SimpleFoam error
Old   October 16, 2008, 05:13
Default Good morning everybody, I n
Sven Degner
sven82 is on a distinguished road
I need help with a simpleFoam case, any start follows a interuption with time step continuity errors (log file below)
and I have no idea why I got this error???!!!!
My checkMesh are Ok, and any changes on nNonOrthogonalCorrectors factors an relactionFactors are pointless (nNonOrthogonalCorrectors from 0 up to 5 andt the relaxationFactors (pressur) 0.5 down to 0.1 (for the other 0.7-0.5)).
But nothing change any the same error, but on a other iteration step .
A last word to the controlDict dt=1/startTime 0/endTime 1000 .
Hope of any advice, Thx
Create time
Create polyMesh for time = constant
Time = constant
Mesh stats
faces: 1550050
internal faces: 1440066
cells: 697760
boundary patches: 3
point zones: 0
face zones: 0
cell zones: 0
Number of cells of each type:
hexahedra: 0
prisms: 189689
wedges: 0
pyramids: 9387
tet wedges: 0
tetrahedra: 498684
polyhedra: 0
Checking topology...
Boundary definition OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
wall 108900 54402 ok (non-closed singly connected)
outlet 140 85 ok (non-closed singly connected)
inlet 944 509 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-99.25 -153.524 -109.521) (393.5 58.7016 80.64)
Mesh (non-empty) directions (1 1 1)
Mesh (non-empty, non-wedge) dimensions 3
Boundary openness (-2.87614e-20 1.99789e-19 8.8192e-20) OK.
Max cell openness = 2.82706e-16 OK.
Max aspect ratio = 31.9831 OK.
Minumum face area = 0.000604772. Maximum face area = 12.8418. Face area magnitudes OK.
Min volume = 8.21905e-06. Max volume = 10.5877. Total volume = 1.65722e+06. Cell volumes OK.
Mesh non-orthogonality Max: 85.7172 average: 19.8501
*Number of severely non-orthogonal faces: 1800.
Non-orthogonality check OK.
<<Writing 1800 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 2.44847 OK.
Mesh OK.
And the log file
Time = 34
DILUPBiCG: Solving for Ux, Initial residual = 0.414096, Final residual = 0.00875563, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.755011, Final residual = 0.00607393, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.289439, Final residual = 0.00401936, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.0242159, Final residual = 0.0002384, No Iterations 13
DICPCG: Solving for p, Initial residual = 0.000512817, Final residual = 4.54779e-06, No Iterations 29
DICPCG: Solving for p, Initial residual = 0.000581243, Final residual = 5.58549e-06, No Iterations 13
DICPCG: Solving for p, Initial residual = 0.000200338, Final residual = 1.7858e-06, No Iterations 17
DICPCG: Solving for p, Initial residual = 8.21745e-05, Final residual = 9.36066e-07, No Iterations 72
DICPCG: Solving for p, Initial residual = 5.18558e-05, Final residual = 8.97518e-07, No Iterations 10
time step continuity errors : sum local = 2.18352e+11, global = 7.3461e+10, cumulative = 7.3461e+10
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.0667035, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0619102, No Iterations 1
ExecutionTime = 26569.9 s ClockTime = 26776 s
Time = 35
DILUPBiCG: Solving for Ux, Initial residual = 0.430625, Final residual = 0.0126636, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.476771, Final residual = 0.0200483, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.538803, Final residual = 0.0238294, No Iterations 1
DICPCG: Solving for p, Initial residual = 1, Final residual = 3042.32, No Iterations 1001
DICPCG: Solving for p, Initial residual = 1.02633e-06, Final residual = 1.50811e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 3.33827e-06, Final residual = 3.858e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 3.36986e-06, Final residual = 9.01726e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 4.6287e-06, Final residual = 5.5043e-07, No Iterations 1
DICPCG: Solving for p, Initial residual = 2.35689e-06, Final residual = 7.30301e-07, No Iterations 1
time step continuity errors : sum local = 1.60889e+23, global = 3.41641e+10, cumulative = 1.07625e+11
DILUPBiCG: Solving for epsilon, Initial residual = 1, Final residual = 0.0328034, No Iterations 5
bounding epsilon, min: -1.64852e+15 max: 9.49915e+49 average: 7.79449e+44
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.0271704, No Iterations 1
bounding k, min: -5.78827e+10 max: 4.92069e+44 average: 4.25102e+39
ExecutionTime = 26870.6 s ClockTime = 27078 s
Time = 36
DILUPBiCG: Solving for Ux, Initial residual = 0.576337, Final residual = 0.0209951, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.374828, Final residual = 0.0196583, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.501717, Final residual = 0.029546, No Iterations 1
DICPCG: Solving for p, Initial residual = 0.999987, Final residual = 108.627, No Iterations 1001
DICPCG: Solving for p, Initial residual = 2.22641e-12, Final residual = 2.22641e-12, No Iterations 0
time step continuity errors : sum local = 6.47453e+59, global = 1.21439e+43, cumulative = 1.21439e+43
DILUPBiCG: Solving for epsilon, Initial residual = 0.0825631, Final residual = 2.92586e-22, No Iterations 1
bounding epsilon, min: -8.3851e+61 max: 2.59504e+64 average: 7.63721e+58
DILUPBiCG: Solving for k, Initial residual = 0.454124, Final residual = 0.0313596, No Iterations 1
bounding k, min: -7.37106e+41 max: 1.04316e+53 average: 1.44528e+48
ExecutionTime = 27167.8 s ClockTime = 27377 s
Time = 37
DILUPBiCG: Solving for Ux, Initial residual = 0.494458, Final residual = 0.0127436, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.319995, Final residual = 0.00570061, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.418424, Final residual = 0.0133077, No Iterations 1
Error message in shell
#0 Foam::error::printStack(Foam:stream&) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7f72420]
#3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOp
#4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGcc
#5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPO
#8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libfiniteVolume.so"
#9 main in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/simpleFoam"
#10 __libc_start_main in "/lib/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/usrfem/femsys/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/simpleFoam"
sven82 is offline   Reply With Quote
SimpleFoam Error with librdmacm amp libibverbs dnomdec OpenFOAM Running, Solving & CFD 1 May 21, 2010 09:02
Error running simpleFoam in parallel skabilan OpenFOAM Running, Solving & CFD 2 August 29, 2008 10:42
SIMPLEFOAM ERROR ON A RAE2822 dinonettis OpenFOAM Running, Solving & CFD 0 April 28, 2008 10:50
Error message using simpleFoam plmauk OpenFOAM Running, Solving & CFD 0 January 22, 2008 08:46
SimpleFoam error message braennstroem OpenFOAM Running, Solving & CFD 1 October 15, 2007 13:33
