August 20, 2008, 04:35 |
I am interested in m
Ivan Lau
Rep Power: 17 |
I am interested in making kEpsilon with Launder-Kato modification or MMK. Or, K-epsilon-phi model. How can I create my own RASModel? Or, is any of these models above available? I have already copied kEpsilon folder and made changes insides 'src' folder for LK and MMK. But, i am not sure what to do next? I changed turbFoam before. But, changing RASModel is not as straightforward. Please kindly advise. Thanks in advance, Ivan |
August 20, 2008, 09:17 |
Hi Ivan,
If you made changes
Takuya OSHIMA
Rep Power: 20 |
Hi Ivan,
If you made changes under OpenFOAM-1.5/src/turbulenceModels/RAS/incompressible, you usually can add your .C file to Make/files and run wmake libso under the directory. By the way is there any chance that we can share your code? Takuya |
August 21, 2008, 01:51 |
Hi, Takuya,
Thanks for your
Ivan Lau
Rep Power: 17 |
Hi, Takuya,
Thanks for your advice. The code are complied and "working" now, but I am not sure if the result is correct at this moment. In term of sharing, the works are the properties of university. Therefore, I can't post it here. However, do you have those research papers? (Let me if you don't) It is actually quite easy to modify, and it should not take too long. I am more than happy to assist you in regards to this modification. Regards, iL |
August 21, 2008, 04:36 |
Hi Ivan,
Thanks for your kind
Takuya OSHIMA
Rep Power: 20 |
Hi Ivan,
Thanks for your kind offer. That's no problem, I have some literature about them and believe their implementations will not be so difficult. Just I was too lazy to code and validate them by myself Takuya |
Kepsilon modification for swirling flows | flavio_pergolesi | OpenFOAM Running, Solving & CFD | 0 | February 22, 2009 13:37 |
Understanding k from kepsilon | markh83 | OpenFOAM Post-Processing | 3 | December 5, 2008 03:42 |
KEpsilon error | mou_mi | OpenFOAM Running, Solving & CFD | 3 | July 16, 2008 18:25 |
Kepsilon BC and intialization | podallaire | OpenFOAM Running, Solving & CFD | 0 | October 17, 2007 20:29 |
KEpsilon and KOmega | larry | OpenFOAM Running, Solving & CFD | 3 | June 29, 2006 01:38 |
