October 15, 2008, 10:53 |
hi,
when i calculate my case,
weihong yao
Rep Power: 17 |
hi,
when i calculate my case,it show some errors: Exec : turbFoam /home/ivan/OpenFOAM/ivan-1.4.1/run/tutorials/turbFoam case1 Date : Oct 14 2008 Time : 09:23:25 Host : linux-pasm PID : 15342 Root : /home/ivan/OpenFOAM/ivan-1.4.1/run/tutorials/turbFoam Case : case1 Nprocs : 1 Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 0.002 Courant Number mean: 0 max: 0.00444444 --> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a defaultFvPatchField (actual type BoundaryU) on patch inlet of field U in file "/home/ivan/OpenFOAM/ivan-1.4.1/run/tutorials/turbFoam/case1/0/U" You are probably trying to solve for a field with a default boundary condition. From function defaultFvPatchField<type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basic/default/defaultFvPatchField.C at line 694. FOAM exiting. i have writed new boundary condition in my case. what is the problem?can someone give me a hint? |
How to calculate the k in les? | aiya | Main CFD Forum | 0 | June 27, 2006 14:33 |
Problem calculate Y in compressible turbulence model | luca | OpenFOAM Running, Solving & CFD | 5 | June 1, 2006 06:53 |
hi how to calculate the HTC | kathir | Siemens | 0 | March 26, 2006 10:31 |
calculate cp | Pete | Siemens | 1 | March 2, 2005 21:58 |
how to calculate CL and CD | zhaoyu | FLUENT | 1 | April 24, 2001 10:56 |
