cumulative = 6.41498e-19 ExecutionTime = 0.84 s ClockTime = 1 s Time = 1.635 Courant Number mean: 0.116714 max: 0.839846 DILUPBiCG: Solving for Ux, Initial residual = 2.12558e-05, Final residual = 2.96012e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 2.46569e-05, Final residual = 2.84806e-07, No Iterations 1 DICPCG: Solving for p, Initial residual = 2.85749e-05, Final residual = 9.04189e-07, No Iterations 9 time step continuity errors : sum local = 9.14192e-09, global = -3.49815e-19, cumulative = 2.91684e-19 DICPCG: Solving for p, Initial residual = 1.07851e-05, Final residual = 9.91138e-07, No Iterations 6 time step continuity errors : sum local = 8.95587e-09, global = -4.25171e-20, cumulative = 2.49167e-19 ExecutionTime = 0.84 s ClockTime = 1 s <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< < THE QUESTIONS ARE: WHY ARE THESE DIFFERENCES?? has this differences happened to someone else??? Is this because of the OpenFoam Version???? Which is the OpenFOAM version used in the icoFoam Tutorial?????? I will appreciate any comment or suggestion !!! ;-) .... Thanks in advance Gaby |
OpenFOAM13 for Mac OSX Darwin 104 | hjasak | OpenFOAM Installation | 70 | September 24, 2010 05:06 |
Help%7e%7einstall openfoam13 on fc5%7e%7e | aderliner | OpenFOAM Installation | 2 | September 11, 2006 07:24 |
Must I unzip the OpenFOAM12linuxGcc4Opt file before I installcompile OpenFOAM12 | andycong | OpenFOAM Installation | 3 | March 9, 2006 07:57 |
1 fetal error in OpenFOAM12 installation | andycong | OpenFOAM Installation | 3 | February 26, 2006 03:09 |
OpenFoam12 on a linux cluster | tsjb00 | OpenFOAM Installation | 5 | September 10, 2005 19:44 |
