Rise of a spherical bubble terminal velocity
Like Tree5Likes
Old   September 21, 2012, 15:54
Tayo
tayo is on a distinguished road
Originally Posted by Hrushi View Post
Hi Angelo & Tayo
Here is the updated version of baryCenter baryCenter-of201.zip utility. I have tested it on OpenFoam-201. You can comapre the each file in zip archive with one that you have to recognise the changes one needs to make it usable in OF201.
Hope it helps.
Regards
Hrushi
Thank you Hrushi. The hard job is done; It compiled fine. I simply ran the application after my simulation run time was complete and it printed out the value. Is there a way to extract the data from the barycenter into a file so that I won't have to manually copy the data? Have a nice weekend.
tayo is offline   Reply With Quote
Old   October 10, 2013, 16:45
Hrushikesh Khadamkar
Hrushi is on a distinguished road
Here is the updated version of baryCenter (for OF-2.2.1) baryCenter221.zip utility. I have tested it on OpenFOAM-2.2.1.
Enjoy!
Hrushi is offline   Reply With Quote
Old   November 16, 2013, 14:27
sfigato's Avatar
Marco Longhitano
sfigato is on a distinguished road
Send a message via Skype™ to sfigato
Dear Sebastian,
i want to compute the rise velocity. After you got your center file and you use it in Matlab, how do you compute exactely the rise velocity for each time step?
v(n-time) = ( barycentre(n) -barycentre (n-1) )/ deltaT
or
v(n-time) = ( barycentre(n) -barycentre (0) ) / ( t(n)- t (0) )
Thanks in advance
Marco
sfigato is offline   Reply With Quote
Old   January 6, 2014, 03:30
Nazanin
Nazanin is on a distinguished road
Enjoy!
Hi Hrushikesh
Thank you for provide baryCenter..
But,how I can use this?I simulate rising bubble and I want calculate rising velocity,bubble diameter and surface area..but I don't know how define these??
can You help me??
Best
arsalan.dryi likes this.
Nazanin is offline   Reply With Quote
Old   May 21, 2016, 15:02
Arsalan
arsalan.dryi is on a distinguished road
Dear Foamers,
Is there a way to compute two or three bubbles center position an velocity with swak4Foam?!
I used a swakEpression as follows for calculating a single bubble center of position, but for two bubble, I don't have any idea!
    bubbleCentreY
        type swakExpression;
        valueType internalField;
        verbose true;
    variables (
    "Vol= sum (alpha1 < 0.5 ? vol() : 0);"
    "VolY= sum (alpha1 < 0.5 ? pos().y*vol() : 0);"
    expression "VolY/Vol";
        accumulations (
        min
Thanks in advance,
Regards.
arsalan.dryi is offline   Reply With Quote
Old   May 31, 2017, 06:41
Smile How to make 2D bubble region in openfoam?
  #46
David
18210436486 is on a distinguished road
Originally Posted by sega View Post
My first setup was really bad.
I have done this now:
- used the complete computational domain (no symmetry)
- boundary-condition:
U: 0 at the bottom, zeroGradient at all other sides
pd: totalPressure 0 at the top, zeroGradient at all other sides
gamma: zeroGradient at all sides
I initialized the bubble as a sphere of defined radius and defined pressure inside.
All other transportProperties were chosen as in the literature mentioned above.
The simulation is running, but is not computing as I have planned.
- The bubble does not reach the "spherical cap sized" shape. It's more "skirted" at the sides.
Is that due to wall effects (actually there is no wall to the sides)?
Maybe I have to increade the computational domain?
The bubble is rising very slowly.
The image from above is after 30s Simulation time.
From the literature the bubble should reach its final shape and terminal velocity round about 0.1 Seconds ...
hi would you please tell me, how to make 2D region for bubble emerged in water using openfoam? I tried using setFeildsDic, but i do not know why it does not make a region...I am confused..it should be quit easy...
18210436486 is offline   Reply With Quote
Old   March 8, 2022, 03:54
sadra mahmoudi
sadra2003 is on a distinguished road
Hello Sebastian,
Thank you for the info you provided here.
I am also working on the terminal velocity of bubbles. Using the paraView, I measure the center of a bubble location in two successive time step, then by deviding the displacement of the center of bubble to the time difference, I wannt to calculate the velocity. The problem is, the value that I gain is 50 % lower than the reported values in the literature. I am using a 2D mesh in openFoam 8 using interFoam.
The contents of my 0 folder are:
U file:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
bottom
type noSlip;
outlet
type noSlip;
walls
type slip;
defaultFaces
type empty;
p_rgh file:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
alpha file:
dimensions [0 0 0 0 0 0 0];
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
transportProperties file:
phases (air water);
air
transportModel Newtonian;
nu nu [ 0 2 -1 0 0 0 0 ] 1.5E-5;
rho rho [ 1 -3 0 0 0 0 0 ] 1.18;
water
nu nu [ 0 2 -1 0 0 0 0 ] 7.22E-7;
rho rho [ 1 -3 0 0 0 0 0 ] 995.7;
Thanks a lot.
sadra2003 is offline   Reply With Quote
Old   March 12, 2022, 07:19
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
I simulated a similar case a few years agao. I did not look at the velocity but at they y value of the center of gravity, which is more or less the same. I get decent values only with veryl low values of maxCo, around 0.01.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
Old   March 7, 2024, 18:57
sajad
seju is on a distinguished road
Originally Posted by sadra2003 View Post
Hello Sebastian,
U file:
boundaryField
bottom
type noSlip;
outlet
type noSlip;
walls
type slip;
defaultFaces
type empty;
p_rgh file:
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
alpha file:
boundaryField
bottom
type zeroGradient;
outlet
type zeroGradient;
walls
type zeroGradient;
defaultFaces
type empty;
phases (air water);
air
water
Thanks a lot.
You can see test cases and validations of different bubble regimes in this post:
Validation of Bubble Regime in Openfoam
#openFoam #bubble_velocity #validation #interFoam
seju is offline   Reply With Quote
Bubble rise velocity Miguel CFX 1 December 25, 2006 20:17
terminal velocity in spray dryer weekendwarrior Main CFD Forum 1 February 20, 2006 01:47
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
Terminal velocity of 2D rising bubbles Tony Main CFD Forum 0 June 15, 2004 19:37
Terminal bubble shapes Tony Main CFD Forum 0 February 27, 2002 17:30
