January 13, 2009, 03:28 |
hi all,
Thanks Bernhard
I w
#21 |
Sachin Kanetkar
Rep Power: 17 |
hi all,
Thanks Bernhard I would like to add thermal effect for drag force calculation and eventually to the momentum change in particle....so would like to know where are the calculation for smoment_ is done so that i can add these term...smoment_ is actually defined just above tsource calculation where it is used then where are the calculations for smoment_ done thanks in advance sachin |
September 29, 2009, 11:35 |
Parallel processing hangs-icoLagrangianFoam
#22 |
Suraj Deshpande
Rep Power: 17 |
Hello All,
I am Suraj. I am trying to integrate Lagrangian particle tracking with interFoam (OpenFOAM-1.5). The code icoLagrangianFoam (written for OpenFOAM-1.5) was really very helpful. Now, I am ready with my code but it does not work very well in parallel . I added some more physical variables apart from U (ie, pd and rho) to the code and changed the equations of motion. What the code does is that it runs in parallel for some time steps and after that it just does not do anything, as if it is in an infinite loop. It also does not respond to the changes made to controlDict. Is that an MPI issue? Is it common for particle codes (I did not see decomposeParDict in any of Lagrangian code tutorials)? It would be very helpful to have your suggestion on this. Another thing I saw in the code was the time step passed to the the HardBallParticle::updateProperties(...) function (ie the line updateProperties(deltaT,data,cellI,face()); ) . I think it should be dt, as defined in HardBallParticle::move(...) function. Thanks, Regards, Suraj Deshpande |
September 29, 2009, 19:01 |
#23 | ||
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
One word of warning: I'm not planing to port the solver to OF 1.6 as starting with 1.5 there are example solvers that use lagrangian particles in the distribution. The 1.5-version of icoLagrangianFoam was just a straight port from the 1.4.1-version and didn't use the new particle classes. Could you be more specific on the topic "hangs": what is the last output (that would help to tell in which phase the problem occurs)? Have you ever run a debug-version of the code? Some problems come to light when running one (if you do any serious development you should have one) Does this always happen or only with certain decompositions? Try some different decompositions Quote:
Bernhard |
October 2, 2009, 19:23 |
#24 |
Suraj Deshpande
Rep Power: 17 |
Dear Bernhard,
I am using OpenFOAM-1.5. I am making changes to the standard interFoam solver that came with it. I have not used the debug version of the code. The code stops while moving the particles. To be more precise, it stops at the statement: this->move(td) in IncompressibleCloud.C . I have seen this happen with larger (about half a million cells) cases; smaller 2D cases do not stop. Also, interestingly, the case hangs at different times for different number of decompositions (it hangs much earlier for cases decomposed into large number of subdomains eg 32 and does not hang at all for single processor cases, no matter how big the case is). This is what leads me into thinking if this is a problem with inter-processor communication in my code. This is what I see in the log: Courant Number mean: 0.0022608 max: 0.166463 Moving Particles 529 Particles moved. 0 walls hit. 0 particles left the model. 1 particles injected. Time = 4.0672 MULES: Solving for gamma Liquid phase volume fraction = 0.517803 Min(gamma) = -2.17137e-09 Max(gamma) = 1 MULES: Solving for gamma Liquid phase volume fraction = 0.517803 Min(gamma) = -1.04872e-10 Max(gamma) = 1 DICPCG: Solving for pd, Initial residual = 0.00124773, Final residual = 4.05203e-05, No Iterations 3 DICPCG: Solving for pd, Initial residual = 0.000151898, Final residual = 6.90998e-06 , No Iterations 6 DICPCG: Solving for pd, Initial residual = 3.09272e-05, Final residual = 9.78173e-08 , No Iterations 43 time step continuity errors : sum local = 3.48316e-10, global = -7.79987e-11, cumulat ive = 3.38557e-09 ExecutionTime = 538.01 s ClockTime = 541 s Courant Number mean: 0.00226081 max: 0.167813 Moving Particles ...... hangs here Also, there are times when the the number of particles crossing processor patch goes astronomically high (3-4Million) for number of droplets as small as 150. I am not sure if this an issue too... Thanks, Suraj Last edited by suraj; October 2, 2009 at 20:57. |
October 9, 2009, 14:00 |
#25 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Pout << something << endl; statements (especially the stuff concerning parallelization) to find what might be the problem Bernhard |
October 9, 2009, 14:05 |
#26 |
Suraj Deshpande
Rep Power: 17 |
Thanks Bernhard,
I will try this and let you know if I see something interesting. Thanks again, Regards, Suraj Deshpande |
October 13, 2009, 21:46 |
#27 |
Suraj Deshpande
Rep Power: 17 |
Hi Bernhard,
I used the Pout statements as you suggested. I think I have a problem in Cloud<HardBallParticle>::move(TrackingData& td) of Cloud.C. The code stops at the statement "combineReduce(allNTrans, combineNsTransPs());" . I will try to see what this function does. Any suggestions? Thanks, Suraj Deshpande |
October 16, 2009, 06:46 |
#28 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
Which version of 1.5 are you using (unpatched, 1.5.x or something in between)? (I think there was a fix sometime it affected parallel running of dieselFoam which might have been the same problem) Bernhard |
August 20, 2010, 07:06 |
#29 |
xinguang cui
Rep Power: 17 |
Hello OpenFoamer:
I wish all of you are enjoying the life now. I am implementing a model in the icoLagrangianFoam which can solve the sub-micro particles. I need to generate the random number. I try to use the class random().scalar01() in the HardBallParticle::updateProperties, but it is pity that there is some error as following: HardBallParticle.C:181: error: request for member 'scalar01' in 'random()', which is of non-class type 'long int' who can give me some hint on it? Last edited by flying; August 20, 2010 at 09:49. |
August 20, 2010, 09:47 |
#30 |
xinguang cui
Rep Power: 17 |
Hello OpenFoamer:
I wish all of you are enjoying the life now. I am implementing a model in the icoLagrangianFoam which can solve the sub-micro particles. I need to generate the random number. I try to use the class random().scalar01() in the HardBallParticle::updateProperties, but it is pity that there is some error as following: HardBallParticle.C:181: error: request for member 'scalar01' in 'random()', which is of non-class type 'long int' who can give me some hint on it? |
February 6, 2013, 02:28 |
#31 | |
Jie
Rep Power: 16 |
Any help will be appraciated. |
February 6, 2013, 05:33 |
#32 | |
Assistant Moderator
Bernhard Gschaider
Rep Power: 51 |
BTE: the way you call it will probably always give you the same number - but I would have to look at the implementation to be 100% sure
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request |
February 6, 2013, 09:45 |
#33 | |
Jie
Rep Power: 16 |
Errors when Compiling UDF: error C2040/error C2099 | Julian K. | FLUENT | 1 | December 21, 2008 01:23 |
Compiling MRFSimple foam error | mrangitschdowcom | OpenFOAM Installation | 0 | September 15, 2008 16:09 |
FOAM FATAL IO ERROR | msrinath80 | OpenFOAM Running, Solving & CFD | 4 | July 30, 2008 11:06 |
Adding collision to icoLagrangian foam | alan_fergus | OpenFOAM Running, Solving & CFD | 0 | December 12, 2006 08:55 |
FOAM FATAL IO ERROR | sita | OpenFOAM Running, Solving & CFD | 2 | August 23, 2005 05:37 |
