September 22, 2008, 05:01 |
Hi David,
i tried to get the
#21 |
Franz
Rep Power: 17 |
Hi David,
i tried to get the GGI to run in OF-1.5 too, but i have not changed anything at the source code in the GGI. So it would be nice to know what you have changed to make it compile against OF-1.5 ? Because I use it very intensivly for rotor-stator interfaces, which can be used to calculate only a part of the cascade which avoids high memory cosumption compared to full cascade calculations. Best regards Franz |
September 22, 2008, 10:52 |
Hi Franz
You will find my l
#22 |
David Hora
Rep Power: 17 |
Hi Franz
You will find my lib here: http://www.cfd-online.com/OpenFOAM_D...tml?1222094745 Let me know if you find a solution ;-) Regards david |
Parallel Processing | pipe | FLUENT | 0 | December 22, 2008 10:34 |
FSI and parallel processing | Jorn | CFX | 5 | June 8, 2007 15:53 |
Parallel processing and FSI | guus_kupers | OpenFOAM Running, Solving & CFD | 0 | March 20, 2007 09:40 |
Parallel Processing | Drew Abbott | FLUENT | 2 | August 29, 2006 12:35 |
Parallel processing | Phil | FLUENT | 1 | May 27, 2004 07:18 |
