Finding velocity temperature etc at a particular pt in space
Old   June 7, 2008, 23:54
Default Hi Suppose i have finished
srinath
srinath is on a distinguished road
Hi
Suppose i have finished a foam run, and am interested in values at a few spatial locations, how would i extract these from the output?
Thanks
Srinath
srinath is offline   Reply With Quote
Old   June 8, 2008, 06:12
Default During the simuation you can d
Assistant Moderator
Bernhard Gschaider
During the simuation you can do that using the probes-functionObject (have a look at $FOAM_TUTORIALS/oodles/pitzDaily/system/controlDict for an example).
I have never tried this, but I think that you can use the same mechanism to do it after the simulation. Just add the entries to the controlDict and run a postprocessing-utility that loads the fields you are looking for into memory (Mach or something like that)
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   June 8, 2008, 22:23
Default Thanks Bernhard I added the
srinath
Thanks Bernhard
I added the lines to the control dict and i get the runtime information.
I would ideally like to extract information at particular spatial co-ordinates even after the run is completed. I am not very familiar with manipulating IO objects. Could someone tell me how i should go about it?
Thanks
Srinath
Old   June 9, 2008, 04:45
Default Hi Srinath There is a tool
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Srinath
There is a tool which you might would take a look at. It is called 'sample' and lives in
~/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/postProcessing/miscellaneous/sa mple
In this folder there is also an example of a sampleDict. Using this tool you can extract points along a line. I do not know if you can extract in specific points, but a line with two points is only a little bit do much work
/ Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   June 9, 2008, 07:34
Default Thanks Niels I copy the sam
srinath
Thanks Niels
I copy the sampleDict into the case/system directory
And it works perfectly when i issue the command
sample . cavity
Srinath
Old   January 6, 2009, 08:30
Default Hi Users, Have you used pro
Martin Romagnoli
martinr is on a distinguished road
Hi Users,
Have you used probes function in multiphase flow solvers (rasInterFoam or interFoam)? I could obtain the probe/0/ files but there is a mistake. The values are not written in the correct time step.
I tried probes function with other solvers (icoFoam, oodles, turbFoam). In this cases probes function works fine.
I have not found the reason for this behaviour.
Any clue?
Thank you in advance.
Martin.
martinr is offline   Reply With Quote
UDF for space-filtering 3-D velocity fields Xianmin FLUENT 0 April 11, 2008 21:58
Finding the node temperature (not cell) Parsa Zamankhan FLUENT 4 August 22, 2007 16:38
Finding average x-velocity at any particular x. Dpu FLUENT 2 April 11, 2006 23:32
Urgent help needed in finding maximum temperature. Deadly FLUENT 3 September 3, 2002 09:43
finding exact temperature....Urgent.. Puck FLUENT 5 July 22, 2002 02:24
