A dynamic case for stressedFoam
Old   July 26, 2008, 18:47
Default Hi everyone, I want to test
feng wang
fw407 is on a distinguished road
Hi everyone,
I want to test the dynamic response of "stressedFoam". the test case is very simple:
"a 2D beam is fixed at the left end, and the right end is suddenly applied with vertical force F."
I have tried the boundary conditions named"constanTraction" which applies the sudden load at the specfied time, but it doesn't work(maybe I did not use it correctly, but so far, I haven't figure out why). did anyone do this before? Any hints are welcome.
Kind regards
feng
fw407 is offline   Reply With Quote
Old   July 27, 2008, 00:20
Default Hi ! You should use the tra
Mathieu Olivier
mathieu is on a distinguished road
Hi !
You should use the tractionDisplacement BC for this with an initial displacement field set to zero. Note that the vibration may damp since the time scheme for d2dt2(U) can only be Euler (first order) which produce diffusion. A small time step may help with that issue.
Mathieu
mathieu is offline   Reply With Quote
Old   July 27, 2008, 08:00
Default Hi Mathieu, Many thanks for
feng wang
Hi Mathieu,
Many thanks for your help!
In fact, I have done what you said, and got the curve for the dynamic response, but it quickly converge to the steady state solution. I will try reducing the time step to see whether it works for me.
Kind regards
feng
Dynamic mesh refinement in a 2D or axissymmetric case christian_kunkelmann OpenFOAM Running, Solving & CFD 9 January 19, 2009 13:15
Variable inletoutlet for dynamic mesh mixer2D case soeren OpenFOAM Running, Solving & CFD 0 May 11, 2008 18:22
Dynamic Mesh in an In-cylinder case venkitaraman FLUENT 0 March 26, 2007 18:15
Compare stressedFoam and stressFemFoam in tutorial case plateHole weijing OpenFOAM Running, Solving & CFD 0 April 13, 2006 23:59
Compare stressedFoam and stressFemFoam in tutorial case plateHole weijing OpenFOAM Running, Solving & CFD 0 April 13, 2006 23:51
