October 23, 2008, 16:20 |
Dear all,
I would like to use
Dear all,
I would like to use snappyhexmesh to mesh the hull of a boat in a blockmesh background mesh and then, using interfoam/interdymfoam work out how the boat reacts (rising, falling, moving due to the water). i have manage to get the boat in there and to fill the domain with some water and by adding a velocity at an inlet i work out that the flow around the boat looks resonable. though i have not worked out how to get the boat to move when the water is flowing at it. i tried the 3d3dof tutorial but then my boat stays put and the blockmesh domain is moving. also it does not seems right that i specify the parameters, they should be calculated from the flow. did anyone do something similar? how can i specify that the beat should be moving with 2 och 3 dof? would be happy for any input. thanks Erik |
October 24, 2008, 05:53 |
just to make it clearer i here
just to make it clearer i here add the right terms: i like to ship to react by heaving (moving up/down) and pitching (tilting backward/forward).
thanks Erik |
simple rigid body motion UDF | Dan | FLUENT | 0 | January 11, 2006 06:48 |
Dynamic meshing: UDF for rigid body Motion | Manoj Kumar | FLUENT | 0 | June 20, 2005 02:02 |
Define the motion of rigid-body CG using profiles! | ducvinh | FLUENT | 2 | October 2, 2004 03:50 |
rigid body motion | antonello | FLUENT | 3 | July 28, 2004 04:25 |
Rigid Body Motion in Eulerian Grid | Zi-Wei Chiou | Main CFD Forum | 0 | November 14, 2001 23:39 |
