Heated vertical channel flow RANS
Old   November 24, 2008, 10:37
Default Hi everybody, i'm trying to
ep4
Pattyn Eric
ep4 is on a distinguished road
Hi everybody,
i'm trying to simulate the flow in a vertical channel due to natural convection, with each plate at a constant temperature. I use the k epsilon turbulence model.
I have choosen a cyclic boundary condition in the streamwise and spamwise directions.
For the two heated plate, i have pd-> fixedFluxBuoyantPressure, p->calculated, no slip condition, fixedValue for T and zeroGradient for k and epsilon.
I use second order discretisation schemes.
Running buoyantSimpleFoam, i have a bad convergence with a fine mesh and the computation with a coarser much crashes after some iterations.
The number of boundary conditions being quite limited, i don't see where is the problem.
Could someone help me?
Thank you
Eric
ep4 is offline   Reply With Quote
DNS for heated pipe flow dpalko OpenFOAM Running, Solving & CFD 7 September 5, 2019 10:12
Fluent-Flow over heated cylinder Khyati Main CFD Forum 0 July 12, 2006 01:17
natural convection in a vertical heated duct. SHANTANU CHAKRABORTY Phoenics 1 June 18, 2001 10:12
Transient laminar free convection between heated vertical plates with entrace effects henry pastohr FLUENT 0 June 23, 2000 10:55
