Which solver
Old   September 19, 2008, 05:25
Default Hi, everyone, I would like
Vivien
sunnysun is on a distinguished road
Hi, everyone,
I would like to simulate newtonian,unsteady flow in an asymmetric pipe, could you please give me some ideas which solver I should use? (Now I am thinking of using simpleFoam or turbFoam)
Thanks!!
sunny
sunnysun is offline   Reply With Quote
Old   September 19, 2008, 06:02
Default Turbulent or laminar? simpleFo
Gavin Tabor
grtabor is on a distinguished road
Turbulent or laminar? simpleFoam is a steady-state code, so that would not be appropriate. If your flow is laminar, use icoFoam or turbFoam with the laminar turbulence model switched on. If it is turbulent, use turbFoam.
Gavin
grtabor is offline   Reply With Quote
Old   September 19, 2008, 06:35
Default Hi, thanks Gavin, my mesh geom
Vivien
Hi, thanks Gavin, my mesh geometry is a straight pipe with a sudden expansion in the middle,which measn the flow is lamina before it goes into expansion, in this case, which solver would be more suitable?
Many thanks!
Sunny
Old   September 19, 2008, 08:25
Default Hi sunny, In fact, I think
Cedric DUPRAT
cedric_duprat is on a distinguished road
Hi sunny,
In fact, I think the question is not about your geometry, a very complex one can be laminar and a simple channel can be turbulent. The main point is the Reynolds number which caracterise your flow motion.
Then, the question is what you want to do with your calculation. A mensioned by Gavin, a steady calculation can be enought but some time a unsteady one is better. so what is the physics you need to take into account ?
When you will have an answer of all these questions, it'll be easier to find the solver you will need to use or the solver you will need do make.
hope it helps
Cedric
cedric_duprat is offline   Reply With Quote
Old   September 19, 2008, 12:04
Default Hi, Cedric, Thanks fou your r
Vivien
Hi, Cedric,
Thanks fou your reply.
The Reynolds number shows the flow is laminar. What I would like to see is the velocity field and wall shear stress in the expanded section. By the way, may I know how to switch on laminar turbulence model as mentioned by Gavin?
Sorry for this simple question...
Thanks!!
Sunny
Old   September 19, 2008, 12:51
Default There should be a turbulencePr
Gavin Tabor
There should be a turbulenceProperties dictionary in the constant directory; change the switch RASModel to "laminar". Alternatively, I think switching turbulence to "off" works as well.
Gavin
Old   September 22, 2008, 06:10
Default Hi, Gavin, Sorry but I coul
Vivien
Hi, Gavin,
Sorry but I could not find the 'RASModel', so I copied the content of turbulenceProperties dictionary in constant directory of turbFoam. If I switch the turbulence to'off', should it generate the same result as icoFoam? Many thanks!
Sunny
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object turbulenceProperties;
turbulenceModel kEpsilon;
turbulence on;
laminarCoeffs
kEpsilonCoeffs
Cmu Cmu [0 0 0 0 0 0 0] 0.09;
C1 C1 [0 0 0 0 0 0 0] 1.44;
C2 C2 [0 0 0 0 0 0 0] 1.92;
alphaEps alphaEps [0 0 0 0 0 0 0] 0.76923;
RNGkEpsilonCoeffs
Cmu Cmu [0 0 0 0 0 0 0] 0.0845;
C1 C1 [0 0 0 0 0 0 0] 1.42;
C2 C2 [0 0 0 0 0 0 0] 1.68;
alphak alphaK [0 0 0 0 0 0 0] 1.39;
alphaEps alphaEps [0 0 0 0 0 0 0] 1.39;
eta0 eta0 [0 0 0 0 0 0 0] 4.38;
beta beta [0 0 0 0 0 0 0] 0.012;
kOmegaSSTCoeffs
alphaK1 alphaK1 [0 0 0 0 0 0 0] 0.85034;
alphaK2 alphaK1 [0 0 0 0 0 0 0] 1.0;
alphaOmega1 alphaOmega1 [0 0 0 0 0 0 0] 0.5;
alphaOmega2 alphaOmega2 [0 0 0 0 0 0 0] 0.85616;
gamma1 gamma1 [0 0 0 0 0 0 0] 0.5532;
gamma2 gamma2 [0 0 0 0 0 0 0] 0.4403;
beta1 beta1 [0 0 0 0 0 0 0] 0.0750;
beta2 beta2 [0 0 0 0 0 0 0] 0.0828;
betaStar betaStar [0 0 0 0 0 0 0] 0.09;
a1 a1 [0 0 0 0 0 0 0] 0.31;
c1 c1 [0 0 0 0 0 0 0] 10;
NonlinearKEShihCoeffs
alphak alphak [0 0 0 0 0 0 0] 1;
alphaEps alphaEps [0 0 0 0 0 0 0] 0.76932;
A1 A1 [0 0 0 0 0 0 0] 1.25;
A2 A2 [0 0 0 0 0 0 0] 1000;
Ctau1 Ctau1 [0 0 0 0 0 0 0] -4;
Ctau2 Ctau2 [0 0 0 0 0 0 0] 13;
Ctau3 Ctau3 [0 0 0 0 0 0 0] -2;
alphaKsi alphaKsi [0 0 0 0 0 0 0] 0.9;
LienCubicKECoeffs
QZetaCoeffs
alphaZeta alphaZeta [0 0 0 0 0 0 0] 0.76923;
anisotropic no;
LaunderSharmaKECoeffs
LamBremhorstKECoeffs
LienCubicKELowReCoeffs
Am Am [0 0 0 0 0 0 0] 0.016;
Aepsilon Aepsilon [0 0 0 0 0 0 0] 0.263;
Amu Amu [0 0 0 0 0 0 0] 0.00222;
LienLeschzinerLowReCoeffs
LRRCoeffs
Clrr1 Clrr1 [0 0 0 0 0 0 0] 1.8;
Clrr2 Clrr2 [0 0 0 0 0 0 0] 0.6;
Cs Cs [0 0 0 0 0 0 0] 0.25;
Ceps Ceps [0 0 0 0 0 0 0] 0.15;
LaunderGibsonRSTMCoeffs
Clg1 Clg1 [0 0 0 0 0 0 0] 1.8;
Clg2 Clg2 [0 0 0 0 0 0 0] 0.6;
C1Ref C1Ref [0 0 0 0 0 0 0] 0.5;
C2Ref C2Ref [0 0 0 0 0 0 0] 0.3;
alphaR alphaR [0 0 0 0 0 0 0] 1.22;
SpalartAllmarasCoeffs
alphaNut alphaNut [0 0 0 0 0 0 0] 1.5;
Cb1 Cb1 [0 0 0 0 0 0 0] 0.1355;
Cb2 Cb2 [0 0 0 0 0 0 0] 0.622;
Cw2 Cw2 [0 0 0 0 0 0 0] 0.3;
Cw3 Cw3 [0 0 0 0 0 0 0] 2;
Cv1 Cv1 [0 0 0 0 0 0 0] 7.1;
Cv2 Cv2 [0 0 0 0 0 0 0] 5.0;
wallFunctionCoeffs
kappa kappa [0 0 0 0 0 0 0] 0.4187;
E E [0 0 0 0 0 0 0] 9;
Old   September 22, 2008, 08:09
Default Hi Sunny, Change the entry
Gavin Tabor
Hi Sunny,
Change the entry
to
turbulenceModel laminar;
Or switch "turbulence" to "off". I think turbulenceModel became RASModel in OF1.5 (I'm still using 1.4.1 myself, so its getting a bit confusing having to check what is what!)
Gavin
Old   September 22, 2008, 09:21
Default Hi, Gavin, Thanks a lot!
Vivien
Hi, Gavin,
Thanks a lot!
I am also using OF1.4.1.
I am still a bit confused~ If I switch the turbulence to'off',or change turbulenceModel kEpsilon to turbulenceModel lamina, should it generate the same result as icoFoam, or what can be the difference?
Thanks!
Sunny
segregated solver vrs coupled solver sm FLUENT 0 November 6, 2007 02:24
How to do it if i change the seregated finitevolume solver to segregated finiteelement solver dandes OpenFOAM Pre-Processing 0 March 22, 2006 22:06
AGM-SOLVER MANOJ FLUENT 5 August 1, 2005 05:49
solver fuf FLUENT 0 June 19, 2003 14:54
coupled solver / uncoupled solver Jaan Unger Main CFD Forum 0 September 3, 2002 09:30
