Moving mesh part 2
Like Tree1Likes
Old   January 15, 2008, 18:49
Default OpenFOAM/OpenFOAM-1.4.1/bin/mp
  #21
Mattijs Janssens
mattijs is on a distinguished road
OpenFOAM/OpenFOAM-1.4.1/bin/mpirunDebug? Or could be that I put it there.
mpirunDebug
mattijs is offline   Reply With Quote
Old   January 29, 2008, 18:02
Default Hi Frank, How are you doing
  #22
sek
Sung-Eun Kim
sek is on a distinguished road
Hi Frank,
How are you doing, my friend? Clearly you're making progress!
Would you mind making your simple moving/deforming, FSI cases availabble to others?
SE
sek is offline   Reply With Quote
Old   January 29, 2008, 18:25
Default Hi Sung-Eun! Nice to hear f
  #23
Frank Bos
lr103476 is on a distinguished road
Hi Sung-Eun!
Nice to hear from you! Basically, I am preparing to share a small collection of different dynamic mesh classes, involving: 1 moving body, 2 moving bodies, with and without subsetMeshes and some applied (defined) flexibility. Unfortunately, I have done only little on FSI, since for my problem I know the wing motion / flexing, so there is no need to couple the forces to the structure. But I do have some test cases which I will share.
If you need anything on the short term, please drop me an email....
Regards, Frank
PS: maybe we can meet in Milan at the OF workshop ??
Frank Bos
lr103476 is offline   Reply With Quote
Old   January 29, 2008, 20:23
Default Hi, Frank, I am wondering i
  #24
Pei-Ying Hsieh
hsieh is on a distinguished road
Hi, Frank,
I am wondering if you can send me your dynamic mesh stuffs when you are ready?
Thanks!
Pei
email: phsieh2005@yahoo.com
hsieh is offline   Reply With Quote
Old   March 6, 2008, 15:08
Default I'm also having problems runni
  #25
Kevin Smith
kev4573 is on a distinguished road
I'm also having problems running the mesh subset motion solver in parallel. Here is the error which occurs right away when trying to run in parallel.
Selecting dynamicFvMesh subsetMotionSolverFvMesh
Selecting motion solver: laplaceFaceDecomposition
Selecting motion diffusivity: quadratic
*** glibc detected *** malloc(): memory corruption: 0x0000000000791140 ***
*** glibc detected *** malloc(): memory corruption: 0x0000000000811220 ***
[compute-2-1:13295] *** Process received signal ***
[compute-2-1:13295] Signal: Aborted (6)
[compute-2-1:13295] Signal code: (-6)
[compute-2-1:13295] [ 0] /lib64/tls/libc.so.6 [0x35b802e2b0]
[compute-2-1:13295] [ 1] /lib64/tls/libc.so.6(gsignal+0x3d) [0x35b802e21d]
[compute-2-1:13295] [ 2] /lib64/tls/libc.so.6(abort+0xfe) [0x35b802fa1e]
[compute-2-1:13295] [ 3] /lib64/tls/libc.so.6 [0x35b8063291]
[compute-2-1:13295] [ 4] /lib64/tls/libc.so.6 [0x35b8069881]
[compute-2-1:13295] [ 5] /lib64/tls/libc.so.6(malloc+0x92) [0x35b806b272]
[compute-2-1:13295] [ 6] /usr/lib64/libstdc++.so.6(_Znwm+0x2a) [0x35b91af50a]
[compute-2-1:13295] [ 7] /usr/lib64/libstdc++.so.6(_ZNSs4_Rep9_S_createEmmRKSaIcE+0x7e ) [0x35b919024e]
[compute-2-1:13295] [ 8] /usr/lib64/libstdc++.so.6 [0x35b919260b]
[compute-2-1:13295] [ 9] /usr/lib64/libstdc++.so.6(_ZNSsC2EPKcRKSaIcE+0x43) [0x35b9192783]
[compute-2-1:13295] [10] /home/krs289/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt/libfiniteVolume.so( _ZN4Foam12fvMeshS
ubset18setLargeCellSubsetERKNS_4ListIiEEiib+0x605) [0x2a9688b1f5]
[compute-2-1:13295] [11] /home/krs289/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt/libfiniteVolume.so( _ZN4Foam12fvMeshS
ubset18setLargeCellSubsetERKNS_7HashSetIiNS_4HashI iEEEEib+0x141) [0x2a9688d451]
[compute-2-1:13295] [12] /home/krs289/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so (_ZN4Foam24subset
MotionSolverFvMeshC1ERKNS_8IOobjectE+0xd64) [0x2a9557bd34]
[compute-2-1:13295] [13] /home/krs289/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so (_ZN4Foam13dynami
cFvMesh29addIOobjectConstructorToTableINS_24subset MotionSolverFvMeshEE3NewERKNS_ 8IOobjectE+0x31) [0x2a9557ed91]
[compute-2-1:13295] [14] /home/krs289/OpenFOAM/OpenFOAM-1.4.1-dev/lib/linux64GccDPOpt/libdynamicFvMesh.so (_ZN4Foam13dynami
cFvMesh3NewERKNS_8IOobjectE+0xaa9) [0x2a9556a2f9]
[compute-2-1:13295] [15] moveDynamicMesh [0x402127]
[compute-2-1:13295] [16] /lib64/tls/libc.so.6(__libc_start_main+0xdb) *** glibc detected *** malloc(): memory corruption:
0x0000000000794d60 ***
[compute-2-1:13296] *** Process received signal ***
[compute-2-1:13296] Signal: Aborted (6)
[compute-2-1:13296] Signal code: (-6)
It should look something like this -
Create mesh for time = 0
Number of cells in new mesh : 2772
Number of faces in new mesh : 11286
Number of points in new mesh: 5940
oldInternalFaces : 198
Running on one processor works great and I can move a subset just fine. However when decomposing the '0/setSubset' and '0/motionSubset' directories do not end up in any of the processor directories (should they?). Here's my case and modified subsetMotionSolverFvMesh code respectively -
http://www.box.net/shared/ph43019sss
http://www.box.net/shared/rllamuaok0
Thanks for any advice,
Kevin
kev4573 is offline   Reply With Quote
Old   March 6, 2008, 18:49
Default The subsets should be decompos
  #26
Frank Bos
The subsets should be decomposed as well. Somewhere on this message board their lives a decomposeParWithSets, or something like that. That utility should do the job, for me it worked fine....
Regards, Frank
Frank Bos
Old   March 10, 2008, 19:25
Default Frank, could you post your
  #27
pbo
Patrick Bourdin
pbo is on a distinguished road
Frank,
could you post your icoFsiFoam case with the cylinder and trailing flat plate. I try to understand why the fore part of my airfoil, which is clamped (fixedValue (0 0 0) for the displacement), gets deformed after the mesh motion in icoFsiFoam (only the rear part and the whole fluid region are coupled in the couplingProperties dictionary).
Cheers,
Patrick
pbo is offline   Reply With Quote
Old   March 11, 2008, 06:07
Default Hello I'm trying to model a
  #28
Juho Peltola
juho is on a distinguished road
Hello
I'm trying to model a wing, or a plate, in flow suspended on an axle. I would greatly appreciate any sample cases that are related ie. on solving the forces acting on the body and updating the mesh accordingly.
If you could email me at juho.peltola@tut.fi it would be great!
Juho
juho is offline   Reply With Quote
Old   March 13, 2008, 15:25
Default Frank - Thanks for pointing me
  #29
Kevin Smith
Frank - Thanks for pointing me to that decomposition utility, it seems to work ok but I could only get the patched decomposePar to compile. After decomposing my case (decomposePar . cylSimple) I try running 'moveDynamicMesh' in parallel but it fails with this message:
[1] --> FOAM FATAL IO ERROR : cannot open file
[1]
[1] file: ../cylSimple/processor1/system/motionSubset/fvSchemes at line 0.
[1]
[1] From function regIOobject::readStream(const word&)
[1] in file db/regIOobject/regIOobjectRead.C at line 66.
[1]
FOAM parallel run exiting
If I'm not mistaken, the processor directories don't need their own system directory - Did you add any parameters or do anything different when decomposing or running?
When I manually copy these files over to each processor directory it eventually gives an error :
[1] --> FOAM FATAL ERROR : Cannot find file "faces" in directory "constant/motionSubset/polyMesh"
Did you end up with the case structure as openFOAM expects it?
Kevin
Old   March 13, 2008, 15:35
Default I did just copy the files and
  #30
Frank Bos
I did just copy the files and directories which is being asked for.......Indeed you'll end up with some dublicate stuff, but for me, it worked.
Are you sure that there is a polyMesh inside the motionSubset. Maybe you should also create the subsets using subsetMeshes utility and put the resulting polyMesh where needed.....In my case I had constant/motionSubset1 and constant/motionSubset2, so I had to create both polyMesh dirs using subsetMeshes.....
Cheers, Frank
Frank Bos
Old   March 14, 2008, 16:14
Default Ok, I've made some progress an
  #31
Kevin Smith
Ok, I've made some progress and can now at least run in parallel but now the mesh moves strangely - seems the processor interface right around the 'oldInternalFaces' is not moving correctly.
Here is the original mesh at t = 0
And after 0.02 seconds I get this
Everywhere else the motion seems fine, but those rogue points at the top of cylinder seem to be causing a problem. Anyone have ideas?
Kevin
Old   March 22, 2008, 13:46
Default Hello I'm trying to set up
  #32
Juho Peltola
Hello
I'm trying to set up a case with icoDyMFoam. Mesh motion works neatly when a set the movingWall in cellMotionUy and pointMotionUy to fixedValue.
When I try to use oscillatingFixedValue or timeVaryingFixedValue it gives me an error message:
[0] --> FOAM FATAL ERROR : Not implemented#0 Foam::error::printStack(Foam:stream&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::error::abort() in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Foam::defaultFvPatchField<double>::defaultFvPatchF ield(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#3 Foam::fvPatchField<double>::addpatchConstructorToT able<foam::defaultfvpatchfield <double> >::New(Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfiniteVolume.so"
#4 Foam::fvPatchField<double>::New(Foam::word const&, Foam::fvPatch const&, Foam::DimensionedField<double,> const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam"
#5 Foam::GeometricField<double,>::GeometricBoundaryFi eld::GeometricBoundaryField(Fo am::fvBoundaryMesh const&, Foam::DimensionedField<double,> const&, Foam::List<foam::word> const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#6 Foam::GeometricField<double,>::GeometricField(Foam ::IOobject const&, Foam::fvMesh const&, Foam::dimensioned<double> const&, Foam::List<foam::word> const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#7 Foam::velocityComponentLaplacianFvMotionSolver::ve locityComponentLaplacianFvMoti onSolver(Foam::polyMesh const&, Foam::Istream&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#8 Foam::motionSolver::adddictionaryConstructorToTabl e<foam::velocitycomponentlapla cianfvmotionsolver>::New(Foam::polyMesh const&, Foam::Istream&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libfvMotionSolvers.so"
#9 Foam::motionSolver::New(Foam::polyMesh const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicMesh.so"
#10 Foam::dynamicMotionSolverFvMesh::dynamicMotionSolv erFvMesh(Foam::IOobject const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#11 Foam::dynamicFvMesh::addIOobjectConstructorToTable <foam::dynamicmotionsolverfvme sh>::New(Foam::IOobject const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#12 Foam::dynamicFvMesh::New(Foam::IOobject const&) in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libdynamicFvMesh.so"
#13 main in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam"
#14 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#15 Foam::regIOobject::readIfModified() in "/home/juho/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoDyMFoam"
[0]
[0]
[0] From function defaultFvPatchField<type>::defaultFvPatchField(con st fvPatch& p, const DimensionedField<type,>& iF)
[0] in file fields/fvPatchFields/basic/default/defaultFvPatchField.C at line 50.
[0]
FOAM parallel run aborting
[0]
I'm using 1.4.1 with the precompiled binaries. The timeVaryingFixedValue works perfectly in turbFoam and oodles.
Any tips how to make it work?
Old   March 22, 2008, 18:06
Default Hi Juho, I've always put the '
  #33
Kevin Smith
Hi Juho, I've always put the 'oscillatingFixedValue' mesh motion implementation in the file 'motionU', never had to touch the other files 'cellMotionUy' and 'pointMotionUy'. I'm using 1.4.1-dev off of the svn but I think you should be able to do this 1.4.1 .
Old   March 22, 2008, 19:21
Default When using tetDecomposition mo
  #34
Frank Bos
When using tetDecomposition motion solvers, the user only has to specify the motionU file. For your moving wall, you either specify oscillatingFixedValue or just fixedValue if your motion is defined by a (custom) dynamicFvMesh library.
This tetDecomp motion solver is only available in the OF-1.4.1-dev version. When using Finite Volume based motion solvers, you only have to specify pointMotion (the interpolation to cellMotion is done accordingly in the code).
Enjoy the mesh motion, it will lead to a lot of fun!!!
Frank
Frank Bos
Old   March 23, 2008, 02:59
Default Thanks for the replies! I g
  #35
Juho Peltola
I guess I should switch to 1.4.1-dev then. Shouldn't the oscillatingFixedValue and timeVaryingFixedValue work with Finite Volume motion solvers? At the moment I've used the movingCone tutorial as an example.
Another question:
I want to move only a part of a continous wall. How do I make the transition between the moving and fixed par smooth? Like bending the wall.
Old   March 23, 2008, 09:11
Default All boundary conditions should
  #36
Frank Bos
All boundary conditions should work fine with both tetDecomp and FV motion solvers......
Frank
Frank Bos
Old   March 23, 2008, 09:36
Default Any ideas what might cause the
  #37
Juho Peltola
Any ideas what might cause the error message I get if I use other boundary conditions than fixedValue for the moving wall? Message in my earlier post.
Old   March 23, 2008, 09:48
Default You should only provide a poin
  #38
Frank Bos
You should only provide a pointMotionU file with oscillatingFixedValue i.e. for your moving wall. (The cellMotionU is derived from that, you could delete that file).....Just try this. Additionally, you should set U for your moving wall to movingWallVelocity.
Frank Bos
Old   March 23, 2008, 10:53
Default I deleted the cellMotionU.
  #39
Juho Peltola
Currently I have:
0/pointMotionU:
boundaryField
farField
type fixedValue;
value uniform (0 0 0);
movingWall
type oscillatingFixedValue;
refValue uniform (0 0 0);
amplitude uniform (0 2 0);
frequency 50;
outlet
type slip;
inlet
type slip;
frontAndBackPlanes
type empty;
0/U:
movingWall
type movingWallVelocity;
constant/dynamicMeshDict:
dynamicFvMesh dynamicMotionSolverFvMesh;
motionSolverLibs ("libfvMotionSolvers.so");
twoDMotion yes;
solver velocityLaplacian;
diffusivity directional (50 500 0);
Same error message as before.
Is it possible something is wrong with my installation? The timeVariedFixedValue gives the same error message but works perfectly in turbFoam and oodles.
Also the mesh motion works fine when I set a fixedValue to the pointMotionU.
Thank you for your time!
Old   March 24, 2008, 04:08
Default The boundary conditions seem t
  #40
Juho Peltola
The boundary conditions seem to work fine with the -dev version's tet decomposition.
And now towards the next problem...
Dynamic Mesh tutorial Part I attachDetach hsieh OpenFOAM Running, Solving & CFD 5 October 11, 2012 16:00
Can we add extra solid mesh part to the analsis? Farhath Alam FLUENT 0 December 22, 2006 03:41
Designating a part of mesh as wall megan FLUENT 0 October 15, 2006 22:04
Problem with rotational mesh deformation: Part II NymphadoraTonks CFX 2 November 4, 2004 04:05
Moving part in a fluid E. BOINOT FLUENT 0 April 24, 2002 10:34
