OpenFOAM141dev A new implementation of dynamicKistlerGammaContactAngle
Like Tree22Likes
Old   March 24, 2016, 16:45
Default OpenFOAM dynamicKistlerGammaContactAngle
  #21
Anastasios
ageorg is on a distinguished road
Dear Kmou
I did it for version 2.2.1 and i get the following error:
dynamicKistlerAlphaContactAngleFvPatchScalarField. C:167:61: error: no matching function for call to ‘Foam::fvPatch::lookupPatchField(const Foam::word&) const’
alphaContactAngle/dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:167:61: note: candidate is:
/opt/openfoam221/src/finiteVolume/lnInclude/fvPatch.H:259:60: note: template<class GeometricField, class Type> const typename GeometricField::PatchFieldType& Foam::fvPatch::lookupPatchField(const Foam::word&, const GeometricField*, const Type*) const
alphaContactAngle/dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:170:64: error: no matching function for call to ‘Foam::fvPatch::lookupPatchField(const Foam::word&) const’
alphaContactAngle/dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:170:64: note: candidate is:
make: *** [Make/linux64GccDPOpt/dynamicKistlerAlphaContactAngleFvPatchScalarField. o] Error 1
The error points to the following lines of the dynamicKistlerAlphaContactAngle.C file:
const fvPatchField<scalar>& mup =
patch().lookupPatchField<volScalarField, scalar>(muName_); ////HERE
const fvPatchField<scalar>& sigmap =
patch().lookupPatchField<volScalarField, scalar>(sigmaName_); ////HERE
could you please advise me what could be wrong?
Thanks in advance
Ageorg
ageorg is offline   Reply With Quote
Old   March 24, 2016, 16:53
  #22
Anastasios
Dear Kmou
I did the translation to v. 2.2.1 and after compilation I get the following errors:
alphaContactAngle/dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C: In member function ‘virtual Foam::tmp<Foam::Field<double> > Foam::dynamicKistlerAlphaContactAngleFvPatchScalar Field::theta(const fvPatchVectorField&, const fvsPatchVectorField&) const’:
alphaContactAngle/dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:167:61: error: no matching function for call to ‘Foam::fvPatch::lookupPatchField(const Foam::word&) const’
The error messages point to the following lines in the dynamicKistlerAlphaContactAngleFvPatchScalarField. C file:
I would appreciate any help if you have encountered this error before in your case
Thank you very much in advance,
Ageorg
Old   March 24, 2016, 17:02
Anastasios
I did the same in OpenFOAM 2.2.1 and i get the following compilation error :
The error points in the following lines of code:
Any help is appreciated
Thank you in Advance
Old   March 30, 2016, 20:57
Default Quick fix
  #24
Mahmoud Aboukhedr
Mahmoud_aboukhedr is on a distinguished road
Am posting my partial fix again in case its not clear,
You can try removing this 4 lines
And instead you add
const fvMesh& mesh = patch().boundaryMesh().mesh();
const scalarField& mup = mesh.lookupObject<scalarField>("muName_");
const scalarField& sigmap = mesh.lookupObject<scalarField>("sigmaName_");
my understanding is mu and sigma is scalar, so maybe you dont need volScalarFeild for the constant. so it should work fine unless I'm missed something.
It compiles fine with 2.3x, so i will say it should be fine with 2.2.1
Zhiheng Wang likes this.
Mahmoud_aboukhedr is offline   Reply With Quote
Old   July 21, 2018, 02:22
Rajesh Singh
rsingh7 is on a distinguished road
I was able to compile the code and libsrary created in the foam_user_appbin. I also added the following line in the controldict:
libs
"libDynamicKistlerContactAngle.so"
but while initializing the solution, I got following errors.
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : /people/sing956/OpenFOAM/sing956-2.4.0/platforms/linux64GccDPOpt/lib/libDynamicKistlerContactAngle.so: undefined symbol: _ZN4Foam49dynamicKistlerAlphaContactAngleFvPatchSc alarField6theta0E
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libDynamicKistlerContactAngle.so"
Help for resolving this issue would be appreciated. Thanks in advance
Thanks
rsingh7 is offline   Reply With Quote
Old   August 15, 2018, 15:56
Adi
aditya95 is on a distinguished road
has anyone installed kistler contact angle in openfoam 5?
joshmccraney likes this.
aditya95 is offline   Reply With Quote
Old   June 10, 2021, 05:08
A. Min
alimea is on a distinguished road
Originally Posted by eberberovic View Post
Sorry, the files were too large for upload.
Here is the interFoam solver with only the part containing the dynamicKistlerGammaContactAngle class. It should be put into transportModels/interfaceProperties/gammaContactAngle/dynamicKistlerGammaContactAngle
interFoamKistler.tgz
damBreak_thetaA_115.tgz
Dear Edin
Thanks for sharing your code.
This is a solver, isn't it? How can I have it as a boundary condition for using as a dynamic CA for other solvers?
You mentioned that "It should be put into transportModels/interfaceProperties/gammaContactAngle/dynamicKistlerGammaContactAngle", If it is a solver, why should be placed in that address? It seems that must be in application/solver.
thank you!
alimea is offline   Reply With Quote
Installing OpenFoam141dev vtk errors cvv OpenFOAM Installation 0 February 11, 2009 03:54
SpaceVaryingGammaContactAngle in OpenFOAM141dev asaha OpenFOAM Running, Solving & CFD 0 January 23, 2009 11:16
OpenFOAM141dev linking error on IBM AIX 52 matthias OpenFOAM Installation 24 April 28, 2008 16:49
Sample utility problem in OpenFOAM141dev 7islands OpenFOAM Bugs 1 January 4, 2008 09:34
CoupledFvScalarMatrix in OpenFOAM141dev oleg_weinstein OpenFOAM Installation 6 December 13, 2007 14:16
