How to define cells which belongs to ratating patch in MRFSImpleFoam
Old   May 20, 2008, 04:05
Default Hi Bharat, On short change 8
  #21
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Bharat,
On short change 8 with 1.
I think the error comes from the number of rotating reference frames that you specify: 8.
I suspect that your intention was to specify the number of rotating patches (I see that you have 8).
Dragos
dmoroian is offline   Reply With Quote
Old   May 20, 2008, 04:14
Default hi I tried by replacing 8 wi
  #22
bharat varshney
bharat is on a distinguished road
hi
I tried by replacing 8 with 1, but still I am getting the same error
do I need to define all patches individually ?
Regards
bharat
bharat is offline   Reply With Quote
Old   May 20, 2008, 04:50
Default Could you send me your case? I
  #23
dmoroian's Avatar
Dragos
Could you send me your case? I'll try to have a look at it.
Dragos
Old   May 20, 2008, 10:49
Default hi Finally, after lots of hi
  #24
bharat varshney
hi
Finally, after lots of hit and trial I removed that error. It was just the problem of spacing in some brackets also the number is 1 not 8. Tomorrow, I will run the final simulation and will update you with the results. Hope I will not find any other hurdle ahead.
Thanx a lot Dragos and Jaswinder.
Below is the corrected MRFZone file:
1
VB
patches (BB INT-BO-SIDE-1 INT-BT-SIDE-1 PER-B-SIDE-1 PER-B-SIDE-2 SB-E SB-I VB-DEFAULT);
origin origin [0 1 0 0 0 0 0] (0 0 0);
axis axis [0 0 0 0 0 0 0] (0 0 -1);
omega omega [0 0 -1 0 0 0 0] 19.625;
Regards
Bharat
Old   October 6, 2008, 03:04
Default Hi People, I am struggling a
  #25
Mahendra
mahendra is on a distinguished road
Hi People,
I am struggling a lot for the MRFSimpleFoam case. I completed the tutorial for the same, but my blower case is giving me some errors while creating the MRF zones. Below is the error....
Please let me know what can be done to fix the error.
Create time
Reading mesh for time = 0
Create mesh
Reading cellSetDict
Backing up wall into wall_old
Set:wall Size:0 Action:new
Adding all cells of cellZone wall ...
--> FOAM Warning :
From function zoneToCell::combine(topoSet&, const bool)
in file sets/cellSources/zoneToCell/zoneToCell.C at line 75
Cannot find zone named wall
Valid zones are
0
Writing wall (size 0) to "constant/polyMesh/sets/wall"
mahendra is offline   Reply With Quote
Old   August 10, 2013, 15:03
reza1980's Avatar
reza
reza1980 is on a distinguished road
Hi ,
Would you please tell me this implemenation is needed as we use mergeMeshes.
Originally Posted by jaswi View Post
Hi Bharat
Sorry for the delay. Below given is the description of makeMesh upto my understanding. it might have mistake and I hope forum experts will correct me if its wrong.
Provided you have the correct cellZone corresponding to your rotating domain, your makeMesh shall look like this:
(Note:replace mixerVessel2D with your case name everywhere.)
cellSet .. mixerVessel2D
cp system/faceSetDict_rotorFaces system/faceSetDict
faceSet .. mixerVessel2D
cp system/faceSetDict_noBoundaryFaces system/faceSetDict
setsToZones .. mixerVessel2D -noFlipMap
Now lets take a quick look what all these commands do. Its all very logical and easy....
1)cellSet .. mixerVessel2D
creates a cell set according to the definition given in the cellSetDict (this file lives in <case>/system). now the cellSetDict given for the mixerVessel2D has the following in it:
// Name of set to operate on
name rotor;
// One of clear/new/invert/add/delete|subset/list
action new;
// Actions to apply to cellSet. These are all the topoSetSource's ending
// in ..ToCell (see the meshTools library).
topoSetSources
// Cells in cell zone
zoneToCell
name rotor; // name of cellZone
It says that create a cellSet (action new called
rotor (name rotor from a topological source. The source can be set by calling topoSetSources(). The argument which is passed to the topoSetSources() is the cellZone called rotor (name rotor hence the code
zoneToCell
At the successfull execution of this step one will get a cellSet called rotor in the directory /polyMesh/sets
2)faceSet .. mixerVessel2D
This creates a face set according to the definition given in the faceSetDict (this file lives in <case>/system). One can clearly observe the analogy with the cellSet command and cellSetDict.
Now the faceSet creation for the rotor is a two step process.
2.1) create a face set corresponding to the cellSet rotor (created in step 1). Thus the faceSetDict for this step should look like this:
name rotor;
action new;
// Actions to apply to pointSet. These are all the topoSetSource's ending
// in ..ToFace (see the meshTools library).
topoSetSources
// Select based on cellSet
cellToFace
set rotor;
option all; // All faces of cells
One can see that its structure is similar to cellSetDict i.e. create a face set from a topological source which in this case is a cellSet named rotor. The "option all" implies that the created faceSet has all the faces of the cells in cellSet rotor
2.2) remove the faces corresponding to the boundary faces from the faceSet created in the step 2.1). and the faceSetDict for this step should look like this:
name rotor;
action delete;
topoSetSources
// Select boundary faces
boundaryToFace
Now this faceSetDict says that delete the faces corresponding to the boundary, from the existing faceSet rotor and the topological source for this operation is the faceSet created in the previous step.
3)setsToZones .. mixerVessel2D -noFlipMap
the last command create the faceZone from the faceSet created in the step 2.2. what does the switch -noFlipMap does is not clear to me yet but no using it throws up error so use it.
Now if you still wonder what does this statement does :-) :
then it should be clear by now.
I encourage you to try the easy step from the console. If at the end you still wonder whether you have the correct faceSet then you can use the following to visualize the set in paraFoam
foamToVTK root case -faceSet rotor
This will create a folder VTK and in there it saves your cellset rotor in VTK format which you can see with paraFOAM
I hope that you will now be able to execute the script and if required modify it to suit your needs.
Regards
Jaswi
P.S: For a detailed list of options for the topoSetSources() look in the sample cellSet, face set, pointSet dictionaries given in the
mesh/manipulation/cellSet
mesh/manipulation/faceSet
mesh/manipulation/poinTSet
reza1980 is offline   Reply With Quote
Old   August 18, 2013, 19:35
Retired Super Moderator
Bruno Santos
Hi Reza,
A bit more information here would help.
Best regards,
Bruno
MRFSimpleFoam command to run shyam OpenFOAM Running, Solving & CFD 2 February 5, 2009 06:38
MRFSimpleFoam xdanielx OpenFOAM Running, Solving & CFD 0 December 17, 2008 02:28
How to define a patch group number in pre-process? jacky CFX 4 December 19, 2002 05:31
How to define a patch group number in pre-process? jacky CFX 0 December 19, 2002 03:46
Define a zone to patch Maurizio Barbato FLUENT 1 October 13, 2000 01:10
