Nonuniform initial condition using cellSetDict
Old   August 24, 2008, 10:13
Default Hi, I'm trying to set diffe
Rina Oldek
rinao is on a distinguished road
I'm trying to set different initial conditions for a set of cells. In the interFoam example, the boxToCell rule was used, hoewver, in my problem the boundary is not rectangular but rather circular.
What are the exact command lines that I should write in the setCellDict?
Should I specify each cell explicitly?
Thanks,
Rina
rinao is offline   Reply With Quote
Old   October 22, 2008, 05:46
Default Hi Kathrin, Thanks for your m
Rina Oldek
Hi Kathrin,
Thanks for your mail.
I have another question: if the blocks have a cyclic side, which command should I use? The code that you sent is for a sphere, which is not the case for me. The block has 3 straight lines and one is cyclic. How should I write the initial conditions?
Thanks again,
Rina
Old   June 22, 2009, 07:31
isabel
isabel is on a distinguished road
I am changing the interFoam tutorial to define a sphere of ratio 1 as initial condition. Does anybody know the error in this setFieldsDict file?
FoamFile
version 2.0;
format ascii;
class dictionary;
object setFieldsDict;
defaultFieldValues
volScalarFieldValue gamma 0
volVectorFieldValue U (0 0 0)
regions
sphereToCell
sphere (0 0 0) (0 0 1);
fieldValues
volScalarFieldValue gamma 1
isabel is offline   Reply With Quote
Old   November 26, 2009, 09:03
Default Answer
Markus_S is on a distinguished road
Correct is that syntax:
sphereToCell
centre (0.02 0.135 0);
radius 0.01;
fieldValues
Markus_S is offline   Reply With Quote
Old   November 9, 2011, 12:30
Concordia_CFD
marzbali is on a distinguished road
Hello all,
does sphereToCell work the same way in 2D axisymmetric cases? The thing is that i want to patch a droplet with this syntax in setFieldsDict, but I get a cylinder instead of a droplet!! I tried funky function and cellSetDict but I got the same cylinder.
Any help is greatly appreciated, thank you.
Marzbali
marzbali is offline   Reply With Quote
Old   January 8, 2013, 13:53
Hossein Yahyazadeh
hossein_y62 is on a distinguished road
Hi every body,
could somebody help me to set an elliptic drop instead?
thanx
hossein_y62 is offline   Reply With Quote
Old   January 9, 2013, 01:42
Daniele Vicario
danvica is on a distinguished road
I've never use it but funkySetFields should work.
See http://openfoamwiki.net/index.php/Co...funkySetFields example at point 5.
In 3D you can use the ellipsoid equation http://en.wikipedia.org/wiki/Ellipsoid
Regards,
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Specifying nonuniform initial condition msyaml OpenFOAM Running, Solving & CFD 65 April 25, 2016 05:23
Specifying nonuniform boundary condition maka OpenFOAM Running, Solving & CFD 59 October 22, 2014 15:52
Initial Condition Tang Kuei FLUENT 0 May 17, 2006 20:54
Nonuniform gradient boundary condition ankgupta8um OpenFOAM Running, Solving & CFD 1 March 14, 2006 02:34
Nonuniform initial conditions nico OpenFOAM Pre-Processing 2 January 4, 2006 07:37
