PEqnflux in compressible and incompressible PISO loop
Old   October 7, 2008, 11:58
Default Hi, all: I have a question
roy fokker
dbxmcf is on a distinguished road
Hi, all:
I have a question about the pEqn.flux() in the PISO loop, for the incompressible(icoFoam) case, after solving the pressure correction equation:
phi -= pEqn.flux();
while in the compressible case (sonicFoam),
phi = pEqn.flux();
My understanding is the incompressible flow is just a special case for the compressible flow (rho=const), no matter the pressure correction equation looks like. Can anyone explain the difference for the two cases?
Thanks a lot!
dbxmcf is offline   Reply With Quote
Old   July 11, 2015, 16:21
België/Belgique
David1 is on a distinguished road
Hi Roy,
Did you eventually found your answer? Because I have the same question you have/had.
Thank you!
David1 is offline   Reply With Quote
Old   September 27, 2019, 02:14
Ashwani
AshwaniAssam is on a distinguished road
Did it get resolved? Because I do not see anywhere else in OpenFOAM except in the sonicFOAM this term
phi = pEqn.flux();
without any addition or subtraction.
Is it right?
Last edited by AshwaniAssam; September 27, 2019 at 02:15. Reason: Typos correction
AshwaniAssam is offline   Reply With Quote
Old   September 27, 2019, 07:13
Ashwani
I found the answer here: PISO Details
In sonicFoam
the ".flux()" function returns the influence of all implicit terms on the flux. In this case everything is implicit, so you can assign it like that
phi = pEqn.flux();
So, what I understand is that .flux() operator gives the flux terms of the equation which are handled implicitly.
Incompressible boussiesq flow pressure BC piso and continuity problems tehache OpenFOAM Running, Solving & CFD 4 November 6, 2008 04:08
PISO loop 21kalee OpenFOAM Running, Solving & CFD 2 January 15, 2008 06:31
Compressible -> incompressible. Jinwon Main CFD Forum 6 November 23, 2007 22:07
Dimensions of laplacian in PISO loop kumar2 OpenFOAM Running, Solving & CFD 2 July 3, 2006 15:34
Mistake in PISO loop for interFoam solver kumar2 OpenFOAM Running, Solving & CFD 3 June 30, 2006 19:26
