SimpleFoam convergence problems
Like Tree29Likes
Old   June 9, 2015, 10:09
KateEisenhower is on a distinguished road
Originally Posted by s.m View Post
Hi Dear cem,
i wana you to say me if i understand your explenation above rigth or not?
i unerstand that,
first we should write potentialFoam instead of simoleFoam in controlDict, after some iteration we should turn the turbulence off in RAS properties, and then after some iteration we should set the turbulence on in RAS properties, is it rigth?
thank you very uch
Hi saeideh,
No, you should start simpleFoam with turbulence turned off. Lateron you can turn turbulence on again.
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 20:39
SimpleFoam Convergence problem skabilan OpenFOAM Running, Solving & CFD 6 May 31, 2013 04:21
SimpleFoam solution convergence pattern philippose OpenFOAM Running, Solving & CFD 0 June 26, 2008 15:18
SimpleFoam problems with converging maybe skewness hoochie OpenFOAM Running, Solving & CFD 4 May 14, 2007 08:23
SimpleFoam convergence problems schnitzlein OpenFOAM Running, Solving & CFD 6 June 24, 2005 10:51
