HELP NEEDED with TURBFOAM
Old   May 28, 2008, 02:50
Default i have posted boundary conditi
  #41
Mohd Yousuf
yousuf is on a distinguished road
i have posted boundary conditions, check mesh results and div schemes.........have a look at them
yousuf is offline   Reply With Quote
Old   May 29, 2008, 11:16
Default I'm running your case, and res
  #42
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
I'm running your case, and results i will obtain tomorrow.
velocity speed 73.9 m/s is for this mesh (convertion factor .0254)?
so, when you was running for convertion factor 1 and 25.4 does you change velocity speed also?
why are you using 'slip' for periodic walls? (not 'cyclic')?
mkraposhin is offline   Reply With Quote
Old   May 29, 2008, 12:00
Default i'm trying turbFoam variant, w
  #43
mkraposhin's Avatar
Matvey Kraposhin
i'm trying turbFoam variant, with div settings for
div(phi,k) and div(phi,epsilon):
div(phi,k) Gauss upwind;
div(phi,epsilon) Gauss upwind;
and it converges (11 iterations), but epsilon is still bounded
because it takes approx 2-3 minutes for each iteration, i will report you about results tomorrow
Old   August 1, 2008, 04:28
Default hi all i am trying to do an
  #44
mayank gupta
mgz1985 is on a distinguished road
hi all
i am trying to do an incompressible flow over a 2D airfoil. everything seems to be fine. my mesh check is OK.when i run icoFoam i get the following error
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
i am new to openfoam and this is my first test case after having practiced thru the tutorials. I ahd set the faces in the z-direction to empty as mentioned in the user guide.
can ne1 help?
thanx
mgz1985 is offline   Reply With Quote
Old   August 1, 2008, 04:51
Default Hi It would mean that you h
  #45
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi
It would mean that you have added cells in the z-direction but still uses empty on the x-y-normal patches, which means that there are no boundary conditions for the z-direction.
/ Niels
P.S. Sometime I have experienced that the boundary file is not updated even though you make a blockMesh. Thus try to delete /case/constant/polyMesh/boundary and see if that helps.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   August 1, 2008, 05:37
Default hi neil, i dont understand
  #46
mayank gupta
hi neil,
i dont understand the meaning of setting the BC for the empty patches. if u do not mind can u elaborate.yeah i have just 1 cell in the z-direction as mentioned in the tutorials. i deleted the boundary file and tried but did not help. same error.
i m putting my U boundaries here.
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
movingWall
type fixedValue;
value uniform (-55.55 0 0);
fixedWall
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
Old   August 1, 2008, 06:02
Default Could you please upload your c
  #47
ngj
Could you please upload your case and I'll take a look at it.
/ Niels
Old   August 1, 2008, 06:24
Default convertToMeters 0.001; vert
  #48
mayank gupta
vertices
(181 -27.39 0)
(209.26 61.17 0)
(600 0.19 0)
(600 500 0)
(209.26 500 0)
(181 -500 0)
(600 -500 0)
(181 -27.39 1)
(209.26 61.17 1)
(600 0.19 1)
(600 500 1)
(209.26 500 1)
(181 -500 1)
(600 -500 1)
(2000 500 0)
(2000 -500 0)
(2000 500 1)
(2000 -500 1)
blocks
hex (0 1 4 5 7 8 11 12) (60 50 1) simpleGrading (1 1 1)
hex (0 5 6 2 7 12 13 9) (50 30 1) simpleGrading (1 1 1)
hex (1 2 3 4 8 9 10 11) (30 50 1) simpleGrading (1 1 1)
hex (3 6 15 14 10 13 17 16) (60 50 1) simpleGrading (1 1 1)
edges
polyLine 0 1 (
(151.99 -26.69 0)
(122.49 -25.57 0)
(92.87 -23.67 0)
(63.09 -20.64 0)
(48.1 -18.59 0)
(32.99 -15.91 0)
(17.63 -11.97 0)
(9.72 -8.96 0)
(6.43 -7.24 0)
(4.73 -6.13 0)
(0 0 0)
(1.27 7.88 0)
(2.56 9.7 0)
(5.28 12.72 0)
(12.37 18.52 0)
(27.01 27.09 0)
(41.9 33.62 0)
(56.91 39 0)
(87.13 47.45 0)
(117.51 53.7 0)
(148 58.21 0)
(178.58 61.17 0)
polyLine 7 8(
(151.99 -26.69 1)
(122.49 -25.57 1)
(92.87 -23.67 1)
(63.09 -20.64 1)
(48.1 -18.59 1)
(32.99 -15.91 1)
(17.63 -11.97 1)
(9.72 -8.96 1)
(6.43 -7.24 1)
(4.73 -6.13 1)
(0 0 1)
(1.27 7.88 1)
(2.56 9.7 1)
(5.28 12.72 1)
(12.37 18.52 1)
(27.01 27.09 1)
(41.9 33.62 1)
(56.91 39 1)
(87.13 47.45 1)
(117.51 53.7 1)
(148 58.21 1)
(178.58 61.17 1)
polyLine 4 5 ((-1000 500 0) (-1000 -500 0))
polyLine 11 12 ((-1000 500 1) (-1000 -500 1))
polyLine 0 2 (
(210.74 -27.35 0)
(239.87 -26.76 0)
(269.09 -25.82 0)
(298.62 -24.49 0)
(328.36 -22.81 0)
(358.25 -20.8 0)
(388.27 -18.51 0)
(408 -16.89 0)
(448.6 -13.44 0)
(490.2 -9.92 0)
(509.15 -8.37 0)
(539.44 -5.79 0)
(569.74 -0.19 0)
polyLine 7 9 ( (210.74 -27.35 1)
(239.87 -26.76 1)
(269.09 -25.82 1)
(298.62 -24.49 1)
(328.36 -22.81 1)
(358.25 -20.8 1)
(388.27 -18.51 1)
(408 -16.89 1)
(448.6 -13.44 1)
(490.2 -9.92 1)
(509.15 -8.37 1)
(539.44 -5.79 1)
(569.74 -0.19 1)
polyLine 1 2 (
(270.92 60.74 0)
(301.38 57.75 0)
(331.64 53.76 0)
(361.75 48.94 0)
(391.73 43.47 0)
(421.6 37.5 0)
(451.39 31.24 0)
(472 26.86 0)
(481.13 24.92 0)
(510.84 18.6 0)
(512.25 18.3 0)
(516 17.34 0)
(520.2 16.62 0)
(540.56 12.32 0)
(570.25 6.15 0)
polyLine 8 9 (
(270.92 60.74 1)
(301.38 57.75 1)
(331.64 53.76 1)
(361.75 48.94 1)
(391.73 43.47 1)
(421.6 37.5 1)
(451.39 31.24 1)
(472 26.86 1)
(481.13 24.92 1)
(510.84 18.6 1)
(512.25 18.3 1)
(516 17.34 1)
(520.2 16.62 1)
(540.56 12.32 1)
(570.25 6.15 1)
patches
wall movingWall
(0 1 8 7)
(0 2 9 7)
(1 8 9 2)
wall fixedWall
(3 6 13 10)
(3 10 16 14)
(6 13 17 15)
(3 4 11 10)
(4 5 12 11)
(5 6 13 12)
empty frontAndBack
(0 1 4 5)
(0 2 6 5)
(1 2 3 4)
(3 6 15 14)
(10 13 17 16)
(7 8 11 12)
(7 9 13 12)
(8 9 10 11)
mergePatchPairs
that is my blockMeshDict
Re is 1.67 million
U is 200kph
thanx a lot neil for ur patience
Old   August 1, 2008, 07:05
Default Please zip the ENTIRE case, as
  #49
ngj
Please zip the ENTIRE case, as that is what I need.
/ Niels
Old   August 1, 2008, 07:31
Default /home/frpelikan/OpenFOAM/mayan
  #50
mayank gupta
/home/frpelikan/OpenFOAM/mayank/tutorials/icoFoam/check8.tar.gz
Old   August 1, 2008, 07:39
Default can u tell me how to paste a z
  #51
mayank gupta
can u tell me how to paste a zipped folder here. I have never done it b4 and dont c an option to do it
thanx
Old   August 1, 2008, 07:49
Default Look under the /Documentation/
  #52
ngj
Look under the /Documentation/Formatting to your left on the Message Board.
Old   August 1, 2008, 07:59
Default \attach
  #53
mayank gupta
\attach
Old   August 1, 2008, 08:00
Default http://www.cfd-online.com/Ope
  #54
mayank gupta
Mayank_Gupta.zip
Old   August 1, 2008, 08:01
Default thanx neils for teaching how t
  #55
mayank gupta
thanx neils for teaching how to attach in a post.
Old   August 1, 2008, 09:47
Default hi neils any luck . I trie
  #56
mayank gupta
hi neils
any luck . I tried after changing the cell thickness also but same error.
Old   August 1, 2008, 10:54
Default The problem is present, becaus
  #57
ngj
The problem is present, because you have two regions, which are not connected. One of these (or both), has not been defined in the blockMesh file, thus they are given 'empty' as it belong to defaultFaces.
These patches are between the two regions just downstream the airfoil. You will definitely not get the results you anticipate using that mesh. You need to make some connection between the two regions.
/ Niels
Old   August 1, 2008, 11:50
Default which patch r u xactly talking
  #58
mayank gupta
which patch r u xactly talking bout. I have all the patches attached.
downstream of the airfoil in block 3 i have 1 internal face and the 5 external faces are defined
(3 6 15 14)
(10 13 17 16)
(3 6 13 10) (this is the internal face and i tried without it also
(3 10 16 14)
(6 13 17 15)
(14 15 16 17 ) (the software fails to recognize this face)
all my patches are connected at the internal faces and i do not define them
did the solver run at your system
thanks
Old   August 1, 2008, 12:00
  #59
mayank gupta
(3 6 15 14)
(10 13 17 16)
(3 10 16 14)
(6 13 17 15)
thanks
Old   August 1, 2008, 13:28
Default thanx neils figured out wha
  #60
mayank gupta
thanx neils
figured out what u meant. but i have a question, i was working with I-DEAS for meshing. And it allows the meshing. i was trying that as i am new to openfoam
thanx again.
Problem with turbFoam skabilan OpenFOAM Running, Solving & CFD 2 September 29, 2008 18:43
Turbfoam error danie OpenFOAM Running, Solving & CFD 2 July 30, 2008 08:45
TurbFoam hsieh OpenFOAM Running, Solving & CFD 12 July 23, 2008 08:40
Error turbFoam jackdaniels83 OpenFOAM Running, Solving & CFD 11 June 27, 2007 15:22
Oodles vs turbFoam rolando OpenFOAM Running, Solving & CFD 9 June 4, 2007 06:42
