May 8, 2008, 04:57 |
Yes, LaunderSharma k-epsilon m
#21 |
Matvey Kraposhin
Rep Power: 21 |
Yes, LaunderSharma k-epsilon model is low-Re, but (on my opinion) you have fully-developed turbulent regime (1.0E+6 > 3.0E+5=Re_critical for sphere) and you can use k-epsilon with standard wall-functions, and y+ (for k-epsilon model) should be in range 30-150. May be your task is to use low-Re model in boudary layer and k-epsilon in freestream...
today i'll download mesh and try it...
MDPI Fluids (Q2) special issue for OSS software: https://www.mdpi.com/journal/fluids/..._modelling_OSS GitHub: https://github.com/unicfdlab Linkedin: https://linkedin.com/in/matvey-kraposhin-413869163 RG: https://www.researchgate.net/profile/Matvey_Kraposhin |
May 8, 2008, 05:56 |
What command line arguments ar
#22 |
Matvey Kraposhin
Rep Power: 21 |
What command line arguments are you using?
I use plot3dToFoam . . -noBlank raetaf.x.fmt -2D 0.1 -singleBlock -scale 0.333 where 0.1 = 0.1ft (10% of airfoil chord length, which is 1ft, as mentioned on nasa.gov site) -scale = 0.333 = convertion factor from [ft] to [m], because OpenFOAM uses metric (SI) system after conversion, i found, that: mesh has 66 high skewed faces (~12000%) - this VERY BAD and some very small edges. this is not good too.
May 8, 2008, 06:36 |
Hi there,
Doesn't "Low-Re t
#23 |
Steve Collie
Rep Power: 17 |
Hi there,
Doesn't "Low-Re turbulence model" merely mean that it solves through the "low-re " (or Re_t) region of the flow, i.e. the viscous sublayer -> it doesn't use wall functions. I don't think it matters what "global reynolds number" you have, it is still suitable as long as the flow isn't laminar or transitional. That said I seem to recall that it is a very stiff model (so can cause slow convergence) and has poorly defined boundary conditions at the wall (epsilon is undefined). A model like Spalart-Almaras which solves for nu_t (zero at the wall) might run better and has shown better accuracy for aerodynamic problems than k-epsilon models. There is also the SST model but as far as I can see the version in openFoam 1.4.1 is not a low reynolds number implementation, you have to use wall functions and a y+>30. Does anybody know if there is a Low-Re version of the SST out there?. Cheers, Steve |
May 8, 2008, 07:06 |
Hi all
In the SST model the
#24 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi all
In the SST model the viscosity is the effective viscosity, thus that would make it possible to simulate all the way through the viscous sublayer, as nuEff = nuT + nuVisc. Thus it should be possible to apply kOmegaSST to your problem, as you are already having a fine resolution at the wing. The only thing which needs to be done (do not know if it is already implemented), is a boundary condition for omega. Enjoy this sunny day Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
May 8, 2008, 12:02 |
Leonardo Nettis, i have conver
#25 |
Matvey Kraposhin
Rep Power: 21 |
Leonardo Nettis, i have converted your mesh, and despite of high skewness at some faces, simpleFoam (steady-state solver) produces stable result with Launder-Sharma k-e model, now, i'm running LES simulation with Spalar-Allmaras model, using soultion from simpleFoam. time-step is very low (5*10E-7) and after first output i can send case to your e-mail.
maybe i'm mistaken about low-re models - it seems that they are could be used with high Re numbers in freestream. however, one-eq Spalart-Almaras model is more suitable for your task
May 8, 2008, 16:14 |
ok, thank you very much krapos
#26 |
Leonardo Nettis
Rep Power: 17 |
May 12, 2008, 12:08 |
Hi Matvey,
I've checked the
#27 |
Leonardo Nettis
Rep Power: 17 |
Hi Matvey,
I've checked the y+ in the LSKE steady case you sent me, with the refined grid made with salome, but its range is 6-25 that is not so acceptable. Anyway since I think I'm going to further reduce the cell size near the wall on your mesh, could you please tell me which utility you used in OF to achieve this purpose?? Thank you again LN |
May 12, 2008, 16:05 |
O, i'm sorry, i'm keeping many
#28 |
Matvey Kraposhin
Rep Power: 21 |
O, i'm sorry, i'm keeping many versions at once (to reverse to old, if something goes wrong)
utility is called refineWallLayer it takes 4 parameters: case root (.) case name (.) patch name (walls) edgeWeight (0 to 1) for example, if you want near-wall distance to be twice smaller, you need to type: refineWallLayer . . walls 0.5 if you need near-wall distance to be ten times smaller, type refineWallLayer . . walls 0.1 utitlity alghorithm splits near-wall cells in patch normal direction by weighting factor and introduces new cells into the mesh, then the new mesh is written in time, one after the latest be careful, the best way - is to step by step experiment with utility and checking mesh for errors after each improvement.
May 13, 2008, 11:16 |
I've just tried to reduce the
#29 |
Leonardo Nettis
Rep Power: 17 |
I've just tried to reduce the near wall cell with an edgeweight equal to 0.5. Then I run checkMesh and the test failed for the High aspect ratio cells near the wall. Moreover I've tried to run simplefoam and the solution did not converge!
Maybe the solution could be to reduce the 3rd direction size. Did you create a 2d mesh?? Is this file located in the folders you sent me (so that I can import it in OF with a smaller z-dir size)? If not could you please send me that? Thank you again LN |
May 14, 2008, 07:57 |
1) contents of directory stead
#30 |
Matvey Kraposhin
Rep Power: 21 |
1) contents of directory steady_SAL:
0 - intial values 2 - mesh with refined boundaryLayer 202 - values after 200 iterations with mesh, contained in 2 constant - initial mesh system - system so, may be you need to delete directory 2 and try to refine mesh again 2) the mesh is 2D (patches empty1 and empty2 are front and back planes of solution domain) 3) i think, it would be better to use next BC for variables: U inlet - fixedValue (33 0 0) walls fixedValue (33 0 0) outlet,top,bottom - pressureInletOutletVelocity (33 0 0) and internal field = (0 0 0) p inlet - zeroGradient walls - zeroGradient outlet,top,bottom - totalPressure {p0=0, gamma=0, phi=phi, U=U, rho=none, psi=none} k,epsilon inlet - fixedValue walls,outlet,top,bottom - zeroGradient epsilon should be estimated as C_mu^(0.75)*k^(1.5)/l_m where l_m can be estimated as 0.09*D, where D is airfoil chord length (25.4cm=0.254m)
May 19, 2008, 02:17 |
Hi, I'm also facing a problem
#31 |
Mohd Yousuf
Rep Power: 17 |
Hi, I'm also facing a problem similar to this.
I have a mesh, while converting mesh once i did it using converttometers parameter as 1 in this case SimpleFoam is working properly but when i used converttometre as .0254 i'm facing many problems........ after 20 iterations simplefoam is giving error message ....... i tried using turbfoam but after 9 iterations suddenly courant number is increasin from 0.6 to 1800. This is the result of checkmesh Create polyMesh for time = constant Time = constant Mesh stats points: 160886 edges: 1048848 faces: 1739328 internal faces: 1666132 cells: 851365 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 851365 polyhedra: 0 Checking topology... Boundary definition OK. Point usage OK. Upper triangular ordering OK. Topological cell zip-up check OK. Face vertices OK. Face-face connectivity OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces ... Patch Faces Points Surface wall1_periodic 15174 7764 ok (not multiply connected) wall2_periodic 15158 7756 ok (not multiply connected) top_wall 11701 6075 ok (not multiply connected) blade 27559 13844 ok (not multiply connected) air_inlet 1802 968 ok (not multiply connected) air_outlet 1802 968 ok (not multiply connected) Checking geometry... Domain bounding box: (-0.198391 -0.0421182 -1.10082e-08) (0.096859 0.0421504 0.123191) Boundary openness (4.82454e-17 -1.29423e-15 1.80607e-15) OK. Max cell openness = 1.83721e-16 OK. Max aspect ratio = 7.81529 OK. Minumum face area = 4.58532e-08. Maximum face area = 4.63974e-05. Face area magnitudes OK. Min volume = 1.47244e-11. Max volume = 9.59112e-08. Total volume = 0.00151722. Cell volumes OK. Mesh non-orthogonality Max: 68.9708 average: 21.8092 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.955689 OK. Min/max edge length = 0.000213567 0.0119259 OK. All angles in faces OK. All face flatness OK. Mesh OK. End |
May 19, 2008, 06:00 |
What BC's are you using?
Also
#32 |
Matvey Kraposhin
Rep Power: 21 |
Also, write about your relaxation factors and "div" descritisation schemes
May 19, 2008, 06:27 |
wall1_periodic
#33 |
Mohd Yousuf
Rep Power: 17 |
wall1_periodic
{ type patch; physicalType slip; } wall2_periodic { type patch; physicalType slip; } top_wall { type wall; physicalType wallFunctions; } blade { type wall; physicalType wallFunctions; } air_inlet { type patch; physicalType inlet; } air_outlet { type patch; physicalType pressureOutlet; } //div schemes divSchemes { default none; div(phi,U) Gauss upwind; div(phi,k) Gauss upwind; div(phi,epsilon) Gauss upwind; div(phi,R) Gauss upwind; div(R) Gauss linear; div(phi,nuTilda) Gauss upwind; div((nuEff*dev(grad(U).T()))) Gauss linear; } //relaxation factors relaxationFactors { p 0.3; U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } basically when i import mesh with scale factor 1 it is working fine and with 25.4 this is working fine till now but i want to use for .0254(required for project) where it is not working properly..... can u suggest few changes that can help |
May 23, 2008, 23:22 |
mohd yousuf,
is your case 3D
#34 |
Matvey Kraposhin
Rep Power: 21 |
mohd yousuf,
is your case 3D or 2D?
May 26, 2008, 00:00 |
hi matj,
Sorry for la
#35 |
Mohd Yousuf
Rep Power: 17 |
hi matj,
Sorry for late reply it was weekend here. My case is a 3D case.Now i'm trying to solve the case using turbFoam. |
May 26, 2008, 11:16 |
are you using tet-mesh, or hex
#36 |
Matvey Kraposhin
Rep Power: 21 |
are you using tet-mesh, or hex?
try relaxations factors 0.1 for all variables for the first 100-200 iterations (in simpleFoam) can you send your case?
May 27, 2008, 01:43 |
Hi Matvej,
I'm using tetrah
#37 |
Mohd Yousuf
Rep Power: 17 |
Hi Matvej,
I'm using tetrahedral mesh. Basically i somehow solved the problem for simplefoam case now i'm working in turbfoam case. In this case courant no. suddenly increases after few iterations. I have posted checkmesh results above do have a look Just now i have fired a run. Will mail you the case in nearly 8hrs from now. |
May 27, 2008, 07:21 |
hey again,
Matvej......I ha
#38 |
Mohd Yousuf
Rep Power: 17 |
hey again,
Matvej......I have seen that most of the times epsilon in my calculations get bounded.....and also somtimes it converges or diverges....... how can we prevent any quantity from getting bounded??? sometimes it fails when i calculate k and epsilon by formula given by few in this forum . is there any other way for calculating k and epsilon or is there any other slution |
May 28, 2008, 02:26 |
if epsilon is always bounded,
#39 |
Matvey Kraposhin
Rep Power: 21 |
if epsilon is always bounded, than it means, that turbulence model diverges
what formula are u using? k=1.5*( (I*u_i)**2), I=0.01 (1%) epsilon=C_mu^0.75*k**(1.5)/l, l=0.07*D_c (D_c - cylinder diameter) are you using low-re model or wall functions?
May 28, 2008, 02:37 |
i'm using the same formula u m
#40 |
Mohd Yousuf
Rep Power: 17 |
i'm using the same formula u mentioned
but l=.05(5%) i dont have much idea wat you mean by low-re or wallfunctions.......if you are talking of walls than i'm using wall-functions and regarding velocity it is 73.9 and nu is 1.789e-5 |
Problem with turbFoam | skabilan | OpenFOAM Running, Solving & CFD | 2 | September 29, 2008 18:43 |
Turbfoam error | danie | OpenFOAM Running, Solving & CFD | 2 | July 30, 2008 08:45 |
TurbFoam | hsieh | OpenFOAM Running, Solving & CFD | 12 | July 23, 2008 08:40 |
Error turbFoam | jackdaniels83 | OpenFOAM Running, Solving & CFD | 11 | June 27, 2007 15:22 |
Oodles vs turbFoam | rolando | OpenFOAM Running, Solving & CFD | 9 | June 4, 2007 06:42 |
