October 17, 2008, 11:31 |
Dear users,
has already som
stephane sanchi
Rep Power: 18 |
Dear users,
has already somebody had this kind of error message using rasInterFoam ??? Create mesh for time = 0 Reading environmentalProperties Reading field pd Reading field gamma Reading field U Reading/calculating face flux field phi Reading transportProperties Selecting incompressible transport model Newtonian Selecting incompressible transport model Newtonian Calculating field g.h Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; alphaEps 0.76923; } time step continuity errors : sum local = 1.73782e-10, global = 4.40409e-22, cumulative = 4.40409e-22 DICPCG: Solving for pcorr, Initial residual = 1, Final residual = 3.98799, No Iterations 21 DICPCG: Solving for pcorr, Initial residual = 0.643426, Final residual = 0.375717, No Iterations 21 DICPCG: Solving for pcorr, Initial residual = 0.4499, Final residual = 0.260614, No Iterations 21 time step continuity errors : sum local = 5.46386e-10, global = -2.37967e-14, cumulative = -2.37967e-14 [5] #0 Foam::error::printStack(Foam:stream&) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [5] #1 Foam::sigFpe::sigFpeHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" [5] #2 ?? in "/lib64/libc.so.6" [5] #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [5] #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [5] #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double) in "/shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" [5] #6 main in "/shared/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/rasInterFoam" [5] #7 __libc_start_main in "/lib64/libc.so.6" [5] #8 Foam::regIOobject::readIfModified() in "/shared/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/rasInterFoam" [cfs8:03149] *** Process received signal *** [cfs8:03149] Signal: Floating point exception (8) [cfs8:03149] Signal code: (-6) [cfs8:03149] Failing at address: 0x45f00000c4d [cfs8:03149] [ 0] /lib64/libc.so.6 [0x7f2b47ad9660] [cfs8:03149] [ 1] /lib64/libc.so.6(gsignal+0x35) [0x7f2b47ad95c5] [cfs8:03149] [ 2] /lib64/libc.so.6 [0x7f2b47ad9660] [cfs8:03149] [ 3] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES7limiterINS_8oneFieldENS_9zeroFieldES3_EEvRNS_5 FieldIdEERKT_RKNS_14GeometricF ieldIdNS_12fvPatchFieldENS_7volMeshEEERKNSA_IdNS_1 3fvsPatchFieldENS_11surfaceMes hEEESK_RKT0_RKT1_ddi+0xeb1) [0x7f2b4924b741] [cfs8:03149] [ 4] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES13explicitSolveINS_8oneFieldENS_9zeroFieldES3_E EvRKT_RNS_14GeometricFieldIdNS _12fvPatchFieldENS_7volMeshEEERKNS7_IdNS_13fvsPatc hFieldENS_11surfaceMeshEEERSE_ RKT0_RKT1_dd+0x274) [0x7f2b4924e4e4] [cfs8:03149] [ 5] /shared/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so(_ZN4Foam5MU LES13explicitSolveERNS_14GeometricFieldIdNS_12fvPa tchFieldENS_7volMeshEEERKNS1_I dNS_13fvsPatchFieldENS_11surfaceMeshEEERS8_dd+0x24 ) [0x7f2b49237f34] [cfs8:03149] [ 6] rasInterFoam [0x420bb6] [cfs8:03149] [ 7] /lib64/libc.so.6(__libc_start_main+0xe6) [0x7f2b47ac5436] [cfs8:03149] [ 8] rasInterFoam(_ZN4Foam11regIOobject14readIfModified Ev+0x1c9) [0x41d6c9] [cfs8:03149] *** End of error message *** mpirun noticed that job rank 0 with PID 25693 on node cfs6 exited on signal 15 (Terminated). Courant Number mean: 0.0175051 max: 0.328046 Starting time loop Courant Number mean: 0.0265228 max: 0.497039 deltaT = 0.00757576 Time = 0.00757576 MULES: Solving for gamma Thanks for helping me, Stephane |
Error message | booz | OpenFOAM Pre-Processing | 0 | October 8, 2008 09:47 |
Error message-Floating point error | Vaibhav | FLUENT | 3 | December 7, 2007 06:38 |
ERROR MESSAGE: line 1: parse error | Lourival | FLUENT | 1 | February 18, 2006 02:35 |
Error message | HP | FLUENT | 0 | August 4, 2005 13:37 |
Gambit 2.0 - Error Message (ACIS ERROR 1200) | James | FLUENT | 1 | May 14, 2003 09:13 |
