TimeVaryingMappedFixedValue field creation
Old   December 4, 2008, 11:50
Default Hi, I still got problems re
  #21
John Deas
johndeas is on a distinguished road
I still got problems related to pTraits :
I tried to modify my code in order to export other variables than U (k and p for instance).
This expression will compile:
AverageIOField<vector> writeSampleU
IOobject
"U",
mesh.time().constant(),
"boundaryData/entree"/runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
U[0],
combinedVecU
But, as soon as I want to insert this one:
AverageIOField<scalar> writeSampleP
IOobject
"p",
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
p[0],
combinedScaP
I get a nice:
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/AverageIOField.C: In constructor 'Foam::AverageIOField<type>::AverageIOField(const Foam::IOobject&, const Type&, const Foam::Field<type>&) [with Type = double]':
writeSampleP.H:39: instantiated from here
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/AverageIOField.C:7 3: error: no matching function for call to 'Foam::pTraits<double>::pTraits(const double&)'
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:68: note: candidates are: Foam::pTraits<double>::pTraits(Foam::Istream&)
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:41: note: Foam::pTraits<double>::pTraits(const Foam::pTraits<double>&)
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/AverageIOField.C:7 7: error: invalid static_cast from type 'Foam::AverageIOField<double>' to type 'double&'
From my understanding of template specialization, in Scalar.H:68, when the template pTraits is specialized for scalars, its only constructor is pTraits(Istream& is)
Therefore, the general constructor from primitive:
pTraits(const primitive& p)
primitive(p)
which has been added in this forum thread is not available. Should I modify Scalar.H and Scalar.C to get my code to compile ?
adding to Scalar.H :
pTraits(const primitive& p);
adding to Scalar.C :
pTraits<scalar>::pTraits(const primitive& p)
p_ = p;
johndeas is offline   Reply With Quote
Old   April 2, 2010, 13:07
Jiang
panda60 is on a distinguished road
Dear Mattijs and John Deas,
Do you have some common on how to use TimeVaryingMappedFixedValue boundary condition ?
I have two questions:
1.what's the meaning of Average in its input data ?
FoamFile
version 2.0;
format ascii;
class vectorAverageField;
object values;
// Average
( 0 0 0 )
// Data on points
70
//minz
(5.74803 0 0)
(5.74803 0 0)
2. Because the most useful things of this boundary condition is to read a large series of data from file as inlet condition. But its request data is a little strange, how we can generate this kind of data ?
Maybe I can get these data from functionObject surface sampling using pre-simulation. But the sampling data is a little difference from TimeVaryingMappedFixedValue data format, and the sampling result have more folders, so how can do this ?
If we have utility to convert sample data to request data format ?
Thank you very much.
panda60 is offline   Reply With Quote
Old   April 2, 2010, 13:10
Jiang
This is request data format for timeVaryingMappedFixedValue :
| \\ / O peration | Version: 1.6 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
object values;
// Average
( 0 0 0 )
// Data on points
70
//minz
(5.74803 0 0)
(5.74803 0 0)
(11.3009 0 0)
(13.4518 0 0)
This is sampling data format :
15408
(0.0239436 -6.28249e-05 0.000567144)
(0.0712944 -0.00019323 -0.00045317)
(0.122301 -0.000335644 -0.00117908)
(0.178985 -0.000485735 -0.000847965)
Old   October 13, 2015, 07:33
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by johndeas View Post
IOobject
"U",
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
U[0],
combinedVecU
IOobject
"p",
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
p[0],
combinedScaP
I get a nice:
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude/AverageIOField.C:7 3: error: no matching function for call to 'Foam:Traits<double>:Traits(const double&)'
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:68: note: candidates are: Foam:Traits<double>:Traits(Foam::Istream&)
/home/flurec/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/Scalar.H:41: note: Foam:Traits<double>:Traits(const Foam:Traits<double>&)
primitive(p)
pTraits<scalar>:Traits(const primitive& p)
p_ = p;
I have encountered a very similar problem. I have included the following code within pimpleFoam to write U field at inlet, at each time step to be used later through TimeVaryingMappedFixedValue bc.
AverageIOField<vector> U2
    IOobject
        "U",
        mesh.time().timeName(),
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    U.boundaryField()[ patchID ]
U2.write();
But when compiling, OpenFOAM gives me the following error:
MypimpleFoam.C: In function ‘int main(int, char**)’:
MypimpleFoam.C:97:4: error: ‘AverageIOField’ was not declared in this scope
MypimpleFoam.C:97:25: error: expected primary-expression before ‘>’ token
MypimpleFoam.C:108:1: error: ‘U2’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/MypimpleFoam.o] Error 1
I need to implement AverageIOField because TimeVaryingMappedFixedValue accepts data with this type. How can I resolve this problem??
Thanks,
Syavash
syavash is offline   Reply With Quote
Old   June 14, 2021, 15:56
Default Problem with TimeVaryingMappedFixedValue
  #25
Pilar
Pilardc91 is on a distinguished road
I am using a boundary condition for the displacement U called TimeVaryingMappedFixedValue. The definition of this BC is:
"This is a derived traction boundary which reads the time and spatial varying force data (from pressure p and/or stresses  S) and computes the traction load and compatible displacement gradient boundary. This boundary condition is derived from tractionDisplacement + timeVary-ingMappedFixedValue in OpenFOAM. (Li et al. 2020)"
When I get the results for each time, this boundary condition does not do like other boundary conditions that store the list of data in the defined patch. In fact, when I look at one of the files and search for the patch where I have imposed that B.C there is no data (it is at the top). The thing is that in Paraview if it represents them to me and it represents them just in that patch.
My doubts are:
1) why does this happen and why Paraview allows to draw it?
2) When I make the sampleDict (and execute sample) none of the interpolation options let me get the data of U, since it looks for the patch and does not find it. Any idea what I can extract those data from
Thank you very much in advance for your help.
Pilardc91 is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
TimeVaryingMappedFixedValue best practice to extract subset points and fields podallaire OpenFOAM Running, Solving & CFD 6 May 21, 2014 11:25
TimeVaryingMappedFixedValue sunnysun OpenFOAM Running, Solving & CFD 12 October 30, 2013 16:22
Possible bug with timeVaryingMappedFixedValue jerome OpenFOAM Bugs 2 October 9, 2007 10:38
Putting submesh field values into field on parent mesh helmut OpenFOAM Running, Solving & CFD 2 June 20, 2006 08:31
