July 31, 2007, 16:13 |
Hi Bernhard,
the the intern
#21 |
Fabian Braennstroem
Rep Power: 19 |
Hi Bernhard,
the the internal p-field is set to 100000; that is not the problem!? Regards! Fabian P.S. Nice PyFoam-Tool! Do you plan further version with more features? I am looking for a small python-gui which handles bc, importing, cloning, etc. :-) |
July 31, 2007, 17:05 |
sorry, for waisting your time.
#22 |
Fabian Braennstroem
Rep Power: 19 |
sorry, for waisting your time...
but for 'compressible' I have to set the pressure outlets too. Stupid! Thanks for the help, it runs now ... |
August 1, 2007, 10:53 |
Hi Fabian!
Yep. Boundaries
#23 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Hi Fabian!
Yep. Boundaries too. That's what I meant with 'somewhere' ;) @PyFoam: Thanks. I am adapting PyFoam constantly on a as-needed basis for my projects and plan to publish new versions on the Wiki. My emphasis is on stuff that helps me to automatize tasks (==scripting) so right now I have nothing planned GUI-wise (there is a graphical blockMesh-viewer, that might be in the next version, but apart from that: no)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
August 1, 2007, 13:31 |
Hi Bernhard,
@PyFoam:
I am
#24 |
Fabian Braennstroem
Rep Power: 19 |
Hi Bernhard,
@PyFoam: I am actually a big fan of scripting too, but as more scripts one is creating, as worse it gets to handle them ... and then a fast keyboard driven gui can help a lot. Especially Python is 'wonderful' in this sense; you can easily connect the existing scripts together. I actually use an own keyboard -driven file manager, written in python-gtk, for collecting my small scripts. Actually I started to integrate your pyfoam-scripts, but I don't have any idea, how I could handle the setup of boundary conditions... the FoamX approach is pretty much mouse-driven. Regards! Fabian |
February 29, 2008, 12:54 |
Hi everybody,
I'm a new Ope
#25 |
Leonardo Nettis
Rep Power: 17 |
Hi everybody,
I'm a new OpenFoam user. I think I have a problem in my analysis on a naca profile, maybe with the turbulence model k-e, since I get this message on the terminal when I try to start the code: ..... Creating turbulence model Selecting turbulence model kEpsilon #0 Foam::error::printStack(Foam:stream&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" #3 Foam::compressible::turbulenceModels::kEpsilon::kE psilon(Foam::GeometricField<do uble,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbule nceModels.so" #4 Foam::compressible::turbulenceModel::adddictionary ConstructorToTable<foam::compr essible::turbulencemodels::kepsilon>::New(Foam::Ge ometricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbule nceModels.so" #5 Foam::compressible::turbulenceModel::New(Foam::Geo metricField<double,> const&, Foam::GeometricField<foam::vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double,> const&, Foam::basicThermo&) in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/lib/linux64GccDPOpt/libcompressibleTurbule nceModels.so" #6 main in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbFo am" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/home/nettis/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linux64GccDPOpt/rhoTurbFo am" Actually I do not know if everything is ok with the grid imported from gambit, but I'm not sure it is the cause of this issue. Thank you in advance. Regards, Dino |
March 3, 2008, 06:36 |
Check whether this is a case o
#26 |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Check whether this is a case of "k or epsilon is zero on some boundary or as the initial condition and OF doesn't like this". That is a very popular mistake with beginners
March 6, 2008, 14:07 |
Hi Bernhard,
you were right
#27 |
Leonardo Nettis
Rep Power: 17 |
Hi Bernhard,
you were right!! but now I'm facing with another problem: which values of k and epsilon I have to set as initial condition?? Have you got some suggestions?? Thank you very much, Dino |
November 18, 2008, 19:51 |
Hi everyone
I'm using interFo
#28 |
Sara Schairer
Rep Power: 17 |
Hi everyone
I'm using interFoam. I turned off the adjustable timestep since it grew ridiculously small after some time and set it to 10e-4 (which was ok in Fluent). But after some time (0,09 seconds) the calculation stops giving this error message. MULES: Solving for gamma #0 Foam::error::printStack(Foam:stream&) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so" #2 __restore_rt at sigaction.c:0 #3 void Foam::MULES::limiter<foam::onefield,>(Foam::Field< double>&, Foam::oneField const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #4 void Foam::MULES::explicitSolve<foam::onefield,>(Foam:: oneField const&, Foam::GeometricField<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, Foam::zeroField const&, Foam::zeroField const&, double, double) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #5 Foam::MULES::explicitSolve(Foam::GeometricField<do uble,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,>&, double, double) in "/opt/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVolume.so" #6 main in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 Foam::regIOobject::readIfModified() in "/opt/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/interFoam" Floating point exception I can't figure out where the problem is. Maybe it has something to do with the timestep, since, as I already said, it turned very small when it was adjustable. But the small timestep is of no use to me either (it was about 10e-30 s), that'w why I turned it off and set it to a fix value. Can anyone help me? Cheers, Sara |
January 2, 2010, 13:47 |
error
#29 |
raul
Rep Power: 17 |
i am building a new solver for steady computation of electrohydrodynamic flow and for the purpose i have combined electrostatic solver and simpleFoam solver.I am getting the following error and i don't know how to solve it,so if anyone has any idea please let me know: Starting iteration loop Iteration = 1 smoothSolver: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 DICPCG: Solving for V, Initial residual = 1, Final residual = 0.192654, No Iterations 2 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libfiniteVolume.so" #9 Foam::lduMatrix::solverPerformance Foam::solve<double>(Foam::tmp<Foam::fvMatrix<doubl e> > const&) in "/home/rahul/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/ehdFoam" #10 main in "/home/rahul/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/ehdFoam" #11 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #12 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/i386/elf/start.S:122 Floating point exception Previously I built an unsteady solver for the same problem and mesh,and it works fine,so there shouldn't be any mesh related trouble like aspect ratio... thanks and regards, rudy |
January 7, 2010, 04:41 |
#30 |
stephane sanchi
Rep Power: 18 |
Hi OF-users,
I have recently installed OpenFOAM-1.6.x with Linux 11.2. I think that the installation is fine. I am not able to run the MRFSimpleFoam solver. So I have decided to check with the mixervessel2D tutorial. I have the following error message when running the mixer 2D tutorial : /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6.x-f3456b234025 Exec : MRFSimpleFoam Date : Jan 06 2010 Time : 16:42:36 Host : cfs10 PID : 16108 Case : /shared/sanchi/mixerVessel2D nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p #0 Foam::error:rintStack(Foam::Ostream&) in "/shared/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigSegv::sigSegvHandler(int) in "/shared/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib64/libc.so.6" Advices are welcome. Need help ! I need help to solve this problem. Best regards, Stephane |
January 7, 2010, 09:08 |
#31 |
stephane sanchi
Rep Power: 18 |
Inside the mixervessel2D directory when I do ./Allrun I get the following error message : [170]cfs10-sanchi /shared/sanchi/mixerVessel2D_1.6.x % ./Allrun + m4 + blockMesh + cellSet + setsToZones -noFlipMap Running MRFSimpleFoam on /shared/sanchi/mixerVessel2D_1.6.x /shared/OpenFOAM/OpenFOAM-1.6.x/bin/tools/RunFunctions: line 38: 13644 Segmentation fault $APP_RUN $* > log.$APP_NAME 2>&1 I hope that it could help to solve my problem !!! Thanks, Stephane |
January 8, 2010, 08:19 |
#32 |
stephane sanchi
Rep Power: 18 |
I discover the problem. For OpenFOAM-1.6.x and OpenSUSE 11.2 I have to use the system compiler. So I just have forgotten to recompile MRFSimpleFoam too. cd ~/OpenFOAM/OpenFOAM-1.6.x/tutorials/incompressible/MRFSimpleFoam wmake and now MRFSimpleFoam works again. Regards, Stephane. |
January 13, 2010, 00:48 |
Same Problem with my solver
#33 |
Seyyed Ali H.M.
Rep Power: 17 |
Hi everybody,
I have same problem too. I have just developed my own reacting solver for a specific case( combustion). And I get the same floating point exception error. Can any body help me with this. My solver is based on IcoFoam, plus there is one property transport equations for Temperature, and three different equations for N2, Fuel, O2. the heat source is based on Arrhenious formula for rate of reaction, and simmilar sink term for Fuel and O2, But I get the same error. Can any body tell me what the problem is, and how I can fix this. The mesh is 2d, and this error happens when the temperature rises and reaction happens, If I keep the temperature low, no reaction happens and There will be no error. The Error message is: #0 Foam::error:: printStack(Foam::Ostream&) in "/home/harish/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/harish/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #2 Uninterpreted: #3 ?? in "/lib/tls/i686/cmov/libm.so.6" #4 pow in "/lib/tls/i686/cmov/libm.so.6" #5 Foam:: pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/home/harish/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so" #6 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:ow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) in "/home/harish/OpenFOAM/harish-1.6/applications/bin/linuxGccDPOpt/MyIncombFoam" #7 main in "/home/harish/OpenFOAM/harish-1.6/applications/bin/linuxGccDPOpt/MyIncombFoam" #8 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6" #9 _start in "/home/harish/OpenFOAM/harish-1.6/applications/bin/linuxGccDPOpt/MyIncombFoam" Floating point exception |
October 17, 2010, 10:10 |
#34 |
poopak
Hi friends,
I try to run RANS. I input a 3D meshed geometry into Open-Foam. after runing for few time step, it gives me eror. I am a new user (OpenFoam 1.6x), pleas help me. the errors are as follows: Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 0.000508485, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 0.000139666, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 0.000140066, No Iterations 1 DICPCG: Solving for p, Initial residual = 1, Final residual = 0.00925416, No Iterations 123 DICPCG: Solving for p, Initial residual = 0.012907, Final residual = 0.000126943, No Iterations 27 DICPCG: Solving for p, Initial residual = 0.00398529, Final residual = 3.14156e-05, No Iterations 116 DICPCG: Solving for p, Initial residual = 0.00182828, Final residual = 1.79837e-05, No Iterations 26 DICPCG: Solving for p, Initial residual = 0.00074565, Final residual = 6.59969e-06, No Iterations 114 DICPCG: Solving for p, Initial residual = 0.000358352, Final residual = 3.48877e-06, No Iterations 24 time step continuity errors : sum local = 3.17637e-05, global = -1.50157e-06, cumulative = -1.50157e-06 #0 Foam::error:rintStack(Foam::Ostream&) in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::sigFpe::sigFpeHandler(int) in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #2 ?? in "/lib/libc.so.6" #3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so" #4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #6 Foam::incompressible::RASModels::kEpsilon::correct () in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libincompressibleRASModels.so" #7 main in "/home/azadeh/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam" #8 __libc_start_main in "/lib/libc.so.6" #9 _start at /build/buildd/eglibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116 Floating point exception |
October 17, 2010, 10:31 |
#35 |
poopak
I FOUND IT
Just "k" ahouldn't be 0. |
June 15, 2011, 07:35 |
#36 |
Rep Power: 15 |
hi,
i have the same error message like some guys before me. I was reading in the forum, but i donīt understand the error. poopak999 sayed that k donīt can be zero. When i go to the 0-Folder in the k-file my k has the value "uniform 3.75e-04". so it isenīt zero. Maybe someone can help me? greets almir Last edited by almir; June 18, 2011 at 11:01. |
November 24, 2011, 23:05 |
#37 |
Daniel
Rep Power: 17 |
Hello all,
I successfully ran a series of simulations using simpleFoam to set up my case, and now I want to complicate things by moving to sonicFoam. 9 iterations ran successfully, but #10 produced an impressive series of errors: Code:
Time = 0.0001 Courant Number mean: 0.0141899 max: 0.421549 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 smoothSolver: Solving for Ux, Initial residual = 5.99736e-05, Final residual = 8.86793e-11, No Iterations 21 smoothSolver: Solving for Uy, Initial residual = 0.0549661, Final residual = 8.38165e-11, No Iterations 22 DILUPBiCG: Solving for e, Initial residual = 0.000111588, Final residual = 7.1124e-09, No Iterations 3 [1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&)[3] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [1] #2 in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [2] #2 in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [3] #2 in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/lib [1] #3 c.so.6" That's not the half of it... I included the whole log file in the attachment. Can anyone suggest what the problem might be? After reviewing the previous posts, I have already verified that all of my turbulence coeffs and pressures are non-zero. Thanks, Dan |
November 25, 2011, 15:35 |
#38 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
http://openfoamwiki.net/index.php/Ma...:Ostream.26.29 (and the point above it). Anyway. You seem to have a parallel run there. Try running it in serial and see if the problem is also there. Apart from that there is much I can tell you (maybe some kind soul has a look at your log-file) |
November 25, 2011, 23:58 |
#39 |
Daniel
Rep Power: 17 |
Thank you for your assistance, Bernhard. It turns out that the simulation ran just fine in serial. I implemented one change each to /etc/config/settings.sh and /etc/bashrc in accordance with the references below, and now it appears to run well.
Regards, Dan Ref 1: http://www.cfd-online.com/Forums/ope...-problems.html Ref 2: http://www.cfd-online.com/Forums/ope...exception.html |
