Examples of implicitly coupled domains
Old   August 15, 2008, 17:44
Default Hello, I am looking for infor
nadine
I am looking for information how to solve a model with implicitly coupled domains.
For example, a solid heat transfer model in one half, and an incompressible fluid flow model with heat transport in the other half.
I know that the coupling can be done iteratively, but need want to combine the solutions of both domains into a single equation system to improve the solution quality at the contact interface (the heat transfer is only a simplified example).
Does any such example exist, how to combine the equation systems of different domains? The more trivial the better.
NB
Old   August 15, 2008, 19:09
Default I wrote one of those and it i
Hrvoje Jasak
I wrote one of those and it i currently in the SVN for 1.4.1-dev. Have a look at the code in:
http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/applications/solvers/conjugate/conjugateHeatFoam/
The "killer bit" is a build and solution of a block matrix:
coupledFvScalarMatrix TEqns(2);
// Add fluid equation
TEqns.set
0,
new fvScalarMatrix
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
// Add solid equation
TEqns.set
1,
new fvScalarMatrix
fvm::ddt(Tsolid) - fvm::laplacian(DTsolid, Tsolid)
TEqns.solve();
There is a tutorial in:
http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/tutorials/conjugateHeatFoam/
This will all be moved to 1.5-dev soon...
Enjoy,
Hrv
Hrvoje Jasak
Old   August 15, 2008, 19:40
Default That's the perfect example for
nadine
That's the perfect example for our problem :-)
Just to make sure, does the "TEqns.solve()" really solve the coupled system and not some relaxed iteration of the two equations? The latter was shown to creep to convergence in our scenario, so that I don't want to give it a try.
Thank you!
NB
Old   August 15, 2008, 19:53
Default Yes, it REALLY solves the coup
Hrvoje Jasak
Yes, it REALLY solves the coupled system: eacy solver sweep, each vector-matrix multiply are coupled.
Hrv
Hrvoje Jasak
Sub Domains prakash CFX 4 May 22, 2008 11:43
Sub domains? Chris Wetton CFX 1 February 24, 2008 17:47
Two Domains kdarc OpenFOAM Running, Solving & CFD 1 March 13, 2007 12:08
Did openoam implicitly implement Gamma differencing shceme harry OpenFOAM Running, Solving & CFD 2 February 5, 2007 03:11
The terms that should be treated implicitly in LES ben Main CFD Forum 3 January 28, 2005 04:32
