SimpleFoam case with SpalartAllmaras turbulence model implemented
Old   November 18, 2008, 13:20
Default Hello people. I have carri
Naveed Akram
nedved is on a distinguished road
Hello people.
I have carried out 2D simulations using simpleFoam and turbFoam for a laminar airfoil. I used the k-epsilon turbulence model because it was the default turbulence model.
I want to switch to the SpalartAllmaras turbulence model. I have searched the tutorials folder for v1.5 and all the solvers use the k-epsilon model. I have searched the forums and have not found a simpleFoam case with SpalartAllmaras model.
Would someone please upload a 2D converged simpleFoam case which has the SpalartAllmaras turbulence model implemented. I want to study how the fvScheme and fvSolution files are set up and how they differ from my k-epsilon case.
Nedved.
nedved is offline   Reply With Quote
Old   November 18, 2008, 16:49
Default Hi Naveed, sorry but I didn
Ville Tossavainen
villet is on a distinguished road
Hi Naveed,
sorry but I didn't fully understand what's your problem? Can't you just go to your case and replace RASModel to "SpalartAllmaras"?
If you don't start run from the scratch, make sure you have "nuTilda" file in the latest time directory. I haven't myself used SA model but noticed fvScheme and fvSolution files have settings for SA model. If you get errors, usually you just need to add stuff according to error message.
villet is offline   Reply With Quote
Old   November 30, 2014, 23:43
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hi Nedved,
I am currently working on the same example, which comes with the openFoam 2.3.2. The airfoil example in the addition that I am using already comes with Spalart Allmaras. However, I would be greatly thankful if provide your example since I am trying to implement and switch to k-epsilon model.
Regards,
tareqkh is offline   Reply With Quote
How to copy the simpleFoam case to turboFoam sivakumar OpenFOAM Pre-Processing 5 November 18, 2009 03:49
Running a case with simpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 4 March 28, 2008 08:13
Question on new implemented komegaSST model in OF 14 peterh OpenFOAM Running, Solving & CFD 7 February 7, 2008 03:09
k-e turbulence model for 3D case Serge A.S. Main CFD Forum 7 September 10, 2007 12:50
Two turbulence models in the same case HSeldon FLUENT 0 November 25, 2006 19:58
