Fluid Structure Interaction using icoFsiFoam Problems
Like Tree3Likes
Old   March 24, 2010, 04:42
Wolfgang W.
WiWo is on a distinguished road
Hi Matteo and Jaas,
How did things work out with your strong FSI solvers? I'm a little bit stuck at the moment. The problem seems to be related to the "moving timestep continuity error" which is blowing up sooner or later. I have not yet found a way to keep that under control.
How did you go about implementing the strong FSI at densities of fluid/solid being very close to each other?
I would be grateful for hints as I'm uncertain about where to search for the cause of my problem.
Cheers,
Wolfgang
WiWo is offline   Reply With Quote
Old   March 24, 2010, 18:06
Johannes Baumann
johannes is on a distinguished road
Hi Wolfgang,
I've been following this and other topics about icoFsiFoam for a while and recently started working with this solver, too.
At the moment I'm at the process of validating icoFsiFoam on the 2006 benchmark of Turek and Hron [1]. It's a 2D geometry with a submerged cylinder with a flexible beam attached which gets deformed by the vortex separation at the cylinder.
The density ratio is always set to 1, so depending on inlet velocities and structural properties Turek and Hron proposed "easy" as well as "hard" versions of the same case. I think it could be a suitable test case since you can easily control the FSI difficulty and the geometry is simple and 'blockMeshable', just have a look at the details (paper | slides).
I'm still at the beginning of my evaluation but I can already say that first results are quite promising despite the fact I'm using an unmodified icoFsiFoam (just added stress and displacement components output).
I noticed that the solution has a noticable dependance on solid mesh size which prevents me from getting any closer than about 10% to the published displacement results at least on the "hard" case. I could not yet figure out what's the reason, so I'll have to run additional tests on that issue.
It would we great if we could collect all of the existing additions and modifications of icoFsiFoam currently floating around at a central place (maybe the wiki?) so that they could be compared, combined and improved. At least it would make things easier for users like me who would like to start modifying icoFsiFoam.
Best regards,
Johannes
[1] Turek, S.; Hron, J.: Proposal for numerical benchmarking of fluid-structure interaction between an elastic object and laminar incompressible flow, Bungartz, H. J.; Schäfer, M., Lecture Notes in Computational Science and Engineering, 53, 371--385, Fluid-Structure Interaction - Modelling, Simulation, Optimization, Springer, ISBN 3-540-34595-7, 2006
elvis likes this.
johannes is offline   Reply With Quote
Old   March 29, 2010, 09:33
Wolfgang W.
Hi Johannes,
Thanks for pointing out the paper - it's a quite interesting read!
It's a great idea to collect the different modifications of icoFsiFoam circulating at the moment. Probably someone with some experience in the field would even be able to merge them to a pretty powerful new FSI solver. I suppose it would be of great value for many OpenFOAM programmers.
You should publicize this idea to a larger audience and see if people are interested - I most definitely am interested :-)
Cheers,
Wolfgang
Old   April 18, 2010, 12:15
Default icoFsiFoam foa a 3D case
  #44
Aldo Iannetti
aldo.iannetti is on a distinguished road
Hi foamers,
Can you help me setting up a icoFsiFoam for a 3D case?
I know it uses stressedFoam as the structural solver but it's been used only for a 2D case I haven't found any 3D tutorial about that.
Is there somebody ho has just make it?
thanks
Aldo
aldo.iannetti is offline   Reply With Quote
Old   April 18, 2010, 13:24
Elvis
elvis will become famous soon enough
Originally Posted by aldo.iannetti View Post
Hi foamers,
thanks
Aldo
Even the 2D cases are "real 3D cases" but with a thickness of "1".
Do not forget =>OpenFOAM uses always 3D cases!
goto
http://www.tfd.chalmers.se/~hani/kurser/OS_CFD_2009/ and search for fsi
or the stuff by Karl Jacob Maus:
Weakly coupled fluid-structure interaction
Solvers for weakly coupled fluid-structure interaction problems are built by combining existing solvers and methods for mesh-movement in a generic way. Test-cases are set up for a variety of problems to be solved.
Report, Presentation, Code, Cases
So learn to use some of the preprocesseing tools other than blockmesh.
Maybe http://www.discretizer.org/ or netgen or gmsh or engrid salome
i remember that somewere @
http://www.dhcae.de/ there is the bambreak in a more complex "city" exampleas a presentation
greetings
elvis
elvis is offline   Reply With Quote
Old   April 18, 2010, 14:26
Default what's going wrong?
  #46
Aldo Iannetti
So I guess it's my fault,
I set up a 3D icoFsiFoam case of a pipe deforming under the pressure load of the fluid passing through (it is close to the 'arteria' case in http://www.dhcae.de/ ) . It is a transient case but I have no convergence, can you give me some advice of what could be wrong in order to take care?
how to set up icoFsiFoam? What kind of dinamic mesh to use?
thanks
Old   April 19, 2010, 03:17
Elvis
thanks
I am sorry but I am not an FSI-expert.
All I can advise you to read
http://www.openfoamworkshop.org/2007...re_Interaction
http://powerlab.fsb.hr/ped/kturbo/Op...Zagreb2007.pdf
=> there stands small timesteps to have a courant number around 1
Old   April 19, 2010, 07:16
Default 3d icoFsiFoam
  #48
frank böhnke
boehnke is on a distinguished road
Hi foamers,
thanks
Aldo
Hello Aldo,
no, no solution yet. I'm working on 3d sonicLiquidFsiFoam solver in 3d.
If i have results i could send it, or we could cooperate if you are interested in compressible viscous fluid-structure coupling. What's your application ?
Thank you, Frank Böhnke, Munich Germany
boehnke is offline   Reply With Quote
Old   April 19, 2010, 07:50
Default of course, let's try reach a solution together
  #49
Aldo Iannetti
Originally Posted by boehnke View Post
Hello Aldo,
Hi Frank,
My application is an incompressible Fsi but I'm interested in all Fsi studies. My problem is a lack of convergence in a transient case in icoFsiFoam. I can tell you:
- I imported a gambit mesh of a 'L' shaped pipe costrained in the first end
- I have doubt about the choise of plane stress/strain (for a real 3D case is neither the first nor the second case)
- What kind of dynamic mesh to use? (it is not a 2D motion of course)
I'm going to change case (a simplier mesh) of a 3D cantilever beam (already studied by OpenFOAM community but I haven't the case files)
what about your problem? Have you got convergence?
Old   April 19, 2010, 09:00
Elvis
Hello Aldo,
it´s me again.
Have you used Bernard Gschaider´s http://openfoamwiki.net/index.php/Contrib_PyFoam PyFoam?
=> pyFoamPlotRunner.py it can plot residuals or Courant No., so you might have a idea if your case converges.
Old   April 19, 2010, 09:17
Aldo Iannetti
Originally Posted by elvis View Post
Hello Aldo,
it´s me again.
No, I haven't, but my log is clear, courant number diverges at the second/third iteration. I think is a structural solver fault but I can't define where exactly.
Old   April 30, 2010, 09:15
Wolfgang W.
Hi everybody,
Frank, you were mentioning that you're working on a compressible FSI version. This sounds most interesting to me.
So far I have been using icoFsiFoam but as Elvis was pointing out quite correctly this solver runs into a lot of trouble when using smaller time steps. For my envisaged application, though, I'll need to work on very small time scales.
I was told that employing a compressible solver for the fluid and just rendering the fluid 'almost' incompressible could solve the time-stepping problem.
Could you give some ideas or hints about which compressible solver you included into the FSI and how you implemented the whole thing?
Cheers,
Wolfgang
Old   April 30, 2010, 11:18
Default sonicLiquidFsiFoam
  #53
frank böhnke
Dear Wolfgang,
as a foundation for the sonicLiquidFsiFoam solver I will use the decompressionTank example from the Programmers Guide. Right now I work on an extension to the stressFoam solver to use it for orthotropic solids for the fsi coupling.
Best regards, Frank Böhnke, Munich
Old   May 7, 2010, 12:55
Wolfgang W.
Dear Frank,
Thanks for your speedy reply!
I had a go on sonicLiquidFoam and was able to integrate it into a small test scenario I built. This solver seems to fit my needs very well - so I'm happy :-)
Thanks again!
Best regards,
Wolfgang
Old   July 16, 2010, 06:25
Default icoFsiFoam problem with restarted simulations
  #55
Takuya OSHIMA
7islands is on a distinguished road
For future interests in doing FSI simulations, we are taking a look at icoFsiFoam in OF 1.5-dev in conjunction with the flappingConsole case (flappingConsoleSmall_HJ_21Mar2008.tgz), which includes several steps of saved field data up to t = 0.024 [s] and the simulation is setup to start from the latestTime. However, we are having problem in restarted simulations.
Here I attach a figure where the x-directional displacements at the top of the console are plotted for three cases: the red line is a restarted simulation from the saved data at t = 0.024 [s] (which is how one would usually run icoFsiFoam), the green line is a fresh simulation started from t = 0 by deleting the saved data, and the blue line is also a freshly started simulation but stopped at t = 1 [s] and restarted from there. There's no wonder in the difference between the red and the green/blue lines if the saved data and our data are calculated by e.g. different solvers, but what was problem to us was the discrepancy between the green and the red lines after t = 1 [s].
The main cause of the discrepancy, besides other unsignificant ones, was sorted out to be the patch-to-patch interpolation weights between the fluid and the solid moving meshes not being updated per time step basis, hence the interpolation weights calculated at the time of simulation (re)start were constantly used during the simulation run regardless of the mesh movements. So here is what we tried to correct the issue:
Index: applications/solvers/stressAnalysis/icoFsiFoam/setMotion.H
--- applications/solvers/stressAnalysis/icoFsiFoam/setMotion.H  (revision 1790)
+++ applications/solvers/stressAnalysis/icoFsiFoam/setMotion.H  (working copy)
@@ -11,6 +11,7 @@
     stressMesh.movePoints(newPoints);
+    interpolatorSolidFluid.movePoints();
     vectorField fluidPatchPointsDispl =
         interpolatorSolidFluid.pointInterpolate
Index: applications/solvers/stressAnalysis/icoFsiFoam/setPressure.H
--- applications/solvers/stressAnalysis/icoFsiFoam/setPressure.H        (revision 1790)
+++ applications/solvers/stressAnalysis/icoFsiFoam/setPressure.H        (working copy)
@@ -2,6 +2,7 @@
     // Setting pressure on solid patch
     Info << "Setting pressure" << endl;
+    interpolatorFluidSolid.movePoints();
     scalarField solidPatchPressure =
         interpolatorFluidSolid.faceInterpolate
And the results with the patched icoFsiFoam are:
This time the green and the blue line agrees perfectly (up to around four significant digits) and the oscillating frequencies of all cases as well. Besides, combined with the results of other runs we have a general impression that the stability is also better. However, the displacements changed too drastically, to around an order of a magnitude smaller compared to those with the unpatched icoFsiFoam. Thus we are unsure if the omission of movePoints() as shown in the patch is a bug or intended for some reasons.
We'd appreciate any inputs, thoughts, comments. Thanks!
Takuya
7islands is offline   Reply With Quote
Old   August 2, 2010, 06:10
matteo lombardi
matteoL is on a distinguished road
Hello takuya,
your post is very interesting and the results you show are quite surprising: there should should be no effect in "restarting" the case but evidently there is!
I thought that the mesh::movePoints would have called automatically also the path-to-patch=interpolation:movePoitns() but evidently not otherwise your extra call should have made no difference...
I believe that the weigths HAVE to be recalculated at every time step (as much as one can try to move both patches unifromly, the two meshes are sliding a little bit one respect to the other.. and in any cases, if they are not, recomputing the weights should make no difference...) ...
Thus , yes, what you posted is very interesting and very worrying!
Thanks for posting it,
matteo
matteoL is offline   Reply With Quote
Old   August 3, 2010, 09:05
Takuya OSHIMA
Hi matteo,
Thanks for the encouraging comment However, we're finding tracking down the other problem (the varying results) is not so simple because even changing face ordering of the interface patch (by tweaking the patch definition in blockMeshDict) radically changes the results. According to my fellow the static displacement at converged steady state agrees with the theory only when a certain face ordering is used. We'll keep you posted if we make a progress.
Takuya
Old   August 3, 2010, 09:24
matteo lombardi
hello takuya,
one more thing that has come to my mind: are you running in serial or parallel? because the patchtopatchInterpolator doesn't work in parallel at the moment (You have to modify it and use globalZone-reduce-etc etc..).
anyway I will try on my FSI test case i f i have the same issue you report and let you know..
Old   August 3, 2010, 10:01
Takuya OSHIMA
Thanks about the input matteo. We are currently running only in serial, but may take a look at the interpolator (not so soon though).
Takuya
Old   August 3, 2010, 10:55
matteo lombardi
Ok, i have tried to restart one of my FSI simulations and indeed things changes.. in my case actually my FSI coupling fails to converge (!) but anyway definetely there is something wrong there..
FLUID STRUCTURE INTERACTION Javier FLUENT 1 October 14, 2004 14:42
fluid-structure interaction Tikka Main CFD Forum 4 July 7, 2001 16:08
Fluid-Structure Interaction Janice Main CFD Forum 9 May 3, 2001 17:46
FLUID/Structure Interaction Jas Main CFD Forum 5 November 21, 2000 05:46
Fluid-Structure Interaction Gabor BALINT Main CFD Forum 5 October 12, 1999 05:54
