September 4, 2008, 08:41 |
Hallo,
I'm trying to simula
Chris
Rep Power: 17 |
Hallo,
I'm trying to simulate multiphase flow in t-junction. Boundary conditions are: inlet1 – water – freestream inlet2 – other liquid (properties similar to water) – freestream outlet – atmosphere channel walls – wall mesh contains about 125000 elements. I have used checkMesh and mesh is OK. Could you please have a look on this piece of convergence history: Starting time loop Courant Number mean: 8.22783e-05 max: 0.023297 Time = 0.00507 MULES: Solving for gamma Liquid phase volume fraction = 9.07245e-05 Min(gamma) = -2.57618e-82 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 9.11763e-05 Min(gamma) = -2.57553e-82 Max(gamma) = 1 DICPCG: Solving for pd, Initial residual = 0.00924923, Final residual = 0.00085711, No Iterations 1001 time step continuity errors : sum local = 1.49501e-09, global = 6.28848e-11, cumulative = -7.2917e-07 ExecutionTime = 7378.93 s ClockTime = 7413 s Courant Number mean: 8.21685e-05 max: 0.0232836 Time = 0.00508 MULES: Solving for gamma Liquid phase volume fraction = 9.16281e-05 Min(gamma) = -2.57488e-82 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 9.20799e-05 Min(gamma) = -2.57423e-82 Max(gamma) = 1 DICPCG: Solving for pd, Initial residual = 0.0062962, Final residual = 0.000132535, No Iterations 1001 time step continuity errors : sum local = 2.3038e-10, global = -3.58816e-12, cumulative = -7.29174e-07 ExecutionTime = 7395.18 s ClockTime = 7429 s I can't understand why from the very beginning it makes 1000 iterations about pressure equation within each timestep. Thought it's a matter of timestep so I've switched on adjustment. After that courrant number was oscillated about 0.5 but number of pressure iterations hasn't changed. I've red on this forum that wrong boundary conditions might be a reason of such big number of iterations. I've checked different boundary settings and used GAMG solver but nothing has changed. As long as I'm obtaining reasonable results it doesn't bother me very much but I would like to speed up my simulation. Now, after 24hours simulation has passed 0.8s of total time. total time is 30s so it looks that I need to wait about month until it's finished Do you have any suggestions. thank you for help in advance!!! Chris |
Transient interFoam with MRF | jaswi | OpenFOAM Running, Solving & CFD | 18 | October 21, 2011 00:29 |
Outlet bc in interFoam | happysimulant | OpenFOAM Running, Solving & CFD | 0 | November 6, 2008 11:06 |
InterFoam | floooo | OpenFOAM Running, Solving & CFD | 0 | November 3, 2008 12:00 |
Pressure in interfoam | qiu | OpenFOAM Running, Solving & CFD | 0 | May 11, 2007 00:17 |
About interfoam solver | qiu | OpenFOAM Running, Solving & CFD | 0 | May 6, 2007 23:48 |
