BuoyantFoam problem
Old   November 7, 2008, 10:24
Default Just a precision: imposing no
  #21
ep4
Pattyn Eric
ep4 is on a distinguished road
Just a precision: imposing no boundary condition for temperature at the Outlet would mean for me to use a "calculated" condition.
When trying to use it, i receive the following error:
Starting time loop
Courant Number mean: 0.00606061 max: 0.133333
Time = 0.0005
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 1.13964e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 0.999969, Final residual = 2.03988e-07, No Iterations 4
gradientInternalCoeffs cannot be called for a calculatedFvPatchField
on patch Outlet of field h in file "/net/ric_home/ep4/OpenFOAM/eric-1.5/run/Flatplate_no_buoyant_unstaedy/0/h"
You are probably trying to solve for a field with a default boundary condition.
From function calculatedFvPatchField<type>::gradientInternalCoef fs() const
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187.
FOAM exiting
ep4 is offline   Reply With Quote
Old   November 7, 2008, 11:13
Default Hello Eric, Quoting from y
  #22
Prashant Ojha
prashant24983 is on a distinguished road
Hello Eric,
Quoting from your post:
"It appears me logical tu use a fixed temperature at the inlet and the plate, a zeroGradient condition at the boundary Up (infront of the plate)."
Thats right, I take back my words. I misread your earlier post and had a completely different case in my mind while replying.
Well, I am retiring for the day but I would like you to check the following boundary conditions.
p:
internalField uniform 100000;
boundaryField
WallDown
type calculated;
value uniform 100000;
Inlet
type zeroGradient
Outlet
type zeroGradient;
Up
type zeroGradient;
pd:
dimensions [1 -1 -2 0 0 0 0];
internalField uniform 0;
boundaryField
WallDown
type fixedFluxBuoyantPressure;
value uniform 0;
Inlet
type fixedValue;
value uniform 50;
Outlet
type fixedValue;
value uniform 0;
Up
type fixedValue;
value uniform 0;
frontAndBack
type empty;
T:
dimensions [0 0 0 1 0 0 0];
internalField uniform 300;
boundaryField
WallDown
type fixedValue;
value uniform 300;
Inlet
type fixedValue;
value uniform 300;
Outlet
type zeroGradient;
Up
type zeroGradient;
frontAndBack
type empty;
U:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
WallDown
type fixedValue;
value uniform (0 0 0);
Inlet
type fixedValue;
value uniform (10 0 0);
Outlet
type zeroGradient;
Up
type zeroGradient;
frontAndBack
type empty;
prashant24983 is offline   Reply With Quote
Old   November 7, 2008, 11:33
Default You were right, setting turbul
  #23
ep4
Pattyn Eric
You were right, setting turbulence off and the simulation is ok. However, i don't know what i should do in order to use the kEpsilon model. Change my initial values for k and epsilon? I had followed the example in tutorial (User guide U-41).
Is it possible that the initial values of epsilon and k influences my results (it can diverge!) even if i have set teubulence off??
Thanks
Eric
Old   November 8, 2008, 01:39
Default It seems that the discretizati
  #24
Prashant Ojha
It seems that the discretization needs tuning, if you keep on getting the bounding error for k and epsilon the solution may blow up.
Just try tightening your tolerances.
Regards,
Old   November 13, 2008, 14:34
Default Hello Foamers, i also have
  #25
Oliver Sommer
lynx is on a distinguished road
Hello Foamers,
i also have a problem with the buoyantFoam solver. I want to simulate a Cell with 1.1mmx10mm in x-y direction and 2D.
For testing i let the Fluid "air" in the "thermophysicalProperties"-File (simply copied the hotRoom example), but now i want to change to a liquid. Do i have to change the "thermoType"? Because i read in the Openfoam website something about liquids and so on. And in which combination can i use the keywords out from the UserGuide?
test case with "air":
hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>>
The problem is, when i change the vaules for W, c_p, eta and Pr to the liquids (n_moles [1] and H_f [o] not changed) the velocities don't fit the experiment results. But is is of course different to the "air"-result.
Do i have to set the H_f value? Do i need it only when i want to "melt ice to water"?
thank you in advance
greets
lynx is offline   Reply With Quote
Old   November 14, 2008, 06:52
Default Hi, I'm considering a heate
  #26
ep4
Pattyn Eric
I'm considering a heated channel flow.
On the plate, where the velocity is zero, the value of pd is different of zero while i thought pd was the dynamic pressure... Actually, i have a variation along x (direction of the flow) which makes me think to a rho g h quantity but i have set g=0 in the environnemental properties.
I have the similar problem with the p quantity of turbFoam, which is the kinematic pressure (User guide U-22). If p= rho V^2/2, for the same case but without heat, p should be 0 on the wall. However, i have the same value as pd for the heated case.
Could someone help me to understand what are these variables exactly?
Thank you
Eric
BuoyantFoam and total pressure bc problem is a bug ariorus OpenFOAM Bugs 3 January 28, 2008 05:20
TotalPressure and buoyantFoam ariorus OpenFOAM Running, Solving & CFD 1 January 22, 2008 09:41
ThermoPhysicalProperties in buoyantFoam prashant24983 OpenFOAM Running, Solving & CFD 0 October 6, 2007 10:40
BuoyantFoam braennstroem OpenFOAM Running, Solving & CFD 22 September 19, 2007 17:55
Release 13 buoyantFoam braennstroem OpenFOAM 0 March 30, 2006 03:43
