Issue with SimpleFoam with Sharp corners
Old   September 3, 2008, 18:48
Default I have been trying to run a no
kshitij neroorkar
kdneroorkar is on a distinguished road
I have been trying to run a nozzle test case using simpleFoam with FixedValue pressure at inlet and outlet boundaries and zeroGradient velocity at both boundaries. I am getting a strange acceleration zone at the exit of the nozzle due to a very high pressure cell.
I know that a better boundary condition is an outlet pressure and an inlet velocity condition but I donot have this information for this case. Could someone please tell me if I am applying some inconsistent boundary condition or does simpleFoam have a problem with sharp corners.
I am attaching my case folder below for anyne who wishes to run it
kdneroorkar is offline   Reply With Quote
Old   September 4, 2008, 10:37
Default sorry here is the image http:/
kshitij neroorkar
the test case is too big to post on the board so if someone wants to see the case I can email it to them.
Old   September 10, 2008, 16:24
Default Kshitij, Interesting proble
David P. Schmidt
schmidt_d is on a distinguished road
Kshitij,
Interesting problem. It might help to list your email address:
Kshitij Neroorkar <kneroork@engin.umass.edu>
-David
schmidt_d is offline   Reply With Quote
Old   September 10, 2008, 17:56
Default Kshitij Neroorkar: Is this a l
louisgag's Avatar
Louis Gagnon
louisgag is on a distinguished road
Send a message via ICQ to louisgag
Kshitij Neroorkar: Is this a laminar simulation? Otherwise, what turbulence model are you using?
regards
louisgag is offline   Reply With Quote
Old   September 10, 2008, 18:06
Default it is laminar
kshitij neroorkar
it is laminar
Old   September 12, 2008, 20:01
Default maybe if you try the same prob
louisgag's Avatar
Louis Gagnon
maybe if you try the same problem with a coarser or finer mesh your results will improve
Old   September 14, 2008, 14:54
Default I would first run checkMesh an
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
I would first run checkMesh and ensure that your mesh passes all checks.
msrinath80 is offline   Reply With Quote
Old   September 15, 2008, 11:05
Default i ran checkMesh and the mesh d
kshitij neroorkar
i ran checkMesh and the mesh did pass all tests.
Also, the mesh is pretty fine with 140,000 cells
Old   September 15, 2008, 14:56
Default Is this some kind of axisymmet
Is this some kind of axisymmetric case? Can you go to www.rapidshare.com and upload your file there and paste the download link (that it gives you) here. The case might help give a better idea on what could be wrong.
Old   September 15, 2008, 15:09
Default here is the link http://rap
kshitij neroorkar
here is the link
http://rapidshare.com/files/14553772...le.tar.gz.html
Old   September 15, 2008, 17:44
Default I just checked your mesh and c
  #11
I just checked your mesh and case setup. I could not identify any obvious errors. However, your log snippet worries me a lot.
Listed below are the snippets for time step continuity errors at the 1st, 10th, 20th and 100th, 500th, 2000th and 4000th iteration. Your cumulative error does not look good, neither does the 'sum local'.
time step continuity errors : sum local = 1.02549, global = -0.0188398, cumulative = -0.0188398
time step continuity errors : sum local = 0.0699843, global = -0.000584316, cumulative = 0.0335601
time step continuity errors : sum local = 0.00333286, global = 0.000201054, cumulative = 0.0354029
time step continuity errors : sum local = 0.000304726, global = -3.63236e-06, cumulative = 0.0340224
time step continuity errors : sum local = 0.000303121, global = 3.93966e-06, cumulative = 0.0318931
time step continuity errors : sum local = 0.000308258, global = -1.41759e-05, cumulative = 0.0297984
time step continuity errors : sum local = 0.00030529, global = 1.66529e-05, cumulative = 0.0286185
I recommend going over the first few posts of this thread[1] to clarify what each error term means.
Things you may want to try:
1. Increase the number of non-orthogonal correctors (at least 1 corrector to start with).
2. Like Hrv recommends in that other[1] post, converge the pressure more tightly (at least in the beginning). Set the tolerance in fvSolution to (say) 1e-08 instead of 1e-06.
I am no expert in CFD, so you may want to recheck your Boundary conditions as well.
References:
[1] http://www.cfd-online.com/OpenFOAM_D...es/1/1671.html
Old   September 15, 2008, 18:06
Default Oh, and one more thing. You ca
  #12
Oh, and one more thing. You can always use icoFoam to run your laminar simpleFoam problem in a transient manner. The transient simulation should converge to steady state if the problem is indeed steady. I recommend maintaining a Max. Courant number of at most 0.75 even if you are not interested in resolving any transient behavior.
Old   September 15, 2008, 18:57
Default Hi Srinath I have tried to ru
  #13
kshitij neroorkar
Hi Srinath
I have tried to run icoFoam using the same boundary conditions and i got a very similar result. In this case the continuity errors look alright. I am just pasting the last few time step continuity errors below
time step continuity errors : sum local = 3.42216e-13, global = -1.07768e-14, cumulative = 8.9745e-10
time step continuity errors : sum local = 4.29076e-12, global = -8.72646e-15, cumulative = 8.97432e-10
time step continuity errors : sum local = 3.58808e-13, global = -8.47658e-15, cumulative = 8.97417e-10
this was using 2 non-orthogonal correctors.
Thanks a lot for your help
Kshitij
Old   September 15, 2008, 19:12
Default How many time steps did you ru
  #14
How many time steps did you run and what was your Max. Co? Try plotting the time variation of velocity or pressure at a particular point in the domain to see if the variable has indeed converged. See the oodles/pitzDaily tutorial to see how to add probes to your simulation.
Courant no%23 and sharp corner in 3D jam OpenFOAM Running, Solving & CFD 6 November 18, 2008 09:21
Avoiding Skew in Tight Corners Marc FLUENT 4 July 23, 2007 16:21
Flow near sharp corners Harish Main CFD Forum 4 February 21, 2007 22:55
How to treat the 2D corners when using NSCBC? leaf Main CFD Forum 0 May 26, 2006 05:12
why the zones gets split at sharp corners/bends Laxminarayana FLUENT 0 February 16, 2005 03:13
