August 15, 2008, 19:04 |
Concerning your wmake question
Concerning your wmake question: the Programmers Guide (or was it the Users Guide?) contains a section about this tool. You find the guides under the Documentation link at the OF homepage.
Basically, you just have to copy the simpleFoam directory from the applications/... sources, apply your changes to simpleFoam.C and within the simpleFoam directory type wmake . Take care, it overrides the standard simpleFoam solver unless you change the name of the output file in simpleFoam/Make/options. NB |
August 18, 2008, 03:39 |
Thanks for the reply. I've alr
Serge Koller
Thanks for the reply. I've already read this section of the usersguide. In the mean while I found my error elsewhere, but i'm getting another error now:
/net/home/campbell/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H: In function 'void runtimecalc(Foam::word, Foam::scalar)': /net/home/campbell/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/createTime.H:6 : error: 'args' was not declared in this scope make: *** [Make/linux64GccDPOpt/runtimecalc.o] Error 1 this variable, what is it used for? Doxygen says something (for me a rather difficult book anyway) that it references Foam::exit and Foam::FatalError. how do I declare it? and why should i in the first place? where is it declared in the simpleFoam.c? I hope my questions are not too silly. Serge |
August 18, 2008, 04:31 |
The main() routine of simpleFo
The main() routine of simpleFoam.C begins with these two lines:
# include "setRootCase.H" # include "createTime.H" And if you have a look into setRootCase.H, you find your args: Foam::argList args(argc, argv); if (!args.checkRootCase()) { Foam::FatalError.exit(); } Have a look at the Doxygen documentation of Foam::argList for details. NB |
August 18, 2008, 05:17 |
Either pass the argc and argv
Either pass the argc and argv from main to runtimecalc and there include setRootCase.H before you include createTime.H
Or, if you have setRootCase.H in your main, the "Foam::argList args" will be available there. Pass it to runtimecalc. NB |
July 2, 2009, 14:06 |
Drag too high
karl
The drag prediction in an airfoil is generally too high for following reason:
A CFD code can't predict the transition from laminar to turbulent regime in the trailing edge. So the code applies turbulent regime in all domain. |
Beginners problem | Zurayk | CFX | 4 | January 11, 2007 10:56 |
A beginners question | Pst | Main CFD Forum | 2 | February 19, 2006 04:33 |
Beginners Question | Aleks | FLUENT | 1 | April 14, 2003 12:09 |
books for beginners | reb | Main CFD Forum | 9 | November 28, 1998 07:54 |
Fluent beginnersīcourse | roland Sabata | Main CFD Forum | 1 | June 25, 1998 09:15 |
