Basic boundary condition question
Old   September 17, 2008, 16:04
Default Hi all, Given that the outw
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
Hi all,
Given that the outward drawn unit normal to inlet and outlet boundaries point parallel to the x-direction, are the following the only conditions that need to be satisfied at these boundaries?
For a fixed velocity inlet,
u = fixed value
v = fixed value
(dp/dx) = 0.0
For a fixed pressure outlet,
p = fixed value
du/dx = 0.0
dv/dx = 0.0
Where: In 2D: U = [u,v] (u and v are the two components of velocity vector U) and assume that 'd' represents the partial derivative symbol.
I would appreciate if someone can point out if I am incorrect or missing anything here.
Thanks for your help.
msrinath80 is offline   Reply With Quote
Old   September 18, 2008, 14:02
Default Anyone? Even a simple Yes or N
Anyone? Even a simple Yes or No will suffice.
Old   September 18, 2008, 14:15
Default For incompressible laminar flo
liu
Xiaofeng Liu
liu is on a distinguished road
For incompressible laminar flow, Yes
Xiaofeng Liu, Ph.D., P.E.,
Assistant Professor
Department of Civil and Environmental Engineering
Penn State University
223B Sackett Building
University Park, PA 16802
Web: http://water.engr.psu.edu/liu/
liu is offline   Reply With Quote
Old   September 19, 2008, 11:59
Default Thanks Xiaofeng.
Thanks Xiaofeng.
Old   October 1, 2008, 18:05
Default For a plain channel or pipe fl
For a plain channel or pipe flow, dp/dx = 0 at the inlet boundary does not seem to make sense. The pressure should be allowed to change in the X-direction. Can anyone comment on that?
Old   October 1, 2008, 18:55
Default Hi Srinath Yes, I would lik
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Srinath
Yes, I would like to give my two cents:
Ideally you would say, that the only thing you know for sure is the pressure at the inlet and at the outlet, i.e. the energy gradient. Thus the intuitive way to set the boundary conditions would be to apply the pressure at both ends, which is equivalent of applying a body force. This solution converges asymptotically, thus far to slow to be interesting if you start with initial field 0 (unfortunately I cannot recall the reference on the asymptotic part).
This would give a correct pressure gradient, i.e. constant, along your uniform channel. Another method is to apply the velocity at the inlet and a non-zero pressure gradient, but that implies that you _know_ the solution to the pressure field in advance, thus people have settled with the zero pressure gradient. I have read another article (again, cannot recall the exact reference), which did compare the results between a zeroGradient and the correct gradient solution, and the differences was small, at least from an engineer-point-of-view.
Best regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   October 1, 2008, 20:56
Default Thanks very much for that resp
Thanks very much for that response Niels. You've brought some interesting facts to my attention. I'll try and dig up more information on this.
Old   October 14, 2008, 01:25
Default Hello People, I am have a s
Mahendra
mahendra is on a distinguished road
Hello People,
I am have a small doubt regarding pressure boundary condition. In Fluent i have specified -1500 Pa gauge (negative) boundary condition at outlet. In OpenFOAM what boundary condition should i give.
like this or something different?
outlet
type fixedValue;
value -1225; // (-1500/1.225) pressure/density since units of pressure are [0 2 -2 0 0 0 0].
mahendra is offline   Reply With Quote
Boundary condition question cestrin FLUENT 0 July 22, 2008 00:53
Basic Boundary Conditions Question vcoralic OpenFOAM Pre-Processing 0 June 26, 2006 08:56
Question about Boundary condition.. Sam CFX 0 May 9, 2005 22:53
boundary condition question tucker FLUENT 1 May 4, 2005 13:42
