How To simulate a pulsating flow in OpenFOAM
Old   July 15, 2008, 16:22
Default Hi everyone, I am trying to
feng wang
fw407 is on a distinguished road
Hi everyone,
I am trying to modify icoFoam so that it can simulate a pulsating flow in a straight flexible pipe. the flow velocity at the inlet is uniformly distributed but the velocity magnitude changs with time:
U = U_0 + U_A*sin(wt)
I have noticed the "timeVaryingUniformFixedValueFvPatchField " may be what I want, but it needs to read the data from a data file. Actually I prefer to implement it in the code somthing like:
U.boundaryField()[patchI] == U_0 + U_A * sin (wt)
and read the "w", "U_0" and "U_A" in a dictionary.
So far I haven't got an idea of how to do that, Could anyone give me some hints?
Kind regards
feng
fw407 is offline   Reply With Quote
Old   July 15, 2008, 17:12
Default Hi ! Take a look at the osc
Mathieu Olivier
mathieu is on a distinguished road
Hi !
Take a look at the oscillatingFixedValueFvPatchField, I think it is exactly what you need.
Mathieu
mathieu is offline   Reply With Quote
Old   July 15, 2008, 17:28
Default Hi Feng As a start, assume
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Feng
As a start, assume you know w, U_0 and U_A, then simply do this, which you have already done:
U.boundaryField()[patchI] == U_0 + U_A * sin (wt);
and add the line:
U.correctBoundaryConditions();
It should to the trick.
With respect to be reading from a dictionary, look for instance at
OpenFOAM/OpenFOAM-1.4.1/applications/solvers/DNSandLES/dnsFoam
and search for IOdictionary.
Have fun,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   July 16, 2008, 07:23
Default Hi Mathieu, Thanks for your
feng wang
Hi Mathieu,
Thanks for your help, I really appreciate it. oscillatingFixedValueFvPatchField is working fine with me.
Kind regards
feng
Old   July 16, 2008, 07:27
Default Hi Niels, I really apprecia
feng wang
Hi Niels,
I really appreciate your help. I will try more complex functions with your method.
Kind regards
feng
Old   August 13, 2008, 05:57
Default Hi, I also work on pulsatil
Tobias Holzinger
woody is on a distinguished road
I also work on pulsatile flows. I am especially interested in heat transfer effects, that occur in turbulent problems containing flow reversal.
So far I tried to simulate my very long (l/D=120) channel with a constant wall temperature, pulsating velocity and oscillatory temperature BC at the inlet. I introduced a special turbulence Model (Wang & Zhang: "Numerical analysis of heat transfer in pulsating turbulent flow in a pipe", Heat and Mass Transfer, 2005) containing wallfunctions. As compressible fluids should be considered, the rhoTurbFoam solver seemed to be the best fitting choice.
When run my computations, the temperature cant follow the backflow conditions, and is increased non-physical.
Scanning the tutorials, I found some other remarks, that backflow causes instabilities and some suggestions, which are not commented to have been worked out or taken to be valid.
Is anybody out there who handled similar problems and has some information, hints etc.???
Thanks Tobias
Tobias Holzinger
Chair of Thermodynamics, TU München
woody is offline   Reply With Quote
Old   August 13, 2008, 06:08
Default Sorry, I scanned the forum
Tobias Holzinger
Sorry,
I scanned the forum ... and not the tutorial...
Tobias
Tobias Holzinger
Old   September 28, 2016, 03:27
Default Pulsating Blood Flow in arteries
Viraj Belekar
viraj20feb is on a distinguished road
Greetings,
Can anyone please share the code for proper pulsating blood flow ? I have been trying to do that for a long time.
Thanks a lot
viraj20feb is offline   Reply With Quote
Old   September 28, 2016, 04:15
floquation's Avatar
Kevin van As
floquation will become famous soon enough
Originally Posted by viraj20feb View Post
Greetings,
Can anyone please share the code for proper pulsating blood flow ? I have been trying to do that for a long time. See the example below. (Evidently, the precise BC depend on what effect you like to achieve.)
Thanks a lot
You can achieve what you want using "groovyBC" which comes with swak4foam.
|  \\    /   O peration     | Version:  2.4.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    walls
        type            zeroGradient;
    cycLeft // p~sin(t)
        type            groovyBC;
        patchType       cyclic;
        valueExpression "-2.6780625E-4*(1 + 0.7*sin(2*3.145926*1*time()))";
    cycRight // p=0
        type            groovyBC;
        patchType       cyclic;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 -2E-2);
boundaryField
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    cycLeft
        type            cyclic;
    cycRight
        type            cyclic;
floquation is offline   Reply With Quote
Old   September 29, 2016, 01:51
Viraj Belekar
FoamFile
    version     2.0;
    format      ascii;
    object      p;
boundaryField
    walls
        type            zeroGradient;
    cycLeft // p~sin(t)
        type            groovyBC;
        patchType       cyclic;
    cycRight // p=0
        type            groovyBC;
        patchType       cyclic;
FoamFile
    version     2.0;
    format      ascii;
    object      U;
boundaryField
    walls
        type            fixedValue;
    cycLeft
        type            cyclic;
    cycRight
        type            cyclic;
Hello floqution,
Thanks for your quick reply. Unfortunately, there is some error with this. When I run simulation, I get the following error:
--> FOAM FATAL ERROR:
Attempt to cast type patch to type lduInterface
    From function refCast<To>(From&)
    in file /home/fossee/foam/foam-extend-3.2/src/foam/lnInclude/typeInfo.H at line 114.
FOAM aborting
Aborted (core dumped)
Can you please help?
Old   September 29, 2016, 03:43
floquation's Avatar
Kevin van As
Hello floqution,
FOAM aborting
I do not know what that error means, but I can troubleshoot you.
Reading the error, I anticipate it has to do with what boundary type was set.
  1. OpenFoam version?
  2. What boundaries did you specify in your blockMeshDict? That is, are they cyclic (like required by the code I showed you), or did you set something else?
  3. What solver are you using?
Old   September 29, 2016, 03:51
Viraj Belekar
Hi floquation,
1) I am using foam-extend-3.2
2) I did set it correctly. Please find the attached case directory
3) I am using fsiFoam solver (https://openfoamwiki.net/index.php/E...re_interaction)
Please take a look
Old   September 29, 2016, 05:29
floquation's Avatar
Kevin van As
I am not familiar with your solver, and it might be related to the way it works:
What is pointMotionU?
In 0/pointMotionU you have set "fixedValue" for the otherwise cyclic boundary. I suspect that this might be the source of the error.
Old   September 29, 2016, 06:39
Viraj Belekar
Hey,
This solver is for Fluid Structure Interaction study which I want to implement for blood flow in arteries. I changed the 0/pointMotionU but had to change back the content of the blockMeshDict file(i.e inlet and outlet to type patch, because I was getting a wierd error and blockMesh command was not working).
face 0 area does not match neighbour 1 by 82.5642% -- possible face ordering problem. patch:outlet my area:9.65479e-06 neighbour area:4.0126e-06 matching tolerance:0.001 Mesh face:3 vertices:4((0 0.003414 0.05) (0.002828 0.002828 0.05) (0.003414 0 0.05) (0 0 0.05)) Neighbour face:4 vertices:4((0 0.005 0.05) (0.003536 0.003536 0.05) (0.002828 0.002828 0.05) (0 0.003414 0.05)) Other errors also exist, only the largest is reported. Please rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 293.
Now when I have changed back to the original blockMeshDict file, the earlier error still persists.
Old   September 29, 2016, 08:29
floquation's Avatar
Kevin van As
Hey,
This new error is actually a 'better' error, as it occurs later inside the source code. That is, your change made the first error disappear.
And this error I know: it means that your inlet boundary is not of the same size as your outlet boundary. Therefore, OF cannot match the inlet with the outlet for the cyclic BC.
This may have two causes: (1) you made a mistake in your blockMeshDict, or (2) your inlet and outlet were not intended to be of the same size.
- If the first is the case, carefully inspect your mesh.
- If the second is the case, then perhaps you shouldn't be using cyclic at all? My code above was using cyclic BC, as that was the kind of artery we were interested in. If you do not want to have an "infinite" (=periodic) artery, then you must change my code above to be consistent with your boundary. That basically means still using groovyBC, but changing the patchType from "cyclic" to whatever is appropriate for your case.
Old   October 4, 2016, 09:30
Viraj Belekar
Hi floquation,
I have been trying what was suggested by you but I was not able to make it work. Can you please try it once on your system? Please find my attached test case.
Thanks a lot
Old   October 5, 2016, 04:19
floquation's Avatar
Kevin van As
I'm sorry, but no, I'm not going through the hassle of installing your solver without admin rights.
However, I did look at your blockMesh in ParaView, and it has two problems:
  1. http://cfd.direct/openfoam/user-guide/blockmesh/
    Firstly, you should define your normals outwards (using the right-hand rule), whereas yours are pointing inwards. For example:
        patch outlet
            (7 8 9 10) //(10 9 8 7)
  2. Secondly, you specify your faces in the incorrect order for cyclic to work. All faces must be specified in the same order for both cyclic patches:
        patch outlet
            (10 9 8 7)
            (12 11 8 9) //(13 12 9 10)
            (13 12 9 10) //(12 11 8 9)
        patch inlet
            (0 1 2 3)
            (1 4 5 2)
            (3 2 5 6)
    Which is probably the reason why you got the "area does not match"-error earlier.
Then, you again have to correct your zero directory, cf. my first post. So, put U and pointMotionU back to cyclic (not groovyBC) and leave pressure on groovyBC.
Old   October 5, 2016, 06:22
Viraj Belekar
        patch outlet
        patch outlet
            (10 9 8 7)
        patch inlet
            (0 1 2 3)
            (1 4 5 2)
            (3 2 5 6)
Hi floquation,
Thanks for your quick reply. I tried what you suggested but it didn't work out. Apparently we need to use createPatchDict to set a patchfield as cyclic ( Use of createPatchDict and createPatch ). But when I use it also I get an error, "keyword 'patchInfo' not defined" (PFA).
File Type: gz createPatchDict.tar.gz (565 Bytes, 11 views)
What kind of computer is needed to simulate with OpenFoam anita OpenFOAM Running, Solving & CFD 8 February 21, 2008 12:25
UDF for pulsating flow Bing FLUENT 0 October 7, 2006 12:16
pulsating static pressure around zero at pipe flow David Kim FLUENT 0 May 16, 2006 14:47
Pulsating flow in Fluent Ryan FLUENT 0 December 9, 2005 00:32
pulsating flow Pete Main CFD Forum 2 December 9, 2003 12:39
