PotentialFOAM for channel flow
Old   October 16, 2008, 13:18
Default Hello all, I am using Poten
Cem Albukrek
albcem is on a distinguished road
Hello all,
I am using PotentialFOAM to initialize the flow field in a rectangular channel to seed it into icoFOAM. Here are the boundary conditions:
inlet: impose velocity profile and zero pressure gradient
outlet: Fixed pressure and zero velocity gradient
walls of the channel: slip velocity boundary condition, zeroGradient on pressure
When I run potentialFOAM, I get the expected straight streamlines across the channel, but the velocity profile is smoothed out to a constant profile after a few cells downstream of the inlet. So at the outlet I have more or less constant velocity across the surface.
If I run icoFOAM, the velocity profile propagates gradually to the outlet across the channel as expected. So the inlet and outlet profiles closely resemble each other.
I am trying to understand if I can expect the potential flow solution to look similar to the fully evolved viscous solution, in which the inlet velocity profile is valid all through the channel. If not why?
Thanks.
C.
albcem is offline   Reply With Quote
Using potentialFoam with simpleBuoyantFoam lasb OpenFOAM Running, Solving & CFD 5 August 28, 2015 13:32
maintain a constant flow rate in channel flow ? Lewis Main CFD Forum 2 September 28, 2010 12:35
POTENTIALFOAM ERROR for a naca profile dinonettis OpenFOAM Running, Solving & CFD 7 September 9, 2010 11:59
PotentialFoam few problems chris_sev OpenFOAM Running, Solving & CFD 1 July 22, 2008 11:15
POTENTIALFOAM ERROR for a naca profile dinonettis OpenFOAM Running, Solving & CFD 2 April 10, 2008 13:17
