Mesh Problem with icoDyMFoam
Old   January 12, 2009, 18:57
Default Hallo everybody, Hoping you
Hai Yu
yuhai is on a distinguished road
Hallo everybody,
Hoping you have had a good new years day, but I am facing a new problem. (^0^)
I made a geography and mesh by Gambit (2D), as shown below. The structure is based on my own understanding of the requirement of icoDyMFoam, I am still not sure about whether it is right or wrong.
I devided the region inside to two parts, one around a two-blade turbo, it contains the moving cells; and one on outside, it contains the stative cells. For the project, air flow from left to right, and the turbo rotates.
I converted the mesh to Foam format, and edited it, then run icoDyMFoam, then the error message shows:
Create dynamic mesh for time = 0
Selecting dynamicFvMesh mixerFvMesh
--> FOAM FATAL ERROR : Error in face ordering: mixed used and unused faces at the end of face list.
Number of used faces: 5219 and face 5219 is owned by cell 0
From function void polyMesh::initMesh()
in file meshes/polyMesh/polyMeshCalcFaceCells.C at line 107.
FOAM aborting
(In the mesh, totally 12031 faces, 6812 are for frontAndBackPlanes, 5219 are for faces used to seperate cells.)
Has anybody any idea on how this is about?
And I have still another question: in the example of mixer2D, file "cellZones" contains only movingCells. So, how will Foam find out the stative cells and deal with them?
Thx in advance.
yuhai is offline   Reply With Quote
Old   January 12, 2009, 18:59
Default can anybody tell me how to upl
Hai Yu
can anybody tell me how to upload a picture?
Old   January 13, 2009, 05:40
Default according to the website : ht
florian
Location: Mannheim - Vincennes - Valenciennes, Deutchland - France
floooo is on a distinguished road
http://www.cfd-online.com/cgi-bin/Op...?pg=formatting
\image{Text description}
if it doesn't work you can upload the picture on a website like this one :
http://www.imagup.com/index.php?page=upload
and then put the link
floooo is offline   Reply With Quote
Old   January 13, 2009, 12:42
Default This is a picture of me: http:
Hai Yu
Old   January 13, 2009, 18:45
Default Really? That is you? (I apo
Assistant Moderator
Bernhard Gschaider
(I apologize for the cheap joke)
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   January 14, 2009, 15:57
Default hallo, Bernhard, and all, tha
Hai Yu
thanks, florian
I made some modifications, and now the problem changed to:
____________________________________
--> FOAM FATAL ERROR : Zero length edge detected. Probable projection error: slave patch probably does not project onto master. Please switch on enriched patch debug for more info
From function void enrichedPatch::calcCutFaces() const
in file slidingInterface/enrichedPatch/enrichedPatchCutFaces.C at line 248.
can anybody give some hints about this?
Mesh Problem with icoDyMFoam yuhai OpenFOAM Running, Solving & CFD 0 January 12, 2009 18:53
Problem with icoDyMFoam olivier OpenFOAM Running, Solving & CFD 13 December 19, 2008 10:03
Problem with icoDyMFoam tutorial matlie OpenFOAM Bugs 10 April 26, 2007 05:51
Problem starting with icoDyMFoam kassiotis OpenFOAM Running, Solving & CFD 1 March 12, 2007 12:12
Problem with icoDyMFoam philippose OpenFOAM Running, Solving & CFD 19 March 7, 2007 13:06
