December 5, 2008, 02:06 |
Dear OpenFOAM users.
I am u
Ameya Durve
Rep Power: 17 |
I am using OpenFOam-1.5 I wanted to solve the transport equation for temperature variance for my research purpose. I have added Temperature equation and Trms equation in the simplFoam code for the same purpose.( I have replaced buoyantSimpleRadiation code with SimpleFOam code sincemy original simpleFoam doce is running with some other modifications in energy equation) My TEqn.H file reads as aplhaEff = aplha + turbulence->nut()/Prt; tmp<fvscalarmatrix>TEqn ( fvm::div(phi, T) - fvm::laplacian(aphaEff, T) ); TEqn().relax(); eqnResidual() = solve(TEqn()).intialResidual(); maxResidual = max(eqnResidual, maxResidual); My TrmsEqn.H file reads as alphavariance = alpha + (0.13*(turbulence->k()*turbulence->k()/turbulence->epsilon())); tmp<fvscalarmatrix> ( fvm::div(phi, Trms) -fvm::laplacian(alphavariance, Trms) +fvm::Sp(fvc::div(aplhaEff, T), Trms) +0.134*(turbulence->epsilon()/turbulence->k())*Trms ); TrmsEqn().relax(); eqnResidual = solve(TrmsEqn()).initialResidual(); maxResidual = max(eqnResidual, maxResidual); On compilation i get following error Ameya@Ameya:~/OpenFOAM/OpenFOAM-1.5/applications/solvers/heatTransfer/buoyantSimpleRadiatio nFoam> wclean Ameya@Ameya:~/OpenFOAM/OpenFOAM-1.5/applications/solvers/heatTransfer/buoyantSimpleRadiatio nFoam> wmake Making dependency list for source file buoyantSimpleRadiationFoam.C SOURCE=buoyantSimpleRadiationFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/turbulenceModels/RAS -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/transportModels -IlnInclude -I. -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/Ameya/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/buoyantSimpleRadiationFoam.o In file included from buoyantSimpleRadiationFoam.C:72: TrmsEqn.H: In function 'int main(int, char**)': TrmsEqn.H:8: error: no matching function for call to 'div(Foam::volScalarField&, Foam::volScalarField&)' make: *** [Make/linuxGccDPOpt/buoyantSimpleRadiationFoam.o] Error 1 Any ideas on what the error actually means???? I know there is some mistake in the way in which the source term of Trms equation is written but i am not able to find out what and exactly how that term should be written. Can anyone please help me????????? |
December 15, 2008, 09:57 |
Hello Ameya,
I have a feeling
Tammo Wenterodt
Rep Power: 17 |
Hello Ameya,
I have a feeling that your nomenclature is a little mixed up: one time you write "alpha" and the other "aplha", the same for alphaEff. Do the error-messages disappear when correcting that? Otherwise after a first overview I see no other problems in your code. |
December 15, 2008, 12:55 |
Hey,
Pierre Le Fur
Rep Power: 17 |
Hey,
TrmsEqn.H:8: error: no matching function for call to 'div(Foam::volScalarField&, Foam::volScalarField&)' it refers to: +fvm::Sp(fvc::div(aplhaEff, T), Trms) what is the mathematical expression you want to express, the divergence of a vector I presume? also fvc::div generally needs a surfaceScalarField to operate. see for example: fvScalarMatrix bEqn ( fvm::ddt(rho, b) + mvConvection->fvmDiv(phi, b) + fvm::div(phiSt, b, "div(phiSt,b)") - fvm::Sp(fvc::div(phiSt), b) - fvm::laplacian(turbulence->muEff(), b) ); hope this helps Pierre |
December 15, 2008, 12:58 |
I forgot, try to interpolate a
Pierre Le Fur
Rep Power: 17 |
I forgot, try to interpolate aplhaEff to the faces of your cell.
Pierre |
Transport equation using UDF | wassim | FLUENT | 6 | March 22, 2018 14:39 |
UDF for concentration transport equation | heri | FLUENT | 1 | August 15, 2011 12:23 |
Poisson equation combined with transport equation | Se-Hee | CFX | 0 | December 27, 2007 02:00 |
transport equation | Arman | Main CFD Forum | 1 | August 28, 2007 13:48 |
transport equation | CMB | Siemens | 2 | July 9, 2004 06:19 |
