How to read pressure from a designated path
Old   December 4, 2008, 05:48
Default Generally, OpenFOAM uses the f
Jia Rui
jennyrui2008 is on a distinguished road
Generally, OpenFOAM uses the following codes to read the initial pressure field as follows:
volScalarField p
IOobject
"p",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
The program will look for p from case/0/p, but now if I need to find p from case/Re/0/p, how should I write the codes?
Thanks a lot!
jennyrui2008 is offline   Reply With Quote
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 08:26
Path status in DPM BC UDF HS FLUENT 4 June 12, 2014 08:12
What is MMS data path? frank CFX 2 July 11, 2008 00:42
How should i set path in OpenFOAM11bashrc ztdep OpenFOAM Installation 1 April 18, 2008 06:20
Different PATH and OpenFOAM 11 ds2taieb OpenFOAM Installation 0 January 25, 2006 14:15
