What is the construction of different 5 parts of the code in OpenFoam |
October 18, 2008, 23:24 |
Hi Guys,
As my understand,
Sandy Lee
Rep Power: 18 |
Hi Guys,
As my understand, an entire procedure always includes 5 parts, namely mesh generation, scheme (QUICK, UP-Wind Scheme), solution of algebriac equation (BiCG, ICCG), Algorithm (SIMPLE, PISO) and User. Could you introduce how to be constructed in every part? There are so many classes in every part. It is actually difficult to make them clear at a short time, so I would like to know that What are their relations between different class? And moreover, what is the relation between 5 parts? I guess, somebody should have a series of entire industruction about the framework of these codes and classes --- glancing in the whole structure and detailed in every part. Could you help me to find out them? Thank you very much! Kind Regards, Sandy |
October 20, 2008, 06:56 |
Have you tried all the tutoria
John Deas
Rep Power: 17 |
Have you tried all the tutorials described in the user guide ? Launching them and opening the various files describing the setup and results of your calculations might clear the picture for you, and it does not take too long.
October 20, 2008, 10:15 |
Hi John,
Thanks for your he
Sandy Lee
Rep Power: 18 |
Hi John,
Thanks for your help. I have quickly finished to read the contents in the user's guide and programe' guide. I also tried several cases by the FoamX and paraFoam. However, It seems that I still can not clearly understand the entire framework of those original colds in OpenFoam? I will try again. By the way, if you have more detailed industruction about those code, please copy to me. Kind Regards, Sandy |
December 22, 2008, 16:58 |
A document titled "Creational
Heng Xiao
Rep Power: 17 |
A document titled "Creational Sequence of Objects in a Solver", Compiled by Jaswinder Pal Singh, should answered this question. Search the forum.
Heng |
Can fronttracking code be found in OpenFOAM | luckyluke | OpenFOAM Running, Solving & CFD | 23 | May 10, 2016 04:15 |
Musig code in OpenFoam | in_flu_ence | OpenFOAM Running, Solving & CFD | 1 | February 25, 2007 17:47 |
Tree of the openfoam code | mhuening | OpenFOAM Installation | 3 | January 29, 2007 19:06 |
pump construction | Roberto Salvador | CFX | 0 | May 4, 2006 11:49 |
Rotating mesh construction | Joel | Siemens | 1 | December 9, 2002 22:21 |
