V2f turbulence model
Like Tree4Likes
Old   October 29, 2012, 11:58
maalan is on a distinguished road
Hi, Alberto!!
First of all thanks for the code! It is useful for me as I work in aerodynamics. My question is: up to the moment I used to running both k-epsilon and k-omega models, and its respectives wall functions for k, epsilon and omega. In addition, I knew how to set up the k and epsilon values in my 0 folder by using the turbulentIntensityKineticEnergyInlet and turbulentMixingLengthDissipationRateInlet boundary conditions. How should I proceed with the v2f model?? the tutorial that comes with the code just set the values for the 4 unknowns...
hope you could help!
Best regards!
Antonio
maalan is offline   Reply With Quote
Old   October 31, 2012, 05:23
Default v2f for OF-1.6
  #62
Could anyone send to me the v2f code for OF-1.6??
Thanks in advance!
Old   October 31, 2012, 13:15
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Hi Antonio,
I'll reply you here. I am not using 1.6-ext right now. But you can post your error message though. Compilation is not that difficult.
But I want to re-state, that I have never had this v2f model work for me (alberto's version and my own version and many others')
So those who have made the code really work, would you please post your results on a simple channel flow?? Because I really think that there is somthing wrong in the code.
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   October 31, 2012, 13:22
Ok!! Thank you for your prompt reply, lakeat!
The point is I have just the OF-1.6 and I am trying to compile the romif codes for such OpenFOAM release. I have set my Make/files and Make/options files as:
Make/files:
DurbinV2F.C
LIB = $(FOAM_USER_LIBBIN)/libmyIncompressibleRASModels
Make/options:
EXE_INC = \
-I$(LIB_SRC)/turbulenceModels \
-I$(LIB_SRC)/transportModels \
-I$(LIB_SRC)/finiteVolume/lnInclude \
-I$(LIB_SRC)/meshTools/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
-I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
-I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude
LIB_LIBS = \
-lincompressibleTurbulenceModel \
-lfiniteVolume \
-lmeshTools \
-lcompressibleRASModels \
-lreactionThermophysicalModels \
-lspecie \
-lbasicThermophysicalModels \
-lgenericPatchFields
After doing wmake, the error which I get is (at the end of the compilation):
Make/linux64GccDPOpt/DurbinV2F.o: In function `Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::magSqr<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam ::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)':
DurbinV2F.C.text._ZN4Foam6magSqrINS_10SymmTensor IdEENS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14G eometricFieldIdT0_T1_EEEERKNS5_INS6_IT_S7_S8_EEEE[Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::magSqr<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<Foam ::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> > const&)]+0x144): undefined reference to `Foam::calculatedFvPatchField<double>::typeName'
Make/linux64GccDPOpt/DurbinV2F.o.data.rel.ro._ZTVN4Foam14incompressib le9RASModels9DurbinV2FE[vtable for Foam::incompressible::RASModels:urbinV2F]+0x70): undefined reference to `Foam::incompressible::RASModel:rintCoeffs()'
Make/linux64GccDPOpt/DurbinV2F.o.data.rel.ro._ZTVN4Foam14incompressib le9RASModels9DurbinV2FE[vtable for Foam::incompressible::RASModels:urbinV2F]+0x78): undefined reference to `Foam::incompressible::RASModel::yPlus(int, double) const'
Make/linux64GccDPOpt/DurbinV2F.o.data.rel.ro._ZTIN4Foam14incompressib le9RASModels9DurbinV2FE[typeinfo for Foam::incompressible::RASModels:urbinV2F]+0x10): undefined reference to `typeinfo for Foam::incompressible::RASModel'
Make/linux64GccDPOpt/DurbinV2F.o.data.rel.ro._ZTIN4Foam11wallFvPatchE[typeinfo for Foam::wallFvPatch]+0x10): undefined reference to `typeinfo for Foam::fvPatch'
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
Thank you for your help!
Best,
Antonio
Old   October 31, 2012, 13:39
dw
1/153 is on a distinguished road
Okay, these cannot be fixed in one reply, Would you mind send you v2f code to me, I'll compile here and send it back to you.
DANIEL_DOT_WEI_AT_ND_DOT_EDU
1/153 is offline   Reply With Quote
Old   October 31, 2012, 14:20
dw
It works here, not sure why you cant make it. I suggest you under
/turbulenceModels/incompressible/RAS folder,
do a "wclean", and "wmake libso" again
Old   October 31, 2012, 14:57
Ok, I have done it: wclean and then wmake libso in the RAS folder, and the the same inside the V2F folder, and I got the next error:
[antonio@gauss0 V2F]$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file DurbinV2F.C
SOURCE=DurbinV2F.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-40 -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/transportModels -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/reactionThermo/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/basic/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/turbulenceModels/incompressible/RAS/lnInclude -IlnInclude -I. -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/antonio/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/DurbinV2F.o
/usr/bin/ld: cannot find -lgenericPatchFields
make: *** [/home/antonio/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libmyIncompressibleRASModels.so] Error 1
Maybe this one is easier to understand!
Old   October 31, 2012, 15:04
dw
I dont know where did you get this Make/options file
Make/options:
EXE_INC = \
LIB_LIBS = \
-lfiniteVolume \
-lmeshTools \
-lspecie \
So, link to genericPatchFields is for Official OF version, so delete it and use the ext version's.
I might be wrong, because the ext version on my computer is not the latest one, just do a double check.
Old   October 31, 2012, 15:14
Ok! Thank you very much, daniel! I was trying to compile it in the cluster... Now, I will try the same with the OF-1.6 release in my PC later. Otherwise I will compile the OF-1.6-ext and I will try again. I will tell you in a short time.
Old   November 5, 2012, 23:00
Default V2-f version for OF-1.6
  #70
Sandy Lee
sandy is on a distinguished road
Hi, I have no new version about V2-f for OF-1.6, and just explicitly give the coefficent values of DurbinV2's version in order to avoid a lookup file, you know. Attachment is it. Who need it?
sandy is offline   Reply With Quote
Old   September 21, 2013, 04:16
s.m
saeideh mohamadi
s.m is on a distinguished road
hi all
is v2f a low re number turbulence model?
thank you
s.m is offline   Reply With Quote
Old   September 21, 2013, 05:27
Default From my knowledge No :)
  #72
Alhasan's Avatar
Hasan K.J.
Alhasan is on a distinguished road
Hey,
From my knowledge and from the Durbin's papers i have read, it is for only high reynolds number since they are interested in heat transfer at stagnation point, the benifit from durbins model is it is very good at stagnation point for high reynolds number !!!
never come across a paper with low re and flow close to the wall for aerofoil or impinging-jet (the only stuff i know lol)
k-kl- is a good low Re i from my knowledge
and still i am a student of life so senior member please correct me if i am wrong
and btw the above model attached is a good v2f model but for some reason i am not fully able to validate all experiments with it, im cent percent sure it needs some corrections
Best Regards,
Hasan K.J
Alhasan is offline   Reply With Quote
Old   January 12, 2016, 19:41
Default Foam warning after running paraFoam
  #73
adhi makayasa
makayasa is on a distinguished road
Hi all,
after running paraFoam, in the terminal to get a message like this
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /home/yasa/OpenFOAM/yasa-2.3.0/platforms/linuxGccDPOpt/lib/libmyIncompressibleRASModels.so: undefined symbol: _ZTIN4Foam14incompressible8RASModelE
FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libmyIncompressibleRASModels.so"
How to fix it? Please help, this is my final assignment
makayasa is offline   Reply With Quote
Old   January 13, 2016, 11:35
Default error in v2f
  #74
hamide hayati
hamide is on a distinguished road
hello friends
i'm new in openfoam
i wanna model turbulence flow with v2f model. in the tutorial there isn't any example for this model. i copied one of k-epsilon tutorials and changed it's B.C to what i want. but i faced to an error!!!!
should i add any thing to fvSolution file? is it necessary to change other things?
the error is shown below:
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.2.0-5be49240882f
Exec : pisoFoam
Date : Jan 13 2016
Time : 18:31:56
Host : "hamide-HP-ProBook-4530s"
PID : 4096
Case : /home/hamide/run/tutorials/incompressible/pisoFoam/ras/aaaaV2f
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model v2f
bounding v2, min: 0 max: 0.0625 average: 0.0625
v2fCoeffs
Cmu 0.22;
CmuKEps 0.09;
C1 1.4;
C2 0.3;
CL 0.23;
Ceta 70;
Ceps2 1.9;
sigmaK 1;
sigmaEps 1.3;
Starting time loop
Time = 5e-05
Courant Number mean: 0.0003125 max: 0.529571
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 7.05865e-06, No Iterations 7
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 9.57628e-06, No Iterations 7
DICPCG: Solving for p, Initial residual = 1, Final residual = 0.098608, No Iterations 539
time step continuity errors : sum local = 6.163e-05, global = -8.17162e-07, cumulative = -8.17162e-07
DICPCG: Solving for p, Initial residual = 0.0235598, Final residual = 9.65185e-07, No Iterations 582
time step continuity errors : sum local = 1.48876e-06, global = -1.1141e-10, cumulative = -8.17274e-07
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
#6 Foam::incompressible::RASModels::v2f::correct() in "/opt/openfoam220/platforms/linux64GccDPOpt/lib/libincompressibleRASModels.so"
in "/opt/openfoam220/platforms/linux64GccDPOpt/bin/pisoFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
Floating point exception (core dumped)
would you please help me?
hamide is offline   Reply With Quote
Old   January 15, 2018, 08:19
Default do anyone knows why v2-f should not be used in Eulerian multiphase problems
  #75
Diogo R.C.B. Neves
dneves is on a distinguished road
Hi everyone
I am a little puzzled because the https://www.cfd-online.com/Wiki/V2-f_models
sais that v2-f turbulence model should not be applied to solve eulerian multifase problems.
Why is that?...?
I am testing a multifase problem (sea waves breaking) and it works fine...I don't understant why should I not use it.
Can anyone enlight me?
Best regards
dneves is offline   Reply With Quote
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 13:12
turbulence model greg FLUENT 3 August 26, 2006 12:07
v2-f model of turbulence abdellah FLUENT 2 February 27, 2005 01:49
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? Mirek Kabacinski FLUENT 5 August 24, 2003 23:31
k-w turbulence model allan Main CFD Forum 4 February 20, 2002 14:05
