Manipulation of cellvalue of a geometricField
Old   September 25, 2008, 10:39
Default Hi to everybody! I'm trying t
Ivan Flaminio Cozza
ivan_cozza is on a distinguished road
Send a message via MSN to ivan_cozza
Hi to everybody!
I'm trying to write a postprocessing utility that modify cell-by-cell the values of a volVectorField, like this:
forAll(ut,celli)
...operations...
ut[celli] += 2.0*ampU*cos(xdotk + phi)*sig;
where ampU, xdotk and phi are dimensionedScalar and sig a dimensionedVector.
When I compile it, wmake told me that it's wrong.
Maybe it's because ut[celli] is not the correct way to access to the cell-value of a volVectorField?
Please, help me!!!
ivan_cozza is offline   Reply With Quote
Old   September 25, 2008, 14:20
Default I don't think that wmake had a
Assistant Moderator
Bernhard Gschaider
I don't think that wmake had a problem. It probably was the compiler. But that's nitpicking.
The problem is that the result on the right hand side is a dimensionedVector while the cell value is a plain vector. So you'll have to use the value() method to get the vector out of the dimensionedVector
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   September 25, 2008, 14:58
Default Thanks Bernhard, now it works.
Ivan Flaminio Cozza
Thanks Bernhard, now it works. I'm new in OF and C++, so I'm still having difficulties in thinking in terms of classes and methods, my Fortran background makes me think in terms of vectors and functions!
I really need a paradigm-shift!!!
How to convert from GeometricField to fvMatrix waynezw0618 OpenFOAM Running, Solving & CFD 2 January 8, 2021 17:35
Create GeometricField without IOobject nadine OpenFOAM Running, Solving & CFD 3 August 15, 2008 10:24
Duplicate GeometricField reimund OpenFOAM Running, Solving & CFD 9 June 9, 2008 14:47
Accessing data of geometricField bird OpenFOAM Running, Solving & CFD 1 August 28, 2007 19:21
Table Manipulation furkan Siemens 0 April 4, 2006 11:23
