Polymer processing injection molding application |
March 4, 2010, 11:55 |
#21 |
ata kamyabi
Rep Power: 18 |
Hi KyleL
As I said I am interested in. I had some literature review. Did you have too? What is your plan? |
March 4, 2010, 15:23 |
#22 |
Ata,
I guess my plan is to first find out what if any development has been done? Then I would like to review any information available, and maybe find a programmer that would be willing to help develop the needed moldFOAM solver. I would very much like to see any information you have available. Thanks, KyleL |
March 6, 2010, 00:18 |
#23 |
ata kamyabi
Rep Power: 18 |
Hi Kyle Lampkin
I have some paper a bout this, but now I don't remember their title and authors and I must take a look at my resources. Do you want them? If yes I'll send them for you. All the best |
May 24, 2010, 15:10 |
Any updates?
#24 |
Vesselin Krastev
Rep Power: 20 |
Are there any updates about this matter? I'm really interested in any applications wich involve the use of the OpenFOAM frame in simulating the injection molding process for polymers.
Thank you in advance |
May 25, 2010, 02:01 |
#25 |
ata kamyabi
Rep Power: 18 |
Hi
I have written a two phase code for polymer processing but now I am PhD student and I can not release it until the end of my PhD but if you want may be I could help you in code preparation or you can wait until the end of my PhD. Best regards Good luck |
May 25, 2010, 03:23 |
#26 | |
Alberto Passalacqua
Rep Power: 36 |
Good luck!
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
May 25, 2010, 05:16 |
#27 |
ata kamyabi
Rep Power: 18 |
Hi Alberto Passalacqua
I am doing that and after publishing my work, I'll release my code. Best regards |
May 25, 2010, 06:38 |
Thank you for the reply
#28 |
Vesselin Krastev
Rep Power: 20 |
First of all thanks for the reply. Secondly, of course I do not ask for your source code if it hasn't been released yet (I'm a PhD student too, soo I can easily understand the importance of protect the autorship of your work). Actually at this stage I only want to understand if such a complex flow has already been approached inside the OpenFOAM frame and how, in general terms, it can be implemented. So, generally speaking, can you tell me how did you approach the problem (I mean: are the two phases isothermal or not? Did you start with modifying some pre-existing multiphase solver, such as the interFoam one? Is the polymer fluid treated as a non-newtonian one?)? Thank you and good luck for your PhD!
May 25, 2010, 06:52 |
#29 |
ata kamyabi
Rep Power: 18 |
Hi
My code is isothermal solver for two phase flow. Two phases can be viscoelastic-viscoelastc fluids or viscoelastic-Newtonian fluids. There is about 15 constitutive models available for viscoelastic fluids in my code and geometry is general in it. I used from interFoam and viscoelasticFluidFoam solvers and combined them. I think it is not very hard to add energy equation to may code. Thank you very much for your understanding me and my restrictions Good luck with your PhD too |
May 25, 2010, 12:35 |
#30 | |
Alberto Passalacqua
Rep Power: 36 |
P.S. Didn't mean to put pressure :-)
May 27, 2010, 05:44 |
Non-Isothermal solver
#31 | |
Erik Appel Jensen
I have some students working on developing a code for simulation of injection moulding. They used interFoam and added an energy equation to the solver, part of the problem is discussed in following thread: http://www.cfd-online.com/Forums/ope...sitymodel.html The non-isothermal behavoiur is based on the paper: "A novel design for hot-melt extrusion pelletizers" Stefan Radel et. al. Chmical Engineering Science 65 (2010) page 1976-1988 If the company involved in the project accepts, I will ask them to disclose the code and test case. However, there is still an issue about the frozen layer. |
May 27, 2010, 10:10 |
#32 | |
Jitao Liu
Rep Power: 17 |
Is the melt compressible in your code? Do you take melt solidification into account in your solver? I am interested in injection molding simulation, too. Hope that we can hellp each other. Best regards |
May 28, 2010, 10:48 |
#33 |
ata kamyabi
Rep Power: 18 |
Hi Jitao Liu
As now code is incompressible with no melt solidification. I would be very glad if I can help you and have cooperation with you. Best regards Ata |
November 26, 2012, 04:37 |
#34 |
k zhang
Rep Power: 14 |
Hi, Ata
I want to combine the interFoam and viscoelasticFoam to simulate the polymer injection, just like i said in the other post. But in the interFoam solver, there is a "transportmodle" file in it ..., I have no idea to put the viscoelastic informations in it. How can I do? can you give me some advises on that? If it is convenient, you are appreciated to e-mail me: skykzhang@hotmail.com |
November 28, 2012, 02:09 |
#35 |
ata kamyabi
Rep Power: 18 |
Hi
I ignored the transportmodle. Write one similar to it for your self. |
December 17, 2012, 09:37 |
#36 |
k zhang
Rep Power: 14 |
ata, did you get your PhD already? you are appreciated for realseing the solver.
June 2, 2014, 07:49 |
#37 |
Andrea Pisa
Rep Power: 13 |
Hi all, i'm very interested in this project. There is still someone working on it?
November 27, 2014, 09:13 |
#38 |
otadol
Rep Power: 12 |
up?
it is possible to access to all the work you did guys? |
May 16, 2016, 08:32 |
#39 |
Christian
Rep Power: 12 |
Hi guys,
any updates on the solvers? Would be interested to contribute, maybe adding a scalartransport equation to introduce temperature in the flow. Let me know, Christian |
December 2, 2016, 17:42 |
Injection molding in OpenFOAM? Euh....
#40 |
Thomas Boucheres
Rep Power: 13 |
Hi guys,
throughout this OpenFOAM forum, I see that many people are interested on the topic of "injection molding" with OpenFOAM. It seems that some people have build a solver for this topic. Something based on interFoam for interface tracking, adding heat transfer, rheology and so on. Nevertheless, I'm not aware of anybody who has released such a solver Well, I work on this topic for a long time and, from my point of view, it is a quite complex story to build such a tool. You could find some hints below. Overview of the problem: the cornerstone of the problem is not the heat transfer or rheology behavior (not an easy task nevertheless...) but the tracking of the interface by itself. Indeed, the main difficulty (for OpenFOAM) is that we need to deal with a highly viscous phase (the polymer) with something like air (not viscous at all). Mmm, it seems abstract at this point of the story We have something like interFoam no? Where is the problem? Common simplifications: in a first step, you can drop all transient and convective terms in the base Navier-Stokes solver --> you are dealing with pure Stokes problem now (it is what all standard softwares like Moldflow do by default). It should be easy now? --> not at all in fact You are just at the cornerstone of the problem: you need to deal with a Stokes system with a highly viscous term and a quasi inviscid one. Ok, another common simplification is to consider that air has a viscosity something like viscosity(polymer)/1000. For example, if your polymer has mu = 1000 Pa.s, then take mu(air) = 1Pa.s. It doesn't change significantly the flow front evolution and it reduces the stifness of the problem. Still a nightmare: Previous simplifications are good but far from being enough The Stokes problem we need to deal with is still too stiff... for OpenFOAM. The problem is heavily linked with the numerical kernel of OF: cell-centered FV with segregated approach for U/p. Not good at all for Stokes operator with strong jump on viscosity and high viscosity. The underlying reasons are not so clear from strict analytic point of view (search this topic on google scholar / you won't find many things). Ok, two things: 1- first recall at least that it is a quite well-known fact that cell-centered FV are bad for diffusion operators on irregular meshes --> there is "reminescence" of this behavior on eulerian tracking schemes (on perfectly regular meshes!), 2- secondly, try to use the interFoam to simulate the falling (by gravity) of a highly viscous drop (say a drop of radius 1mm with density 1000 and viscosity 1000Pa.s) in ambiant air and see the result. You should understand quickly what happens. What you could do: 1- Work with a finite element solver for U/p (you can track alpha with FV if you -- still -- like them!). 2- Ok, i'm a bad guy. It could have some solutions also for finite volume framework but it is not "proven" and they are difficult to implement in OpenFOAM: a- modern finite volume methods like DDFV. Search a paper of Jerome Droniou, "Finite volume schemes for diffusion equations. Introduction to and review of modern methods" --> just an introduction, not focused at all in diphasic Stokes problem / rather some approachs (DDFV but some others) for working with quite irregular meshes / some peoples have succesfully applied them for biphasic Stokes flows with good results. Highly interesting / quite valuable for amening OpenFOAM to a high level of numeric technology / but quite complex to implement properly and quickly. Obviously, if you are able to do such a thing by yourself, you would be a god if you release freely such an extension to the OpenFOAM community! Seriously, it is a quite complex topic and "a job by itself". You need to be a researcher on this topic to achieve it. Nightmare is not finish... It begins! If you start some works on this topic, you will quickly face the problem of the wall boundary condition treatment A physical fact: at the melt front position, the polymer "partially slip" along the wall... It is a big / interesting / and complex story to deal accurately and efficiently with this (now you should guess that it is not sufficient to use something like the "partialSlip" BC of OF). Maybe more on this topic later .................................................. ........................... Well, is it yet an easy task to do injection molding with OpenFOAM??? Mmm, maybe it is for this reason that nobody has released a real solver for it... |
Path Line in a injection molding | David | FLUENT | 8 | September 2, 2011 11:08 |
Melt Front Tracking in Transfer Molding | Alex | FLUENT | 0 | August 2, 2008 22:43 |
compression molding in cfx | Christoph Raith | CFX | 0 | May 3, 2008 10:30 |
viscoelstuc model in polymer processing. | abbas | FLUENT | 0 | July 29, 2007 09:45 |
polymer hydration | Dave Pinella | Main CFD Forum | 0 | December 6, 1999 15:24 |
