IcoFsiFoam simulation crashes when using a smaller timestep
Old   January 6, 2009, 19:24
Default Hi, I tried a FSI case (the
Mathieu Olivier
mathieu is on a distinguished road
I tried a FSI case (the one available at http://powerlab.fsb.hr/ped/kturbo/OpenFOAM/run/flappingConsoleSmall_HJ_21Mar2008 .tgz) with icoFsiFoam on OpenFOAM 1.4.1-dev. The case worked fine but if I set the timestep to 0.0001 instead of 0.0003, the simulation crashes. I tried many things but I was not able to solve this problem yet.
I am currently working on an "improved" version of icoFsiFoam that handles strongly coupled cases and that problem is still very annoying (for example, I can't do timestep independance tests since I can't reduce the timestep). Any help would be greatly appreciated.
Mathieu
mathieu is offline   Reply With Quote
Old   May 17, 2009, 04:54
Default Effect of the time step on stability
joris is on a distinguished road
I have studied the effect of the time step on the stability of partitioned FSI simulations. If the fluid/solid density ratio is high (e.g. if you neglect the mass of the structure), it is normal that the convergence becomes more difficult if the time step is reduced. May I suggest a paper of myself on this subject: http://dx.doi.org/10.1016/j.compstruc.2008.05.005
Best regards,
Joris
joris is offline   Reply With Quote
Timestep for transient simulation houman CFX 2 April 28, 2005 04:44
TIMESTEP PROBLEM IN TRANSIENT SIMULATION George CFX 4 September 9, 2003 11:45
Timestep for Free Surface simulation jh CFX 0 February 13, 2003 00:55
timestep for combustion simulation yangqing FLUENT 0 August 18, 2002 09:46
Can y+ be much smaller than 1 for... Rodrigo Madariaga FLUENT 3 June 8, 2001 00:38
