Naca airfoil with too high drag
Like Tree8Likes
Old   January 8, 2016, 09:15
Aleksandr
metaliat93 is on a distinguished road
[QUOTE=maddalena;262440]Hello everybody,
I have the same problem as above: for an airfoil at Re 1.5*10^6, cl matches well with theoretical value, while cd is two times the wanted cd. I am using kOmegaSST as implemented in OF (and not with the lowRe variation), y+ is between 30 and 110 everywhere, with an average value of 70. The fvSchemes is as follows:
This my analysis
https://sites.google.com/site/3didea...ofila-naca0012
If you want I can sent to you my project
metaliat93 is offline   Reply With Quote
Old   October 17, 2017, 11:44
Camilo
yanke is on a distinguished road
Hi Aleksandr,
I'm currently trying to validate the same airfoil without much success. I'll be really grateful if you could please send me your project
Thanks
Camilo
kmy_527@hotmail.com
yanke is offline   Reply With Quote
Old   October 19, 2017, 16:50
sheaker's Avatar
Oskar
sheaker is on a distinguished road
Hello.
Drag coefficient is way too high because kOmegaSST turbulence model assumes that there is turbulent flow around entire airfoil surface. Turbulent viscosity is higher than laminar viscosity and that cause higher drag coefficient.
I wonder it there is someone who could give us a hint? Which turbulence model should we use to get a better drag force? I'm working on compressible case with NACA65(2)-415 laminar airfoil and I'm facing the same problem.
Have a nice day.
Sheaker
PS.
There is no such a turbulence models like those below in my openFoam 2.1.1 but my university professor recommend me:
gamma Re theta
kkl omega
gammaLCTM
I wonder if there is any more suitable turbulence model for airfoil case in openFoam 2.1.1 or openFoam 1.6-ext.
sheaker is offline   Reply With Quote
Old   March 26, 2021, 14:33
Default NACA0012 k-OmegaSST model
  #44
afa13 is on a distinguished road
Hello All,
I am trying to simulate a flow over a NACA0012 airfoil with k-omegaSST(incompressible) at different angles of attack. On the NASA website, the study is done using a low Re(6e6) and a turbulence intensity of 0.052%. I tried first with the turbulence intensity of 0.5% (estimated from this website's tool) used 1 for nut/nu and a velocity of around 80m/s with 10 deg as an angle of attack. For the 0.5% I got a convergence however the values for the drag coefficient were far from the results by NASA; the lift coeffecients were in the range of 7%. However, when i change my boundary conditions based on the 0.052% criteria it doesnt converge and the program stops because I get extremely high values for both Cd and Cl. As for a 0 deg angle of attack, using the values of the 0.052% turbulent intensity to calculate the boundary conditions, the solution converges after 1474 iterations and i get
Cd=0.0071605
Cl=-0.000470603
My mesh is constructed using construct2d by using the dat file from the NASA website then the plot3dtofoam function and a createPatchDict.
Any help is appreciated because I have gone my ways trying to figure this thing out.
 patch walls y+ : min = 6.98209, max = 7.02351, average = 7.02168
The boundary conditions I have are as follows:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.00328535;
boundaryField
    farfield
        type            freestream;
        freestreamValue           $internalField;
    walls
        type            kqRWallFunction;
        value           $internalField;
     frontAndBack
        type            empty;
|  \\    /   O peration     | Version:  v2012                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 1.85e-5;
boundaryField
    farfield
        type            freestream;
        freestreamValue $internalField;//uniform 9.8e-4;
        //value uniform 0.14;
    walls
        type            nutUSpaldingWallFunction;
        value           uniform 0;
     frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      epsilon;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 219;
boundaryField
    farfield
        type             freestream;
    walls
        type            omegaWallFunction;
      frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;
boundaryField
    farfield
        type            freestreamPressure;
    walls
        type            zeroGradient;
    frontAndBack
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (87.64789 15.4546 0);
boundaryField
   farfield
        type            freestreamVelocity;
    walls
        type            noSlip;
    frontAndBack
        type            empty;
The code to calculate the lift and drag coefficients:
forces
    type                forces;
    functionObjectLibs  ("libforces.so");
    outputControl       timeStep;
    outputInterval      1;
    patches             ( "walls" );
    pName               p;
    UName               U;
    rho             rhoInf;
    log                 true;
    CofR                (0.25 0 0);
    rhoInf              1.225;
forceCoeffs
    type                forceCoeffs;
    functionObjectLibs  ( "libforces.so" );
    outputInterval      1;
    pName               p;
    UName               U;
    rho             rhoInf;
    log                 true;
    liftDir             (.1736 0.98481 0);
    dragDir             (0.98481 .1736 0);
    CofR                (0.25 0 0);
    pitchAxis           (0 0 1);
    magUInf             89;
    rhoInf              1.225;
    lRef                1;
    Aref                1;
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    limited         cellLimited Gauss linear 1;
    grad(U)         $limited;
    grad(k)         $limited;
    grad(omega)     $limited;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind unlimited;
    turbulence      bounded Gauss linearUpwind limited;
    div(phi,k)      $turbulence;
    div(phi,omega)  $turbulence;
    div(phi,epsilon) $turbulence;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.001;
        minIter          5;
        maxIter          100;
        smoother         GaussSeidel;
        nPreSweeps       1;
        nPostSweeps      3;
        nFinestSweeps    3;
        scaleCorrection true;
        directSolveCoarsest false;
        cacheAgglomeration on;
        nCellsInCoarsestLevel 50;
        agglomerator     faceAreaPair;
        mergeLevels      1;
    U
        solver           smoothSolver;
        tolerance        1e-8;
        relTol           0.01;
        nSweeps          1;
    k
        tolerance        1e-8;
        relTol           0.01;
        nSweeps          1;
    omega
        tolerance        1e-8;
        relTol           0.01;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        "(k|omega)"     1e-5;
relaxationFactors
    fields
        p               0.3;
    equations
        "(U|k|omega)"   0.7;
        "(U|k|omega)Final" 0.7;
cache
    grad(U);
afa13 is offline   Reply With Quote
Lift and drag coefficient with strange values for NACA airfoil antonio_ing OpenFOAM Running, Solving & CFD 16 September 13, 2012 13:21
NACA 23020 airfoil drag and lift calculation. Zmur CFX 2 December 23, 2008 17:35
Drag prediction for Naca 23012 airfoil Ravel Bogatec CFX 17 February 15, 2008 01:21
Naca airfoil with to much drag Andreas CFX 6 March 17, 2006 07:13
Drag predicion for a NACA 0012 airfoil Peter Giannakopoulos FLUENT 7 March 9, 2004 16:32
