Error while running lesInterFOAM OF 15 on the initial amp BC files of OF14
Old   December 18, 2008, 07:26
Default Hello FOAMERS, I am running a
Suresh kumar Kannan
kumar is on a distinguished road
Hello FOAMERS,
I am running a les-VOF simulation of a liquid jet of 200 bar injected into a chamber. I have been provided with the set up files which were sucessfully used to run such simulations in OF 1.4. But when I use the same set up files to run on OF 1.5. It gave me the following errors:
1. gammaCompression 1.0 , this scheme is not identified and OpenFOAM gave me a list of schemes available to solve the gamma equation, since I could not find the scheme gammaCompression 1.0 in the list, I chose interfaceCompression to solve the gamma equation.
2. Then when i tried to run the solver after this change, it solves the velocity equations for the 0 time step, but while starting to solve the pressure equation it gives me a error message as pated below:
Create mesh for time = 0
Reading environmentalProperties
Reading field pd
Reading field gamma
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Calculating field g.h
Selecting LES turbulence model oneEqEddy
time step continuity errors : sum local = 0, global = 0, cumulative = 0
DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
Courant Number mean: 0 max: 0
Starting time loop
deltaT = 1.1904762e-08
Time = 1.19047619e-08
MULES: Solving for gamma
Liquid phase volume fraction = 0.00033350008 Min(gamma) = 0 Max(gamma) = 1
DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 1.1917548e-15, No Iterations 2
bounding k, min: 0 max: 100 average: 1.2078798e-06
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 4.882832e-13, No Iterations 2
DILUPBiCG: Solving for Uz, Initial residual = 0, Final residual = 0, No Iterations 0
DICPCG: Solving for pd, Initial residual = 1, Final residual = 0.034418455, No Iterations 1001
keyword pdFinal is undefined in dictionary "/home/kumar/OpenFOAM/kumar-1.5/run/test/Offset100um_200into10bar/system/fvSolut ion::solvers"
file: /home/kumar/OpenFOAM/kumar-1.5/run/test/Offset100um_200into10bar/system/fvSoluti on::solvers from line 27 to line 32.
From function dictionary::lookupEntry(const word& keyword) const
in file db/dictionary/dictionary.C at line 213.
FOAM exiting
I can see that there is no definition of Pd in the fvSolution file.
But the same setting worked for OF-1.4. so is there any major change in OF-1.5 in solving the pressure equation.
Any comments are welcome
with regards
K.Suresh kumar
kumar is offline   Reply With Quote
OF14 compilation error bistreamb is already declared in this scope rafal OpenFOAM Installation 5 August 26, 2008 12:23
Error running lesInterFOAM nozzleFlow2D case idosil OpenFOAM Running, Solving & CFD 4 July 12, 2007 13:17
OF14 compilation error with icc91 ueno OpenFOAM Installation 0 June 1, 2007 09:54
Running script files without opening grafic inter Jim CFX 0 March 21, 2006 07:57
FIDAP RUNNING ERROR "ERROR-DIR-NOT-EMPTY=145" BAOYU FLUENT 0 January 26, 2006 19:32
