October 2, 2008, 09:06 |
dear all!
i m about to stud
Aram Amouzandeh
Rep Power: 17 |
dear all!
i m about to study the buoyantSimpleRadiationFoam solver and the appropriate tutorial case hotRadiationRoom. i found two different (marshak) bc for the variable G: 1) MarshakRadiation: Radiation temperature taken from calculated temperaure 2) MarshakRadiationFixedT: Radiation temperature specified 1) seems to be clear; for 2) a "radiation temperature" Trad needs to be specified, as an error message informed me, by the keywords "uniform" or "nonuniform": type MarshakRadiationFixedT; Trad nonuniform; emissivity 1; value uniform 0; with this bc i get the following error message: attempt to read beyond EOF file: /home/E202/aa/OpenFOAM/aa-1.5.x/run/tutorials/buoyantSimpleRadiationFoam/hotRadi ationRoom/0/G::Trad at line 50. From function ITstream::read(token& t) in file db/IOstreams/Tstreams/ITread.C at line 64. FOAM exiting honestly i do not understand the MarshakRadiationFixedT bc, in other words i have no idea what Trad should be. i would greatly appreciate any comments!! thx in advance! aram |
October 2, 2008, 09:43 |
Try:
Eugene de Villiers
Rep Power: 21 |
Try:
type MarshakRadiationFixedT; Trad nonuniform 300; emissivity 1; value uniform 0; Also, remember all temperatures are in Kelvin. |
October 2, 2008, 11:29 |
thx eugene!
i tried but get
Aram Amouzandeh
Rep Power: 17 |
thx eugene!
i tried but get the same error message again. my main problem is that i have not been able to figure out the difference between the two Marshak bc yet ... aram |
October 2, 2008, 12:26 |
My mistake:
type MarshakRad
Eugene de Villiers
Rep Power: 21 |
My mistake:
type MarshakRadiationFixedT; Trad uniform 300; emissivity 1; value uniform 300; If you want to specify "nonuniform" it has to be followed by a list of values the size of the boundary, like: value nonuniform List<scalar> (88 763 ... 789 423); |
October 3, 2008, 06:03 |
ok, like this it works. now i
Aram Amouzandeh
Rep Power: 17 |
ok, like this it works. now i can study the difference between the two bcs.
thanks a lot! aram |
October 3, 2008, 06:17 |
Aram Amouzandeh
Rep Power: 17 |
November 11, 2008, 06:25 |
i would like to use the
Pattyn Eric
Rep Power: 17 |
i would like to use the constant absorptionemission model (coefficients are present in my constant/radiationproperties file for a simple radiation case. Why this model is not present in OpenFoan-1.5/src/thermophysicalModels/radiation/radiationModel ? I just have P1, noreadiation and radiationModel directories. I'm also wondering how the P1 model works. Is there any documentation i should read? I don't have see informations on thsi forum or in the user / Programmer's guide. Thank you Eric |
