Implicit solver for gamma volumefraction equation |
July 8, 2009, 04:35 |
#21 |
isabel
Rep Power: 17 |
I only have advisors this week. I am at a OpenFOAM course, which finishes on Friday.
fv::gaussConvectionScheme<scalar>(mesh, phi, UDs).fvmDiv(phi, psi), This line is to calculate div(phi, psi). The begining is only to specify to the program how to calculate it. And the div(U) is repeated. |
July 8, 2009, 05:36 |
#22 |
Sandy Lee
Rep Power: 18 |
Wow, it is great. Thank you very much.
By the way, what a OF course are you studying? Do you have some documents or websites to share? Sandy sandy.lee37@gmail.com |
November 5, 2009, 04:31 |
#23 |
J. Cai
Rep Power: 17 |
Hi, everybody, I am trying to use the interPhaseChangeFoam in OpenFOAM-1.6, and just meet the same problem how to set MULES::implicit in the fvSolution file. Any suggestions are appreciated.
Best regards, Chiven |
November 5, 2009, 19:48 |
#24 |
Sandy Lee
Rep Power: 18 |
Hi Chiven, is there the tutorial about InterPhaseChangeFoam in OF-1.6? I use the OF-1.5.
------------------------------------- gamma MULESImplicit { maxIter 1000; nLimiterIter 10; maxUnboundedness 1; CoCoeff 0.2; solver PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; }; }; |
November 5, 2009, 20:23 |
#25 | |
J. Cai
Rep Power: 17 |
Hi, Sandy, thanks for your reply.
I have justed used the similar setting like yours, but failed. At this time, I have NOT run the interPhaseChangeFoam successfully in OpenFOAM-1.6. Code:
alpha1 { MULESImplicit { maxIter 1000; nLimiterIter 10; maxUnboundedness 1; CoCoeff 0.2; solver PBiCG { preconditioner DILU; tolerance 1e-10; relTol 0; } } } Chiven Quote:
March 29, 2010, 14:20 |
#26 |
Suresh kumar Kannan
Rep Power: 17 |
Hello
I am planning to modify the interfoam solver of OF-1.6.x with the implcitMULES and use an LES simulation. I am studying the breakup of 2D liquid sheets. I have already run some simulations in which i see that the solution is very much dependent in the CFL number I want to know th experience of other interFOAM users who have used an implicitMULES. Do you really find a difference in the solution of two explicitMULES and implicitMULES. And if yes what was the improvement. Is it advicable to give the implicitMULES a try. Will it allow me to use higher CFL numbers. bye with regards K.Suresh kumar |
April 8, 2010, 06:08 |
#27 |
Suresh kumar Kannan
Rep Power: 17 |
Hello interFoam and interphasechange users,
I implemented the implicit::MULES in interFoam in OF-1.6.x . Thanks to Niels and pbohorquez.and ran it with the LES model on some preliminary test cases. I can already see that the results are much better than the explicit::MULES case. So i have decided to further look into the implicit::MULES solver. I already read the posts in this discussion. That gave me a good idea about the form of the equation that is being solved in the two cases. But I would like to know more about the discretization of the transport equation when i am using an implicit::MULES, because i really dont get anything about the parameters that i specify in the fvSolution gamma PBiCG { MULESImplicit { maxIter 1000; nLimiterIter 10; maxUnboundedness 1; CoCoeff 0.2; } preconditioner DILU; tolerance 1e-06; relTol 0; }; so it would be very useful to me if anybody gives some explanation about the discretization in the case of MULES implicit. with regards K.Suresh kumar |
July 14, 2010, 13:25 |
#28 |
Nima Samkhaniani
Rep Power: 25 |
hi friend
the correct form of alpha fvSolution is like below : alpha1 MULESImplicit { maxIter 1000; nLimiterIter 10; maxUnboundedness 1; CoCoeff 0.2; solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; }; |
June 17, 2011, 17:18 |
#29 | |
In order to strictly restrict alpha in [0,0.52], I am now considering to use MULES in case of bubbly flow. I have a question here since in Weller's scheme, there is a compression term (eqn 4.13, Rusche). And it is said "The artificial term is only active in the thin interface region because of the multiplication term gamma(1-gamma)". It is true in case of liquid-vapor with clear interface which only exists somewhere. However in bubbly flow, the interface could be everywhere. I dont know if it is appropriate to use this scheme in my case. Thanks. // Kai |
June 27, 2011, 21:11 |
#30 |
Sandy Lee
Rep Power: 18 |
You can try them, respectively. I guess, there are not differences in results but in the performance of convergence ...
July 14, 2011, 05:08 |
#31 |
Pablo
Rep Power: 17 |
Hello Suresh,
What are the steps to update interfoam from mules::explicit to mules::implicit?? Advanced thanks, Pablo |
July 14, 2011, 06:01 |
#32 |
Anton Kidess
Rep Power: 30 |
Pablo, simply replace the call to MULES::explicitSolve in alphaEqn.H to MULES::implicitSolve and recompile. You will need some extra entries in the fvSolution file as shown in a post earlier in this thread, and that's it.
July 14, 2011, 13:47 |
#33 |
Pablo
Rep Power: 17 |
Thanks Anton,
It is working, i copied from interphase tutorial; alpha1 { maxUnboundedness 1e-5; CoCoeff 2; maxIter 5; nLimiterIter 2; solver PBiCG; preconditioner DILU; tolerance 1e-12; relTol 0.1; }; but what mean cocoeff,maxiter and nlimiter?? |
March 27, 2012, 23:11 |
report
#34 |
Ehsan
Rep Power: 17 |
Hello all
Could any one share this file with me: OpenCFD, OpenCFD Technical report no. TR/HGW/02 (unpublished); 2005 Regards |
June 25, 2012, 22:41 |
#35 | |
NieYongguang
Rep Power: 16 |
So, can you give me some suggestion? |
June 25, 2012, 23:16 |
#36 |
Sandy Lee
Rep Power: 18 |
Hi, why you not read some papers by Dr. Lu Naixian and deduce those equations?
March 27, 2014, 13:02 |
#37 |
Emeline Noel
Rep Power: 12 |
I think, it is not as trivial as you suggest in a not very friendly way. In addition, it is link to a query often ask in this forum and As far as I have searched I did not find an answer. If someone have any interrest on this, in can give some suggestion. Bye |
November 7, 2014, 18:20 |
#38 | |
Cong Gu
Rep Power: 13 |
I'm also confused. Have you been successful in finding why the volumetric source is formulated with this coefficient? It is the same as rho_mixture / (rho_1 * rho_2). |
July 11, 2015, 05:59 |
#39 | |
Przemek
Rep Power: 16 |
You can find an answer in Jibran Heider master thesis in chapter 2.1 http://www.cimne.com/cvdata/cntr2/sp...branHaider.pdf
best regards pblasiak |
Euler Equation Implicit Upwind Schemes | felixrieper | OpenFOAM Running, Solving & CFD | 1 | February 9, 2014 01:58 |
FEM pressure poisson equation (Implicit) | cfd-beginner | Main CFD Forum | 0 | August 9, 2005 14:32 |
Compressive term in gamma equation | Ali (Ali) | OpenFOAM Running, Solving & CFD | 0 | February 17, 2005 18:19 |
Implicit equation solving | Dr B.M. Smith (Smith) | OpenFOAM Running, Solving & CFD | 2 | December 10, 2004 06:36 |
implicit solver | john | Siemens | 1 | November 11, 2003 09:55 |
