MaxCo with interFoam
Old   January 5, 2009, 05:39
Default Hello again. Thinking about
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Hello again.
Thinking about the maxCo entry in controlDict I'm asking myself what this entry is good for if I'm using Euler implicit discretisation for the temporal derivative, which should be unconditionally stable for ALL timesteps.
What is maxCo limiting in this case?
The velocity field?
Greetings.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   January 5, 2009, 08:36
Default Hi Sebastian, yes, maxCo is
caw
Christian Winkler
caw is on a distinguished road
Hi Sebastian,
yes, maxCo is based on the velocity field. The stability is limited by the PISO algorithm, which is stable for Co up to 1 i think. But Co should be lower for interFoam, it should be around 0.25. To overcome this, you can use subtimestepping for MULES. A good choice is maxCo = 0.5 and two subtimesteps for gamma.
Concerning Euler: even if Euler is unconditionally stable, this does NOT mean that it is unconditionally accurate ;-)
Best regards
Christian
caw is offline   Reply With Quote
Old   January 6, 2009, 05:05
Default Thank you, Christian. That mak
sega's Avatar
Sebastian Gatzka
Thank you, Christian. That makes sense.
Who can tell the correct Co-limit for PISO?
Problems with adjustable timestep control and maxCo Number wolle1982 OpenFOAM Running, Solving & CFD 5 September 24, 2015 11:07
Transient interFoam with MRF jaswi OpenFOAM Running, Solving & CFD 18 October 21, 2011 00:29
Outlet bc in interFoam happysimulant OpenFOAM Running, Solving & CFD 0 November 6, 2008 11:06
InterFoam floooo OpenFOAM Running, Solving & CFD 0 November 3, 2008 12:00
About interfoam solver qiu OpenFOAM Running, Solving & CFD 0 May 6, 2007 23:48
