August 25, 2008, 07:54 |
hi,
i am using OF1.4,I want t
weihong yao
Rep Power: 17 |
hi,
i am using OF1.4,I want to input my inlet velocity,it is not a constant. when i type: setParabolicInlet /home/user/ivann/OpenFOAM/ivan-1.4/run/tutorials/rhoTurbFoam building inlet 0.01 then it show setParabolicInlet: symbol lookup error: setParabolicInlet: undefined symbol: _ZTIN4Foam19lduCoupledInterfaceE what is wrong with it? |
August 25, 2008, 10:05 |
Is this the first application
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Is this the first application you compiled for OpenFOAM?
Because basically it is looking for a symbol that should be in the libOpenFOAM.so. which should be be loaded by default. This seems to be more a system/compilation-problem than a problem specific to that application. Could you give us some more info about your system and how you compiled that app?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 25, 2008, 20:44 |
hi
this is the first applicat
weihong yao
Rep Power: 17 |
hi
this is the first application i compiled for OpenFOAM.i use openSuse10.2 and OF1.4.i don't know how to upload the file,so i can't upload my app file.if you don't mind,drop me a email.Cause i can't get you email address in the forum.my email address is ivan_ywh@yahoo.com.cn |
August 26, 2008, 04:20 |
Uploading a file is easy. Have
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Uploading a file is easy. Have a look at the "Formatting"-link on the left and look for "attach"
Wich version of setParabolicInlet are you using (because there are several floating around on the board - None of them with Make/options, Make/files - where did you get those from?). My guess is thatyour application wasn't linked to libOpenFOAM.so and therefor it can't find that symbol when running Bernhard
August 27, 2008, 22:50 |
hi,
This is a picture of me:
weihong yao
Rep Power: 17 |
hi,
This is a picture of me: ,if the problem is you guess that,what can i do? |
August 27, 2008, 22:52 |
hi,
weihong yao
Rep Power: 17 |
hi,
August 27, 2008, 22:59 |
hi,
i can't upload my zip.fil
weihong yao
Rep Power: 17 |
hi,
i can't upload my zip.file,because it is too big,evan i have zip.if the problem is you guess that,what can i do? |
The setParabolicInlet problem | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 26, 2008 03:11 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
Problem in Tutorial problem of fluent | Phanindra | FLUENT | 5 | April 17, 2007 09:57 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
