FixedFluxPressure cannot find field 1%7cAU
Old   September 22, 2008, 09:08
Default Hello, I'm stumbling across
Thomas Wolfanger
anger is on a distinguished road
I'm stumbling across the same error.
I think that it has to do with a missing volScalarField, but I have no idea how to register this field in the objectRegistry.
Anybody knows what to do to get the fixedFluxPressure boundary condition running with (simple)Foam?
Best regards,
-Thomas
anger is offline   Reply With Quote
Old   September 22, 2008, 11:53
Default Declare a field called 'rUA' i
Sandeep Menon
deepsterblue will become famous soon enough
Declare a field called 'rUA' in createFields.H, like this:
volScalarField rUA
IOobject
"(1|A(U))",
runTime.timeName(),
mesh
mesh,
dimensionedScalar("rUA", dimTime, 1),
zeroGradientFvPatchScalarField::typeName
And call:
rUA = 1.0/UEqn.A();
inside the PISO loop.
Sandeep Menon
University of Massachusetts Amherst
https://github.com/smenon
deepsterblue is offline   Reply With Quote
Old   September 23, 2008, 05:15
Default Hello Sandeep, thank you fo
Thomas Wolfanger
Hello Sandeep,
thank you for your help, this works.
Just foor the books: a little typo occured in the last equation which should read
rUA = 1.0/UEqn().A()
I put this in pEqn.H
Best regards,
-Thomas
Old   November 10, 2008, 06:50
Default hi to all I want to simulat
emilianyassenov
hi to all
I want to simulate in straight pipe to include some
heat flow and to see temperature increasing...
which solver I should use...
can anyone help me
EMO
FFT on flow field to find peaks? CFDtoy Main CFD Forum 17 June 7, 2011 07:34
Putting submesh field values into field on parent mesh helmut OpenFOAM Running, Solving & CFD 2 June 20, 2006 08:31
How can I find maximum of a field Q FLUENT 2 November 9, 2005 05:00
where to find velocity field for square pipes??? enrico Main CFD Forum 2 February 4, 2005 12:32
I wish to find the proper model to validate the temperature field. G.H.Lee Main CFD Forum 1 May 6, 1999 03:05
