Drag and lift force using OpenFoam14
Old   August 4, 2008, 12:08
Default I believe that there will be n
  #21
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I believe that there will be no need to continue using the old liftDrag implementation in new 1.5-based solvers. Since v1.5 can natively compute the dimensionless force coefficients through functionObjects, it would be wise to validate the new approach.
msrinath80 is offline   Reply With Quote
Old   August 4, 2008, 13:31
Default hi srinath can u please tel
  #22
mayank gupta
mgz1985 is on a distinguished road
hi srinath
can u please tell how to follow what u have mentioned in the above post. I am new to Linux and OpenFOAM. And have a decent command in C++.
I am trying to calculate the lift and drag for an airfoil in openfoam but cant find the tool to do so. I hope u can explain in detail what u mean above by this
'Since v1.5 can natively compute the dimensionless force coefficients through functionObjects, it would be wise to validate the new approach.'
Thanks
mgz1985 is offline   Reply With Quote
Old   August 4, 2008, 13:33
Default Hi, Srinath, I am not su
  #23
Ivan Lau
ivanwhlau is on a distinguished road
Hi, Srinath,
I am not sure how to do it through functionObjects.
Would you please give me some directions how to set up to calculate force coefficient?
Ivan
ivanwhlau is offline   Reply With Quote
Old   August 4, 2008, 14:56
Default Hi Ivan and Mayank Please l
  #24
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Ivan and Mayank
Please look into the following thread, which goes through the functionObject for forces.
http://www.cfd-online.com/cgi-bin/Op...how.cgi?1/8402
Further there is a discussion on modifying the output files to ease the plotting procedure, which you might also find interesting.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 4, 2008, 16:00
Default Thanks for the link Niels :-)
  #25
Old   August 4, 2008, 22:32
Default Thanks, Niels
  #26
Ivan Lau
Thanks, Niels
Old   March 21, 2013, 05:17
Malik
malaboss is on a distinguished road
Originally Posted by msrinath80 View Post
Good to know that it compiled without issues. The Drag/Lift computation was primarily done by Frank Bos. Search for his posts in this forum concerning Lift and Drag, you will find many useful threads.
PS: If you need to extract the Lift/Drag coefficients from the log file conveniently, using the foamLog command, you need to add the following 4 lines in your foamLog.db file (which is present in ~/OpenFOAM/OpenFOAM-1.4/bin)
#- Drag coefficient:
dragCoefficient/DragCoefficient = /DragCoefficient =
#- Pressure Drag coefficient:
pressureDragCoefficient/pressureDragCoefficient = /pressureDragCoefficient =
#- Viscous Drag coefficient:
viscDragCoefficient/viscDragCoefficient = /viscDragCoefficient =
#- Lift coefficient:
liftCoefficient/LiftCoefficient = /LiftCoefficient =
Hi all,
I just saw this post and wanted to use it.
You cannot print lift and drag coefficient values like that now, because in the log file they don't appear as "LiftCoeffcient" and "DragCoefficient" anymore.
You need to add :
LiftCoefficient/Cl = /Cl =
DragCoefficient/Cd = /Cd =
at the end of the file /opt/openfoam211/bin/tools/foamLog.db
If you hear me Srinath, thanks a lot !
malaboss is offline   Reply With Quote
accessing lift fore/drag force in UDF changkiang FLUENT 6 May 11, 2015 16:00
how to set lift and drag coefficients in force mon alagesanj FLUENT 0 November 16, 2008 21:47
Drag & lift force Max CFX 1 September 4, 2008 12:41
finding drag and lift force Deloat CFX 3 February 27, 2008 17:53
Lift and Drag force Dmitriy CFX 4 September 18, 2005 02:00
