Equation of state
Old   June 12, 2008, 10:35
Default Hello We want to use buoyan
stijn vantieghem
stvtiegh is on a distinguished road
Hello
We want to use buoyantFoam but with a non-ideal gas. We tried to change the relationship between rho, T and p in perfectGasI.H, but compilation in 'specie' failed with the following output
/usr/lib/crt1.o: In function '_start':
(.text+0x18): undefined reference to 'main'
collect2: ld returned 1 exit status
In fact, it's not completely clear to me what to compile after changing the equation of state. Can someone give some more information about this?
Thx and regards
Stijn
stvtiegh is offline   Reply With Quote
Old   June 12, 2008, 11:35
Default Hello Stijn, If you change
David Palko
dpalko is on a distinguished road
Hello Stijn,
If you change only the equation of state, recompile src/thermophysicalModels/specie directory. Maybe you will need also to recompile src/thermophysicalModels/basic directory.
Error which you get comes probably, because you run "wmake" command. Then you of course should have main function. thermophysicalModels is a library, so you should use "wmake libso" command in order to compile library.
Good luck,
David
dpalko is offline   Reply With Quote
Old   June 12, 2008, 11:41
Default one more thing, I wouldn't ch
David Palko
one more thing,
I wouldn't change the perfectGas class. Instead i would make a new class (use perferctGas as a template). Then there are some more things to do, so if you decide to go this way, let me know, i did it before so i can try to help you.
Otherwise you can of course change the function rho() in perfectGas (which is the simpiest way), but then the beauty of OOP unfortunately dissapears.
Good luck,
David
Old   September 12, 2008, 07:24
Default David, I tried to create n
Maxim Loginov
zeliboba is on a distinguished road
David,
I tried to create new EoS from perfectGas, but it seems solver does not use new, but perfectGas. could you please take a look at my package on
http://www.cfd-online.com/OpenFOAM_D...es/1/5316.html
or maybe you can post your working case?
thanks
Maxim
zeliboba is offline   Reply With Quote
Equation of state Ali FLUENT 7 February 20, 2010 09:02
gas-state-equation? abel FLUENT 0 May 6, 2006 07:08
Equation of state Edward Main CFD Forum 0 September 18, 2005 18:17
Equation of State for Water Alexey Main CFD Forum 2 July 7, 2005 04:25
the state equation lsm Main CFD Forum 1 March 4, 2005 11:05
